Cybearg Posted October 31, 2014 Share Posted October 31, 2014 It's a shame that, with how much detail DPC+ allows, you're limited to just the 4k of the final bank for all sprite and playfield data. Is there any way to increase that amount or to allow sprite and/or playfield data to be spread across different banks? Also, did RevEng ever make a version of DPC+ that takes advantage of ROMS greater than 32k? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted October 31, 2014 Share Posted October 31, 2014 The DPC+ bankswitch format, which bB DPC+ uses, is defined as a 32K image containing: 3K of ARM code (the DPC+ driver) six 4K banks for code one 4K bank for graphic data 1K of ARM data (note frequencies for music generation) It can't be any larger, or any smaller. It's possible a new version of the DPC+ bankswitching format could be done for Harmony Encore, though I suspect it'll be a long time before that would happen. The 4K of graphic data does end up in RAM as RAM is significantly faster for the ARM code to access than ROM. That extra speed is required in order for DPC+ to work. You could use the DPC+ copy feature to manipulate what's in RAM in order to utilize more than 4K of graphics - I do that in my games, though I use C code instead of the DPC+ copy feature to do the copying. In order to do this in bB would require an understanding of how bB uses DPC+ bankswitching, so that's not something I could help you with. batari mentions how to use the copy feature here (along with the fill feature). 2 Quote Link to comment Share on other sites More sharing options...
Cybearg Posted October 31, 2014 Author Share Posted October 31, 2014 Thanks for the information! I'll look into it. Quote Link to comment Share on other sites More sharing options...
Cybearg Posted October 31, 2014 Author Share Posted October 31, 2014 ScumSoft posted an Assembly function that is supposed to do this sort of thing: MAC COPY2RAM .source SET {1} .destination SET {2} .amount SET {3} .mode SET {4} LDA #<.destination STA DF0LOW LDA #(>.destination) & $0F STA DF0HI lda #<.source sta PARAMETER ;byte pointer increments on write lda #((>.source) & $0f) | (((>(.source)) / 2) & $70) sta PARAMETER lda #0 ;Using DataFetcher #0 sta PARAMETER lda #.amount ;256 bytes copy max sta PARAMETER lda .mode sta CALLFUNCTION ENDM Now, is this actually complete, or is PARAMETER just pseudo-code? I don't see what PARAMETER and CALLFUNCTION refer to. Also, how do I know exactly which RAM locations to overwrite? That is, if I have a number of sprite and playfield definitions, how can I tell which location needs to be swapped out? Also, does the entirely of that 4k of graphics ROM get copied to 4k of RAM in one go, or does it get copied over in smaller chunks as it's referenced? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted October 31, 2014 Share Posted October 31, 2014 PARAMETER and CALLFUNCTION are DPC+ registers. They're defined in DPCplus.h The .amount is a single byte, so you can copy from 0-255 bytes. It's possible that passing 0 means "copy 256", though I don't know for sure. As for locations to swap out, you'll need somebody familiar with bB's usage of DPC+ to tell you that. Quote Link to comment Share on other sites More sharing options...
iesposta Posted November 7, 2014 Share Posted November 7, 2014 Thanks for the information! I'll look into it. Anything come of this? You could do what I do and make playfield pixels in data statements, thus using the ROM batari Basic banks for the data and leaving the graphics bank free for other things. Also is it easy to "Tell virtual Player3 to use Player0's color?" and save space there? I thought you were looking into that also. Quote Link to comment Share on other sites More sharing options...
Cybearg Posted November 8, 2014 Author Share Posted November 8, 2014 I haven't really had the time yet. I started a new job recently, so I haven't gotten any programming done in weeks. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted November 8, 2014 Share Posted November 8, 2014 I haven't really had the time yet. I started a new job recently, so I haven't gotten any programming done in weeks. Your priorities are all messed up. Atari first. Quote Link to comment Share on other sites More sharing options...
Cybearg Posted November 8, 2014 Author Share Posted November 8, 2014 Also is it easy to "Tell virtual Player3 to use Player0's color?" and save space there? I thought you were looking into that also. On this, and on getting both sprite and color data shared between sprites, I have a question... Here is an example of my current set-up: .L0129 ; on frame goto __Stand __Stand __Stand __Stand __WalkA __WalkB __WalkA __WalkC LDX frame LDA .L0129jumptablehi,x PHA LDA .L0129jumptablelo,x PHA RTS .L0129jumptablehi .byte >(.__Stand-1) .byte >(.__Stand-1) .byte >(.__Stand-1) .byte >(.__Stand-1) .byte >(.__WalkA-1) .byte >(.__WalkB-1) .byte >(.__WalkA-1) .byte >(.__WalkC-1) .L0129jumptablelo .byte <(.__Stand-1) .byte <(.__Stand-1) .byte <(.__Stand-1) .byte <(.__Stand-1) .byte <(.__WalkA-1) .byte <(.__WalkB-1) .byte <(.__WalkA-1) .byte <(.__WalkC-1) . ; .__Stand ; __Stand .L0130 ; player0: LDX #<playerL0130_0 STX player0pointerlo LDA #((>playerL0130_0) & $0f) | (((>playerL0130_0) / 2) & $70) STA player0pointerhi LDA #30 STA player0height . ; I wonder, though, instead of that on...goto using pointers to branch, could I instead have the player0: code just reference a table of hi and lo pointers to the graphics data itself? This way, all it would take would be a duplicate of those 6 lines of ASM and using the same sprite pointer table to allow sprite data to be easily shared across all sprites. without ever having to re-define sprites. I did this in the past with my Piñata collection. In Fixer Fenix, Wrecker Ron can re-use sprites between his left and right side, cutting out any duplication of sprite data. To do this, I had to use a tweaked bit of ASM: asm setRalph LDX ralphstate LDA ralphLlo,x STA player0pointerlo LDA ralphLhi,x STA player0pointerhi LDA ralphRlo,x STA player1pointerlo LDA ralphRhi,x STA player1pointerhi LDA #17 STA player0height STA player1height end ... which referenced a table of sprite data pointers: ralphLlo .byte <ralphStandA .byte <ralphClimbA .byte <ralphClimbB .byte <ralphPoundA .byte <ralphPoundB ralphLhi .byte >ralphStandA .byte >ralphClimbA .byte >ralphClimbB .byte >ralphPoundA .byte >ralphPoundB ralphRlo .byte <ralphStandA+1 .byte <ralphClimbB+1 .byte <ralphClimbA+1 .byte <ralphPoundB+1 .byte <ralphPoundA+1 ralphRhi .byte >ralphStandA .byte >ralphClimbB .byte >ralphClimbA .byte >ralphPoundB .byte >ralphPoundA ... which in turn referenced the actual sprite data: if (<*) < 90 repeat (90-<*) .byte 0 repend endif ralphStandA .byte 0 .byte %00111100 .byte %00011110 .byte %11101111 .byte %11010111 .byte %11110111 .byte %11101111 .byte %11101111 .byte %11101111 .byte %11111111 .byte %01111110 .byte %00011111 .byte %00000101 .byte %00001111 .byte %00000101 .byte %00000000 .byte %00000000 if (<*) > (<(*+16)) repeat ($100-<*) .byte 0 repend endif if (<*) < 90 repeat (90-<*) .byte 0 repend endif ralphClimbA .byte 0 .byte %00000000 .byte %00011110 .byte %11101111 .byte %11010111 .byte %11110111 .byte %11101111 .byte %11101111 .byte %11101111 .byte %11111111 .byte %01111111 .byte %00011111 .byte %00000111 .byte %00001111 .byte %00000101 .byte %00000000 .byte %00000000 if (<*) > (<(*+16)) repeat ($100-<*) .byte 0 repend endif if (<*) < 90 repeat (90-<*) .byte 0 repend endif ralphClimbB .byte 0 .byte %00111100 .byte %00011110 .byte %00001111 .byte %00000111 .byte %00000111 .byte %00001111 .byte %00001111 .byte %00001111 .byte %01111111 .byte %11111111 .byte %11111111 .byte %11100111 .byte %11101111 .byte %11110101 .byte %11010000 .byte %11100000 if (<*) > (<(*+16)) repeat ($100-<*) .byte 0 repend endif if (<*) < 90 repeat (90-<*) .byte 0 repend endif ralphPoundA .byte 0 .byte %00111000 .byte %00111000 .byte %00111100 .byte %00111100 .byte %00111000 .byte %00111000 .byte %00111000 .byte %00111001 .byte %00111010 .byte %00111110 .byte %00011111 .byte %00000101 .byte %01111111 .byte %11111111 .byte %11111111 .byte %10001111 if (<*) > (<(*+16)) repeat ($100-<*) .byte 0 repend endif if (<*) < 90 repeat (90-<*) .byte 0 repend endif ralphPoundB .byte 0 .byte %00000000 .byte %00000000 .byte %00000000 .byte %11100000 .byte %11100000 .byte %11110000 .byte %11110000 .byte %11100001 .byte %11100010 .byte %11111110 .byte %01111111 .byte %00000101 .byte %01111111 .byte %11111111 .byte %11111111 .byte %10001111 ...changing what otherwise would have required sprite definitions for both player0 and player1 into just single sprite definitions, saving a LOT of space. This would work the same for color data. However, those were with 4k games, where I could just add that sprite data at the end of the .bas file in asm...end statemetns and I was fine. In DPC+, I apparently can't directly put the necessary sprite code into the last bank because that's off-limits. Furthermore, the pointers seem a lot more complicated. Is there a way that I CAN include the sprite data to be added in the final bank? Would it just simply involve modifying the includes file to add the sprite.asm file after the bB.asm file? Would there be complications in using tables of pointers in this way for DPC+ sprite data? Also, what are the limitations of using these kinds of pointers? Can you actually create pointers and pointer-pointers using this table >pointer <pointer notation? Quote Link to comment Share on other sites More sharing options...
