ACML Posted July 21, 2014 Share Posted July 21, 2014 Is there a way to set up the SIO2SD to not remember what ATR is in disk 1 when you turn the power off? Is can be quite annoying when playing a XEX game and you have to manually select the menu program on the unit to reload the menu selector. I hope this feature can be set up. SDRIVE already does this by default and is easier to use when playing games. Quote Link to comment Share on other sites More sharing options...
+Philsan Posted July 21, 2014 Share Posted July 21, 2014 In my setup, every time I turn on the computer, on-screen display appears so I can select .atr/.xex. If I am not wrong all selections are saved. I don't remember what happens if you don't use on-screen display but I think selections are saved too. I am on holidays so I cannot do a test. Is your SD card write-protect switch turned off? Quote Link to comment Share on other sites More sharing options...
ACML Posted July 21, 2014 Author Share Posted July 21, 2014 In my setup, every time I turn on the computer, on-screen display appears so I can select .atr/.xex.If I am not wrong all selections are saved. I don't remember what happens if you don't use on-screen display but I think selections are saved too. I am on holidays so I cannot do a test. Is your SD card write-protect switch turned off?[/quot This is my problem. I don't want it to save my selection. I want it to clear to the SIO2SD menu when I cycle the power. I don't want to have to manually reset the loader everytime. The SDRIVE is superior in this regard. Quote Link to comment Share on other sites More sharing options...
+Philsan Posted July 21, 2014 Share Posted July 21, 2014 Ah, sorry, I didn't get it right. You want that SIO2SD doesn't remember disks settings. Have you tried to turn on write protect switch on SD card? I think SIO2SD cannot remember disks settings if SD card is read-only. Otherwise, you can ask developers to add this feature (disable auto save of disks settings); SIO2SD software is continually developed. Quote Link to comment Share on other sites More sharing options...
