BenMcLean Posted September 3, 2014 Share Posted September 3, 2014 (edited) I have been thinking about using the stack to do depth first search pathfinding for enemies to get around playfield obstacles when chasing the player. If it ran out of stack space before finding the player then it would throw the search away and revert to some simpler rule set for it's next move. I would try to have it get closer to catching the player within the limits of the Atari 2600's stack by biasing the search in favor of moving towards the player. (always searching in that direction first) This might enable it to get around at least some simple obstacles intelligently. Is this doable? Has it ever been done in an Atari 2600 game? (I haven't actually played all that many) (later edit) Or wait ... the search should be backwards from what I said. It should push the path from the player's position to the enemy's position so that the enemy can pull it's next destination coordinates in the order it needs to follow. Edited September 3, 2014 by BenMcLean Quote Link to comment Share on other sites More sharing options...
bogax Posted September 3, 2014 Share Posted September 3, 2014 I have been thinking about using the stack to do depth first search pathfinding for enemies to get around playfield obstacles when chasing the player. If it ran out of stack space before finding the player then it would throw the search away and revert to some simpler rule set for it's next move. I would try to have it get closer to catching the player within the limits of the Atari 2600's stack by biasing the search in favor of moving towards the player. This might enable it to get around at least some simple obstacles intelligently. Is this doable? Has it ever been done in an Atari 2600 game? (I haven't actually played all that many) (later edit) Or wait ... the search should be backwards from what I said. It should push the path from the player's position to the enemy's position so that the enemy can pull it's next destination coordinates in the order it needs to follow. I doubt it will work unless it's really really shallow. The stack is only, like, 8 deep at best and the kernel will use some. Certain options or addons will use some. You might be able to get something going if you sacrifice some variables and create a data stack. Either way it will be dependent on what options you're using and how much of RAM they use. Might be able to use look up tables. Quote Link to comment Share on other sites More sharing options...
BenMcLean Posted September 3, 2014 Author Share Posted September 3, 2014 (edited) I doubt it will work unless it's really really shallow. The stack is only, like, 8 deep at best and the kernel will use some. Certain options or addons will use some. You might be able to get something going if you sacrifice some variables and create a data stack. Either way it will be dependent on what options you're using and how much of RAM they use. Might be able to use look up tables. Random Terrain's web site says, "The DPC+ stack can be used to save and restore your bB variables. There are 256 stack locations available, with the top-most location being #0 and the bottom-most being #255.... Note: The DPC+ stack is a special stack just for you that is 100% dedicated to your push and pull commands. Nothing else uses it. It's all yours." According to this, I should have 256 bytes of stack space that is only for my program, (not used by the kernel) which is used by the push and pull commands. This would be separate from and in addition to the 26 bytes used for variables and the six bytes used for the gosub and return commands. Is that true or not? Edited September 3, 2014 by BenMcLean Quote Link to comment Share on other sites More sharing options...
bogax Posted September 3, 2014 Share Posted September 3, 2014 Random Terrain's web site says, "The DPC+ stack can be used to save and restore your bB variables. There are 256 stack locations available, with the top-most location being #0 and the bottom-most being #255.... Note: The DPC+ stack is a special stack just for you that is 100% dedicated to your push and pull commands. Nothing else uses it. It's all yours." According to this, I should have 256 bytes of stack space that is only for my program, (not used by the kernel) which is used by the push and pull commands. This would be separate from and in addition to the 26 bytes used for variables and the six bytes used for the gosub and return commands. Is that true or not? Ah, well, I know almost nothing of DPC+ If RT says so I'd take it as truth until proved otherwise. Sounds like you're good to go, let us know how it works out. (When you say depth first I'm thinking recursive subroutine calls, but of course, it doesn't have to be that way and you could probably manage that with a little asm trickery) Quote Link to comment Share on other sites More sharing options...
BenMcLean Posted September 3, 2014 Author Share Posted September 3, 2014 (edited) (When you say depth first I'm thinking recursive subroutine calls, but of course, it doesn't have to be that way and you could probably manage that with a little asm trickery) Given that you can really only go three gosubs deep, (six bytes reserved / two bytes per gosub = three gosubs) obviously I would want to use goto for the recursion in this case, not gosub, and keep track of how deep in the recursion I am with variables. I do plan to use individual gosub/return pairs within each iteration in order to abstract some parts of the algorithm that are used multiple times. I don't think I'd need to write any actual assembly for this. It seems like it should be doable within Batari Basic. Edited September 3, 2014 by BenMcLean Quote Link to comment Share on other sites More sharing options...
bogax Posted September 3, 2014 Share Posted September 3, 2014 Given that you can really only go three gosubs deep, (six bytes reserved / two bytes per gosub = three gosubs) obviously I would want to use goto for the recursion in this case, not gosub, and keep track of how deep in the recursion I am with variables. I do plan to use individual gosub/return pairs within each iteration in order to abstract some parts of the algorithm that are used multiple times. I don't think I'd need to write any actual assembly for this. It seems like it should be doable within Batari Basic. Not that I'm advocating it, but there's at least two ways to implement a computed goto with just a few bytes of asm (push an address to the return stack and return or jump indirect) Given that, you could in principle use the DPC+ data stack as a return stack. (or do direct or indirect threading write a FORTH in bB ) Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted September 4, 2014 Share Posted September 4, 2014 Just opinion here. I apologize in advance. Avoid trying to shoe in modern game theory into an Atari 2600 game. I've had to un-learn using gosubs due to eating CPU cycles. I use roomy/spacious playfield screens to avoid having to worry about pathfinding. When I do, it's typically something like picking new goalx and goaly locations for the enemy and then seek the player again when it reaches those coordinates. Quote Link to comment Share on other sites More sharing options...
BenMcLean Posted September 11, 2014 Author Share Posted September 11, 2014 (edited) Depth first search isn't really "modern game theory" ... it's just an algorithm and most of the work on it was done in the '70s unless I am greatly mistaken. Anyway, I have come up with a reason why this won't work: there is no fast enough way to check whether or not you've already searched a particular square before in order to avoid going in circles in your search path. You'd have to progress back through the entire stack at each square you search and that would almost certainly be prohibitively expensive. I'll just have to think of something else. Or maybe use a grid with bigger/fewer squares ... hmm. Will keep thinking this over. Edited September 11, 2014 by BenMcLean Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted September 12, 2014 Share Posted September 12, 2014 I guess what I meant is that you're trying to force to 2600 to do things that work on more robust systems. That's OK if that's your primary goal. Otherwise you might have to apply some lateral thinking. Quote Link to comment Share on other sites More sharing options...
