+discotronic Posted August 15, 2014 Share Posted August 15, 2014 Ordered Tempest from the AtariAge Store and got it in yesterday. This game shines with the Trak-Ball. A couple times between levels I either got shot or grabbed by one of the monsters. This happened as the level was phasing out. When it happens it is at the point where you can't see any of the enemies but you are still firing and can still move. I'm not sure if it happened on the same level each time. Hopefully that makes sense. Has anyone else seen this and is it normal or possibly a bug? I did a search of the forums but didn't see this mentioned anywhere. Quote Link to comment Share on other sites More sharing options...
+FujiSkunk Posted August 15, 2014 Share Posted August 15, 2014 Stupid question: Are you sure you're not hitting Spikes on your way out of levels? Quote Link to comment Share on other sites More sharing options...
+discotronic Posted August 15, 2014 Author Share Posted August 15, 2014 Stupid question: Are you sure you're not hitting Spikes on your way out of levels? You might be on to something. I didn't think about the Spikes. It is possilble that is what is happening. I will try again this evening and see if that might be it. The problem is when it happens the tube has pretty much disappeared so there is no way to tell what hits me. It has been years since I have played any version of Tempest. Forgot how much fun it is and how hard it is. Quote Link to comment Share on other sites More sharing options...
Andromeda Stardust Posted August 16, 2014 Share Posted August 16, 2014 You're hitting green spikes. This occurs in the arcade version as well. That's why it says "avoid spikes" right as you complete the level. Do not spin around the stage and do hold the fire button down as you exit, and you should be fine. 1 Quote Link to comment Share on other sites More sharing options...
+discotronic Posted August 20, 2014 Author Share Posted August 20, 2014 Yep. It was the Spikes. Thanks for the responses. Quote Link to comment Share on other sites More sharing options...
