+Gemintronic Posted September 8, 2014 Share Posted September 8, 2014 Here is a demonstration of abusing using player0pointerlo to apparently squeeze more sprites out of your sprite data. Your sprite data can be larger than the sprite itself. By changing the lowest position inside the sprite data to start drawing your sprite we can make it appear like a different sprite. The important bits of code are here: rem /** p0lo saves the starting value of the bottom position **/ rem /** inside player0 sprite data **/ p0lo = player0pointerlo and here: change_player0 rem /** Randomize player0 x/y values **/ player0x = rand player0y = rand&31 rem /** Change the bottom starting point in the larger **/ rem /** player0 sprite data **/ player0pointerlo = (p0lo +(rand&3)) rem /** Randomize the player0 size and duplication **/ monsize = rand goto after_col changespr.bas changespr.bin 2 Quote Link to comment Share on other sites More sharing options...
bogax Posted September 8, 2014 Share Posted September 8, 2014 (edited) If you put your sprite data in to a data stament you'll have a name that you can use to refer to the sprite data and you won't have to use a variable to save the pointer. You also save a few bytes of code that sets up the pointers which you would be duplicating. But you have to make sure the data doesn't cross a page boundary or at least make sure no individual sprite crosses a page boundary (in which case you'ld have to deal with all 16 bits of the pointer).(I'll have to play with it some more but it sounds like page crossings may not be a problem with the DPC+ kernel) Making sure the data doesn't cross a page boundary is just a small bit of asm and not a problem. simplest I think is to just tell DASM to page align it. asm align 256 end That may not be needed in which case it'll just waste space. If the total of your sprite data approaches 256 bytes (so that there's a good chance that it would cross a page boundary) might as well put it all in one place and use the page alignment and of course the asm needs to go immediately before the block of data you're aligning. This (which I lifted from a list file) fills with 0 bytes if the data would cross a page boundary. You have to supply it with the length of the data. rem fills in with zero bytes if necesary so that rem the sprite table doesn't cross a page boundary asm if (<*) > (<(*+datalength)) repeat ($100-<*) .byte 0 repend endif end If you use the usual player definiton for the data you can still use a constant and save the variable, but it's trickier because the name is the line number so pretty much any change to the program will likely change the name. You can dig into the asm listing and find the address or you could read it from the player pointer (then put it in a constant). I think once you get the sprite data settled, if bB is putting it into it's own bank, the address will remain the same provided the length of the actual data doesn't change. Edited September 8, 2014 by bogax Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted September 8, 2014 Author Share Posted September 8, 2014 I might need an example.bas to fully understand yer technique. The one variable used here is a tradeoff indeed. I suspect that there's a way to use the already allocated player0pointerlo but I never got it to work right :/ Quote Link to comment Share on other sites More sharing options...
bogax Posted September 8, 2014 Share Posted September 8, 2014 (edited) There's some of that here. player0_parameterized.bas uses player0pointer I forgot to mention that using a player statement has the advantage that bB takes care of the page boundaries http://basicplay.netau.net/ I don't have one there that uses a constant with a player statement but I've got one somewhere. Really the easiest thing is just to assign the low byte of the player pointer to a playfield variable and read it that way (which assumes you have playfield variables you can assign to). Of course you have to decipher the binary then and it takes 4 bytes which you may have to subtract when you remove the assignment. edit oops player0_parameterized.bas was the wong file now fixed and augmented (see below) and uses a player0 statement with a constant. Edited September 8, 2014 by bogax Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted September 8, 2014 Author Share Posted September 8, 2014 Thank you, sir! Bookmarked and perusing Quote Link to comment Share on other sites More sharing options...
bogax Posted September 8, 2014 Share Posted September 8, 2014 here's something you could try I've added it to the player0_parameterized.bas mentioned above (and changed it to use a player0 statement with a constant) rem this will read a byte into the score rem it's padded to exactly one page so it rem shouldn't change the page alignment rem if it's removed rem you will have to change the assignment of rem temp4 to whatever you want to read, of course rem and it will have to be a simple variable rem or a constant, indexing will throw the total off temp4 = player0pointer score = 0 if temp4{7} then score = score + 128 if temp4{6} then score = score + 64 if temp4{5} then score = score + 32 if temp4{4} then score = score + 16 if temp4{3} then score = score + 8 if temp4{2} then score = score + 4 if temp4{1} then score = score + 2 if temp4{0} then score = score + 1 rem this is just padding temp4 = 0 : temp4 = 1 : temp4 = 2 : temp4 = 3 temp4 = 4 : temp4 = temp4[0] + 6 Quote Link to comment Share on other sites More sharing options...
bogax Posted September 15, 2016 Share Posted September 15, 2016 this might be something animated_sprite.bas animated_sprite.bin parameterized_animation.bas parameterized_animation.bin player0_parameterized.bas player0_parameterized.bin 1 Quote Link to comment Share on other sites More sharing options...
wallaby Posted September 15, 2016 Share Posted September 15, 2016 this might be something I have rabbit holed so far down this it isn't even funny anymore. Your example works. So then I thought, why not make it so I store the lo and hi bits in data. Then I can use some fancy coding to select player 1 or 2 or whatever. Storing the lo bit: const player_0_lo = <playerpointers ;WORKS. data player_pointers_lo <playerpointers ;DOESN'T WORK end I thought it would be more elegant to change the player lo bit with a data table. Because you could type: player0pointerlo = player_pointers_lo[0] + 8 And that would work for player 0. Instead of having to use a constant e.g: player0pointerlo = player_0_lo + 8 But, after typing that out. I don't think it matters. You probably save more space using a constant anyway. As long as I'm not going crazy with animation frames constants would work, I guess. I keep getting dragged into a marathon battle with this game. Quote Link to comment Share on other sites More sharing options...
