jimbox114 Posted November 19, 2014 Share Posted November 19, 2014 I have been working on a simple Atari game. The basics is two fish blowing bubbles (missiles) at each other. The first fish to get hit 10 times loses and it will go to a cutscene showing the winning fish swim up to a female (pink) fish and play a little tune and be over. I have it set up to be 1 player or 2 player. If joy1fire is pressed at the title screen it sets a variable to skip the auto controls for the other player and allow joystick controls. I am having two problems with it right now. For starters I can't get player1 to shoot a missile. Rather its on 1player or 2player it just sets the missile in front of the player and it doens't move. The other problem is while playing in 2 player. If player0 is moving player1's controls don't work until the move ends. Here is the code, I have also included the .bas files in case the spacing is off on this copy and paste: rem Generated 11/11/2014 3:13:05 PM by Visual bB Version 1.0.0.554 rem ********************************** rem *<Deep.bas> * rem *<Fish Wars!> * rem *<jimbox114@gmail.com * rem **********************************opening const noscore = 1 rem p is player 1 health and q is player 2 health whichever hits 10 first loseslet p = 0:let q = 0:h = 0 playfield: .XXXX..XXXXX...XXXXX...X...X.... .X.......X.....X.......X...X.... .XXX.....X.....XXXXX...XXXXX.... .X.......X.........X...X...X.... .X.....XXXXX...XXXXX...X...X.... ................................ ..X...X......X......XXXX..XXXXX. ..X...X.....X.X.....X..X..X..... ..X...X....X...X....XXXX..XXXXX. ..X.X.X...XXXXXXX...X.X.......X. ..XX.XX...X.....X...X..X..XXXXX.end COLUBK=$A4 COLUPF=$0E let a = 0 drawscreen rem tells the game to enable 2player mode if joy0fire then goto main if joy1fire then let a = 1:goto main goto opening main playfield: ................................ ................................ ................................ ................................ ................................ ................................ ................................ .....................X.......... .....X..............X........... ....X................X.......... XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXend COLUPF=$FE COLUBK=$80 player0x=20:player0y=50 player1x=140:player1y=50 missile0height=1:missile0x=170 missile1height=1:missile1x=0 NUSIZ0 = 16 NUSIZ1 = 16sprites COLUP0=$FC player0: %00000000 %00010000 %00001000 %01011100 %00111011 %01011100 %00001000 %00010000end COLUP1=$BA player1: %00000000 %00001000 %00010000 %00111010 %11011100 %00111010 %00010000 %00001000end if missile0x>155 then let missile0y=200:goto skip if missile1x<3 then let missile1y=200:goto skip missile0x = missile0x+2:goto draw_loop missile1x = missile1x-2:goto draw_loopskip if joy0fire then missile0y=player0y-4:missile0x=player0x+4:goto playsound if joy1fire && a = 1 then missile1y=player1y-4:missile1x=player1x+3:goto playsound draw_loop drawscreen if q = 10 then goto final if p = 10 then goto final rem prevents players from leaving screen if player0x < 5 then player0x = 4 if player0x > 70 then player0x = 69 if player0y < 8 then player0y = 8 if player0y > 80 then player0y = 80 if player1x > 150 && a = 1 then player1x = 150 if player1x < 80 && a = 1 then player1x = 81 if player1y < 8 && a = 1 then player1y = 8 if player1y > 80 && a = 1 then player1y = 80 if a = 1 then 1s: rem skips autocontrol and allows joy1 commands for player 2 if player0y=player1y then missile1y=player1y-4:missile1x=player1x-1:missile1x = missile1x-2 if player1x = 139 then player1y = player1y-1 if player1x = 140 then player1y = player1y+1 if player1y > 80 then player1y = player1y-8:player1x=139 if player1y < 5 then player1y = player1y+1:player1x=140 if player1y = 5 then let h = h + 1 1s if collision(missile0,player1) then p = p +1:missile0y=255:goto playsound1 if collision(missile1,player0) then q = q +1:missile1y=255:goto playsound1 if joy0up then player0y = player0y-1:goto jump if joy0down then player0y = player0y+1:goto jump if joy0right then player0x = player0x+1:goto jump if joy0left then player0x = player0x-1:goto jump if joy1up && a = 1 then player1y = player1y-1:goto jump if joy1down && a = 1 then player1y = player1y+1:goto jump if joy1right && a = 1 then player1x = player1x+1:goto jump if joy1left && a = 1 then player1x = player1x-1:goto jump 1p if switchreset then let player1y=200:player0y=200:missile1y=200:missile0y=200:goto openingjump goto spritesplaysound AUDV0 = 5 : AUDC0 = 4 : AUDF0 = 10 u = u + 2 drawscreen if u < 1 then playsound u = 0 AUDV0 = 0 : AUDC0 = 0 : AUDF0 = 0 goto jumpplaysound1 for u = 1 to 30 AUDV0 = 5 : AUDC0 = 12 : AUDF0 = u next u rem p = p + 2 drawscreen if u < 1 then playsound1 rem p = 0 AUDV0 = 0 : AUDC0 = 0 : AUDF0 = 0 goto jumpfinal rem working on final cutscene need to match some colors up with the fish etc. player0x=20:player0y=50 player1x=140:player1y=50 player1x=player1x-4 if player1x=player0x then player0y=player0y-2 if player0y<0 then COLUP0=$54:player0y=50:player0x=1 if joy0fire then goto main if joy1fire then goto main deep.bas Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted November 19, 2014 Share Posted November 19, 2014 See if this helps for the missile part of your problem: randomterrain.com/atari-2600-memories-batari-basic-commands.html#sprite_ball_miss_coll_example Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted November 19, 2014 Share Posted November 19, 2014 The problem you're having is that you've tangled the different if statements together. This is causing the right player to have dependencies on the left player's state. Change: if missile0x>155 then let missile0y=200:goto skip if missile1x<3 then let missile1y=200:goto skip missile0x = missile0x+2:goto draw_loop missile1x = missile1x-2:goto draw_loop skip if joy0fire then missile0y=player0y-4:missile0x=player0x+4:goto playsound if joy1fire && a = 1 then missile1y=player1y-4:missile1x=player1x+3:goto playsound To: rem if else structure for missle0 processing if missile0x < 154 then missile0x = missile0x+2 : goto skip0 missile0y=200 if joy0fire then missile0y=player0y-4:missile0x=player0x+4:goto playsound skip0 rem if else structure for missle1 processing if missile1x > 2 then missile1x = missile1x-2 : goto skip1 missile1y=200 if joy1fire && a = 1 then missile1y=player1y-4:missile1x=player1x+3:goto playsound skip1 Make sure you understand this if/else pattern before you proceed. There are other places where you have the same issue. This is why the fish will not change both x and y position at the same time. Quote Link to comment Share on other sites More sharing options...
jimbox114 Posted November 20, 2014 Author Share Posted November 20, 2014 Thanks for the reply. I looked at my player controls and removed the :goto statements at the end of each of my joy commands that that solved player 1 overriding player 2. Your missle code also took care of it as well. I really apprecaite the help I can honestly say I learned something today. When I went back and read the code I could see exactly the problem. Now both fish blow bubbles with sound and they both can move all directions as well. Now all I need is a healthbar for each of them and my cutscene but I think I can handle that with some research. Quote Link to comment Share on other sites More sharing options...
