Stefan Both Posted June 21, 2014 Share Posted June 21, 2014 (edited) Because it does not really belongs to my first thread, I opened another one. Hope that is o.K. ?! Just for testing purposes, I flashed SpartadosX to MyIde-II. Seems to work fine. Now I´d like to switch back to MyDos... hm... I allready made an .atr from the shipped "workbook". When I unplug MyIDE, it boots, but of course cannot find the hardware to flash to. But the problem is, I cannot "start" the file, when MyIDE is plugged in. I mounted (Workbook.atr) it with my Sio2Sd as D1: But as long as SDX is aktiv, I cannot boot from Sio2Sd?! the atr file cannot be recognized by SDX (unknown filesystem) Any suggestions? Is there a key to be pressed to surpress booting of SDX ? Stefan Edited June 21, 2014 by Stefan Both Quote Link to comment Share on other sites More sharing options...
Marius Posted June 21, 2014 Share Posted June 21, 2014 Cold /N Quote Link to comment Share on other sites More sharing options...
Stefan Both Posted June 21, 2014 Author Share Posted June 21, 2014 Cold /N You mean: Switch off computer, hold "N" Key pressed while switch on computer? Then Im afraid - that does not work. Stefan Quote Link to comment Share on other sites More sharing options...
Stefan Both Posted June 21, 2014 Author Share Posted June 21, 2014 (edited) Oh, Uh... R T F M ! you mean type COLD /N in command line mode !!! Thank you for the hint anyway - I wasn´t able to find it in manual before... well, you have to know what you are looking for... Stefan Edited June 21, 2014 by Stefan Both 1 Quote Link to comment Share on other sites More sharing options...
Marius Posted June 21, 2014 Share Posted June 21, 2014 Yes that is it. You put the right ATR to D1: on your Sio2SD and then you boot the MyIDE 2 cart with the SDX you flashed to it. As soon as you see the D1: you type COLD /N and press return. Then the Atari reboots, and you are able to reflash your cart. 1 Quote Link to comment Share on other sites More sharing options...
