Stevaside Posted June 29, 2014 Share Posted June 29, 2014 Can anybody confirm that they will work? I'd like to pick up a 9ft pair I saw online soon, but vaguely remember someone telling me they wont work with the 7800 joypads Thanks Quote Link to comment Share on other sites More sharing options...
Trebor Posted June 29, 2014 Share Posted June 29, 2014 Can anybody confirm that they will work? I'd like to pick up a 9ft pair I saw online soon, but vaguely remember someone telling me they wont work with the 7800 joypads Thanks Unless these are "out of the ordinary" extension cables, they do (should) not modify controller mappings. The same '2600' extension cable will work for the 7800, ColecoVision, Sega Genesis, C64, Atari 8-bit computers, etc. Quote Link to comment Share on other sites More sharing options...
Bodyshots Posted June 29, 2014 Share Posted June 29, 2014 Yes they will work. You may check out this link and look at # 10. http://www.atariage.com/7800/faq/?SystemID=7800 Quote Link to comment Share on other sites More sharing options...
mckafka99 Posted June 29, 2014 Share Posted June 29, 2014 Tired of plugging in and unplugging controllers into my 7800, I recently went with the switch box and cable below to enable switching between a Space Invaders modded for 7800 controller, a Starplex controller, a regular Atari Joystick and a set of paddles. Apart from having to shave a bit of the top of the end of the connector that plugs into the 7800, this setup is working like a charm. http://www.ebay.com/itm/4Male-1Female-DB9-pin-Serial-RS232-4way-ABCD-manual-cable-cord-wire-Switch-Box-F-/301211831363?pt=LH_DefaultDomain_0&hash=item46219fcc43 http://www.ebay.com/itm/6ft-DB9pin-Male-Female-Extension-Serial-RS232-Straight-Through-Cable-Cord-SHdisc-/301221731291?pt=US_Parallel_Serial_PS_2_Cables_Adapters&hash=item462236dbdb 1 Quote Link to comment Share on other sites More sharing options...
Stevaside Posted June 29, 2014 Author Share Posted June 29, 2014 Thanks...I wouldn't think there would be a problem, but I was sure someone once told me they might not work for with the joypads for some reason..Just wanted to be sure to avoid the hassle of having to ship back an item. ..Thats's a cool idea BTW, I never thought of that....be nice to have the ease of just hitting a switch to choose between joysticks, paddles & the other controllers Quote Link to comment Share on other sites More sharing options...
treismac Posted July 24, 2014 Share Posted July 24, 2014 Tired of plugging in and unplugging controllers into my 7800, I recently went with the switch box and cable below to enable switching between a Space Invaders modded for 7800 controller, a Starplex controller, a regular Atari Joystick and a set of paddles. Apart from having to shave a bit of the top of the end of the connector that plugs into the 7800, this setup is working like a charm. http://www.ebay.com/itm/4Male-1Female-DB9-pin-Serial-RS232-4way-ABCD-manual-cable-cord-wire-Switch-Box-F-/301211831363?pt=LH_DefaultDomain_0&hash=item46219fcc43 http://www.ebay.com/itm/6ft-DB9pin-Male-Female-Extension-Serial-RS232-Straight-Through-Cable-Cord-SHdisc-/301221731291?pt=US_Parallel_Serial_PS_2_Cables_Adapters&hash=item462236dbdb Dude, that's awesome, but, man, is it a early '70s eye sore. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted April 6, 2017 Share Posted April 6, 2017 Black spray paint and woodgrain shelf paper. Issue solved. 2 Quote Link to comment Share on other sites More sharing options...
