stevseluk Posted March 13, 2003 Share Posted March 13, 2003 Every time I use my 7800, the R/F varies slightly so I have to fine tune the TV every time I use it. Also it seems to change as time passes. Actually the picture quality gets better after about 30 minutes (if I retune the tv). Does this mean my 7800 is on its last legs or is this a common problem and if so is the only way to cure it, a mod job? Cheers Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted March 13, 2003 Share Posted March 13, 2003 sounds to me like there is a semi cold solder joint in the RF circuit of your 7800 in the RF tuner of your TV. The reason the picture improves after the systems have been on for a bit is because the heat build up in the TV or the 7800 actually expands the contacts of the components in the circuit and hence they actually improve their connection. I may be off base...but thermal migration is the only thing I can think of to cause this. Quote Link to comment Share on other sites More sharing options...
Clock Posted March 13, 2003 Share Posted March 13, 2003 My Pal 7800 does the same, but when I removed the large metal RF sheilding from inside, my picture remains pin sharp and in tune. I do not understand why, or whether it interferes with other equipment now that the sheild is out. I only removed the sheilding whilst trying to convert console to S-Vid connection (unsuccessfully by the way). I put the sheild back in and hey presto, it drifts again. Quote Link to comment Share on other sites More sharing options...
