orion1052003 Posted December 8, 2014 Share Posted December 8, 2014 What does line 290 mean? I thought it meant IF you typed R,L, and space then the program branches to line 210 but that does not happen? If I type R or L the program does not branch to line 290. Perhaps I should have tried typing just a space. Does it mean IF R AND L AND space THEN branch? Notes : In the book, the story has 4 team members trying to cross a gorge one at a time on a harness attached to a line or rope. The array ACT$ holds the names of the four team members. Line 720 has a non-TI command that places the cursor at coordinates. I used Display At with coordinates, without printing anything. It appears the "rope" printing is done in lines 580 and 640. I don't know how you would modify this to PRINT what is intended or if there is a TI function just to place the cursor anywhere. The "Microadventure" books no longer support TI at this point, Book 7. The last Book is #10. The book came out in 1985, and I think the TI was discontinued in 1984. 300-320 seems to print a dropping off the person to there doom by PRINTing in the natural vertical fashion. I assume the rope crossing printing is supposed to be horizontal somehow like the bar in line 100. Maybe the "@" in line 580 and 640 is used to show the harness going left and right horizontally on the line. I am not sure if Line 390 is correct syntax as it has SEG$ with an array name inside of it as a parameter. The program is a mess of jumping and branching. Y=2 in line 5, but changes to 10 in line 90 without being used for anything yet. Why change y=2 to y=10, when you can start off with y=10? In line 70, If I don't change the value of CL$, the program never reaches line 210. I may be wrong, but I never got to line 210 that I know of until I changed CL$ to any string but "OFF" as mentioned in line 120. Line 150 GOSUBs Line 560 which leads to GOSUB 720 with one return at the very last line 730. What happens if you GOSUB a GOSUB and then RETURN? Should the RETURN send control back to line 160 or line 570? I am not sure why X needs to equal BX in line 570. I added line 5, OPTION BASE 1. BOOK 7 PROGRAM 4 5 OPTION BASE 1 10 ACT$(1)="BRONZE" 20 ACT$(2)="FRIEDA" 30 ACT$(3)="ARCH" 40 ACT$(4)="ORION" 50 J=1 :: B=1 :: Y=2 60 L$="B" :: Z$=" " 70 CL$="OFF" 80 CALL CLEAR 90 Y=10 :: GOSUB 710 100 PRINT"+--------------------+" 110 BX=2 120 IF CL$<>"OFF" THEN 210 130 BX=5 140 FOR I=1 TO 10 150 GOSUB 560 160 NEXT I :: GOSUB 680 170 FOR I=1 TO 10 180 GOSUB 620 190 NEXT I:: GOSUB 680 200 GOTO 140 210 GOSUB 700 220 IF BX<2 THEN BX=2 :: GOSUB 350 230 IF BX>20 THEN BX=20 :: GOSUB 420 240 Y=5 :: GOSUB 710 250 PRINT"ENTER L OR R" 260 INPUT M$ 270 IF M$="R" THEN GOSUB 560 280 IF M$="L" THEN GOSUB 620 290 IF (M$="R")+(M$="L")+(L$=" ") THEN 210 300 FOR KK=1 TO 10 310 PRINT TAB(5);L$ 320 NEXT KK 330 PRINT"YOU DROPPED",ACT$(J) 340 END 350 IF B=0 THEN 380 360 PRINT "AT STARTING POINT " 370 RETURN 380 PRINT"PICK UP",ACT$(J) 390 L$=SEG$(ACT$(J),1)!LEFT$(SEG$)IN BOOK 400 B=1 410 RETURN 420 IF B=1 THEN 450 430 PRINT"HARNESS IS EMPTY" 440 RETURN 450 Y=4 :: GOSUB 710 460 PRINT ACT$(J);" MADE IT" 470 Z$=Z$+L$!PROBABLY & NOT + IN TI XB 480 Y=10 :: X=20 :: GOSUB 720 490 PRINT Z$ 500 J=J+1 :: B=0 :: L$=" " 510 IF J<5 THEN 540 520 PRINT "ALL ACT MEMBERS ON OTHER SIDE" 530 END 540 GOSUB 700 :: PRINT"FETCH NEXT MEMBER " 550 RETURN 560 BX=BX+1 570 Y=10 :: X=BX :: GOSUB 720 580 PRINT"-@" 590 Y=11 :: GOSUB 720 600 PRINT " ";L$ 610 RETURN 620 Y=10:=BX::GOSUB 720 630 BX=BX-1 640 PRINT"@-" 650 Y=11 :: GOSUB 720 660 PRINT L$;" " 670 RETURN 680 FOR K=1 TO 500 :: NEXT K 690 RETURN 700 Y=1 710 X=1 720 !LOCATE Y,X 730 RETURN Quote Link to comment Share on other sites More sharing options...
+5-11under Posted December 8, 2014 Share Posted December 8, 2014 I haven't looked at the rest of the code, but it looks like the "+"s are "OR"s. Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted December 8, 2014 Share Posted December 8, 2014 I'd have to pull out my copy of the book to look at the original code and see what needs changing to get it to work on a TI (I have all 10 of these). It is unfortunate that they abandoned the TI after the sixth one. . . Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted December 8, 2014 Share Posted December 8, 2014 (edited) 390 L$=SEG$(ACT$(J),1)!LEFT$(SEG$)IN BOOK This will throw an error. The format is SEG$(stringexpression,position,length) So if it is the leftmost byte of the string it should be: L$=SEG$(ACT$(J),1,1) 470 Z$=Z$+L$!PROBABLY & NOT + IN TI XB You are right, it should be an ampersand 470 Z$=Z$&L$ 290 IF (M$="R")+(M$="L")+(L$=" ") THEN 210 the + sign is the same as an OR; the * sign is the same as an AND. So here you have IF M$="R" OR M$="L" OR L$=" " THEN 210 What happens if you GOSUB a GOSUB and then RETURN? Should the RETURN send control back to line 160 or line 570? RETURN goes back to the statement following the GOSUB that called it. But in your program the subroutine at 720 is a remark followed by RETURN, so it does nothing. Something must have been left out. You can test the above easily: 100 PRINT "LINE 100"::GOSUB 200::PRINT "BACK TO LINE 100"::END 200 PRINT "LINE 200"::GOSUB 300::PRINT "BACK TO LINE 200"::RETURN 300 PRINT "LINE 300"::RETURN Edited December 8, 2014 by senior_falcon 1 Quote Link to comment Share on other sites More sharing options...
