Tyler Frisbee Posted June 17, 2014 Share Posted June 17, 2014 So I've started creating my first Atari game and figured it wouldn't be too hard since I know some other programming languages...oh how wrong I was Anyway, my game isn't very much so far but I haven't been able to make much progress as a few issues (mostly graphical) have been tripping me up. The first issue is that I get errors whenever I try to add more than two sprites or when I try to add color to my existing sprites, and missiles only seem to fire occasionally when pressing the spacebar and when they actually do fire, I can't seem to make it look like they are coming out of player0's gun. I obviously don't expect anyone to troubleshoot my code, but does anyone have any ideas as to what the issues may be? Thanks for the help! prototype.bas prototype.bas.bin Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted June 17, 2014 Share Posted June 17, 2014 I'd look over the examples and code snippets pinned in the batari basic section. It'll give you a feel for the kernel options and how the drawscreen command works. Basically, you need to declare which batari basic kernel you are gonna use: http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#kernelopchart You only get two sprites, two missiles and one ball. The sprite and missiles share sizes and colors too. The ball shares the color with the playfield. You can kinda fudge it with the multi-sprite kernel but that's pretty quirky. You need to set up how your colors and sprites look before each drawscreen command. Most of those settings get forgotten after the drawscreen. UPDATE: Many of the games in my sig have source. It's not terribly proper but at least it could give you a feel for working code. Quote Link to comment Share on other sites More sharing options...
bogax Posted June 17, 2014 Share Posted June 17, 2014 (edited) play with the offsets until the missilestarts where you want it to.you could try +9 x and -11 yyou park your missile off screen in the y directionbut it keeps moving in the x direction and youcan't fire again until it reaches 241also the missile and player1 move 3 pixels (relativeto each other) so eg if player1 is only 2 pixels widesometimes you'll miss Edited June 17, 2014 by bogax Quote Link to comment Share on other sites More sharing options...
Tyler Frisbee Posted June 17, 2014 Author Share Posted June 17, 2014 Thanks so much for the help guys, I managed to work out most of my problems. I apologize for the nooby questions! Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted June 18, 2014 Share Posted June 18, 2014 I apologize for the nooby questions! This forum welcomes nooby questions! Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted June 18, 2014 Share Posted June 18, 2014 Thanks so much for the help guys, I managed to work out most of my problems. I apologize for the nooby questions! Heck, you've seen my code. I'm STILL a noob! If you can't find the answer by searching and it's too small for a topic just PM me. I can't promise a timely (or best) answer but I'll try Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted June 19, 2014 Share Posted June 19, 2014 Also, even if you figured out the answer yourself, it's probably still a good idea to post a description of what the problem was and what you did to fix it, since others might conceivably run into the same issue and your post might help them. 2 Quote Link to comment Share on other sites More sharing options...
freshbrood Posted September 25, 2018 Share Posted September 25, 2018 Hello guys, another nooby question. Is there a way to share player color data the same way we can use data frame1lo and data frame1hi for sharing sprites? If so, a very simple example would really help. I am using the playercolors kernel. Thank you! Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted September 25, 2018 Share Posted September 25, 2018 Hello guys, another nooby question. Is there a way to share player color data the same way we can use data frame1lo and data frame1hi for sharing sprites? If so, a very simple example would really help. I am using the playercolors kernel. Thank you! You cannot swap color statements made for player0 or player1. Altering the start and end of a sprite does not let you mix and match arbitrarily. Basically, you can make one very long sprite and move the pointers up and down to present a vertical slice. You CAN mix and match sprite data and color data for a specific player. So, you could have player0 sprite data with a purple bat and a yellow key on one sprite data block. You could use a different player0 color statement to have a purple bat and a black key. Quote Link to comment Share on other sites More sharing options...
