Subby Posted August 2, 2014 Share Posted August 2, 2014 Two questions. First: I'm using Altirra 2.5 and it says the first two ATRs are corrupt, 103.atr & XF_551.atr. I'm just using Altirra's Disk Explorer on the freshly downloaded Altirra 2.5. Can somebody validate them for me? I need to make sure I'm not doing something incorrectly here. ATM I'm not needing them fixed (although that would be nice), I just need to verify whether they are corrupt or not. Second: Using Disk Explorer is there a way to look at "non-standard" disks like Halle_B.atr? 103.atrxf_551.atrhalle_b.atr Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted August 2, 2014 Share Posted August 2, 2014 103 is fine, halle_b is a boot disk with invalid flags for the 3 files, xf_551 has 13 directory entries that are just text with a file size of zero (0) bytes length which could be throwing it off... Quote Link to comment Share on other sites More sharing options...
phaeron Posted August 3, 2014 Share Posted August 3, 2014 Both 103.atr and xf_551.atr are being flagged due to VTOC errors. 103.atr has a minor issue with two sectors being marked in-use in the VTOC bitmap when they shouldn't. VTOCFIX.COM reports a +3 delta after correction with MyDOS rules (+2 with DOS 2). xf_551.atr has the whole disk marked as in-use when some sectors aren't covered by files. Quote Link to comment Share on other sites More sharing options...
