Evidious Posted June 18, 2014 Share Posted June 18, 2014 i been recently using my sdive again and i have one question that hopefully someone can help I am trying to play space dungeon i have a 32 in 1 os upagrade in my 130xe when I use the 800 compatible OS it loads and works fine when i use XL/XE OS garbage appears on the screen I am sure I need to disable basic while holding down the option key when it loads and i tried that but it does not work so I am not sure what i am doing wrong Thanks in advance Quote Link to comment Share on other sites More sharing options...
+Stephen Posted June 18, 2014 Share Posted June 18, 2014 Probably not doing anything wrong. Certain games are incompatible with the XL/XE OS. You can either search for a fixed version (fandal's site has many), or keep using the OS B for that game. Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted June 18, 2014 Share Posted June 18, 2014 (edited) i been recently using my sdive again and i have one question that hopefully someone can help I am trying to play space dungeon i have a 32 in 1 os upagrade in my 130xe when I use the 800 compatible OS it loads and works fine when i use XL/XE OS garbage appears on the screen I am sure I need to disable basic while holding down the option key when it loads and i tried that but it does not work so I am not sure what i am doing wrong Thanks in advance OK, I just tried Space Dungeon on my 800XL with my SDrive and it works. If you are trying to load the game from the SDrive configuration program remember to hold down the OPTION key and then press the ATARI key. It's awkward and looks strange as OPTION advances the highlight all the way to the bottom, but it's necessary if you need to disable BASIC while using SDrive. Well, perhaps not necessary. You can try to press the ATARI key and then press OPTION but I'm almost never quick enough to pull it off. Rather than using the SDrive configuration program for each game I prefer to have Kheffington's game ATRs mounted as disks D1: through D4:. The MyPicoDOS game loader decides whether you need BASIC or not, so no fussing with the OPTION key. There's about 57MB worth of games included in Kheffington's ATR set. Unfortunately, for a game that doesn't exist as a file version then you would need to mount that ATR within the SDrive configuration program. -SteveS Edited June 18, 2014 by a8isa1 Quote Link to comment Share on other sites More sharing options...
Evidious Posted June 19, 2014 Author Share Posted June 19, 2014 when i use my sio2pc it work fine..only when i use the sdrive it wont work. thanks for your suggestion i will give it a try Quote Link to comment Share on other sites More sharing options...
