Retro Lord Posted January 1, 2015 Share Posted January 1, 2015 I'm experimenting with the advlight script that allows you too have a light effect around the player. There's one thing I can't figure out. How do I make player1(monster) overlap player0(light) so that player1 becomes visible when in the light? I've set COLUP1 too $00 so it's the same color as the background so you can't see it unless it's in the light zone. Thanks in advance. rem ---- Adventure 'Light' Sample Program ---- rem This program demonstrates how to move an animated sprite. rem It combines previous sample programs I've written, and rem adds an invisible playfield along with the 'light' sprite rem that surrounds the player in the mazes in the original rem Atari adventure game. rem Any non-indented command is taken as a label. This is rem something you can jump to with the 'goto' or 'gosub' rem command. rem Declare Variables: rem I'm going to declare x and y variables for the player's rem position, so I can move him with the joystick later. missile0x=50 missile0y=50 player1x=100 player1y=50 rem Add Static Playfield playfield: X..............................X XXXXXXXXXXXXXXXXXXXX..........XX X..................X...........X X..............................X XX............................XX X..............................X X..............................X XX............................XX X.........X....................X X.........XXXXXXXXXXXXXXXXXXXXXX X..............................X end rem Change the color of the playfield to black to match the rem background color. We want the walls to be invisible for rem this sample. COLUPF=0 main rem Set NUSIZ to make light sprite quad sized. rem rem Value Effect rem $0x (x = don't care) missile = 1 pixel wide rem $1x missile = 2 pixels wide rem $2x missile = 4 pixels wide rem $3x missile = 8 pixels wide rem $x0 one copy of player and missile rem $x1 two close copies of player and missile rem $x2 two medium copies of player and missile rem $x3 three close copies of player and missile rem $x4 two wide copies of player and missile rem $x5 double-sized player rem $x6 three medium copies of player and missile rem $x7 quad-sized player NUSIZ0=$37 missile0height = 8 rem Set CTRLPF so light sprite moves behind playfield rem rem Value Effect rem $0x (x = don't care) ball = 1 pixel wide rem $1x ball = 2 pixels wide rem $2x ball = 4 pixels wide rem $3x ball = 8 pixels wide rem $x1 none of the below rem $x3 left half of PF gets player0 color, rem right half gets player1 color rem $x5 players move behind playfield rem $x7 both of the above CTRLPF=$05 rem position light sprite so it surrounds player sprite rem and moves with it player0x=missile0x-20:player0y=missile0y+20 rem COLUP0=<xx> sets the color of the player 0 sprite. Valid rem range is 0-254. rem Sample Program 3 used 28 (decimal), which is yellow. rem Sample Program 5 used $28 (hexadecimal), which is orange. rem This sample program uses hexadecimal for the color values. COLUP0=$28 COLUP1=$00 rem Change the background color with COLUBK. Changing to same rem color as playfield to make playfield invisible. COLUBK=$00 rem f will be used for the frame counter. In Sample Program 5, rem this was y instead of f; but Sample Program 3 uses y for rem the vertical position of player0, so we need to use a rem different variable-- and "f" is a nice little abbreviation rem for "frame"! f=f+1 rem Here is where you define the shape of the player sprite. rem It's limited to 8 pixels wide, but you can make it as rem tall/long as you want. You have to draw the sprite upside rem down; it's flipped when it's displayed onscreen. rem The 'player0' must be indented, the 'end' must NOT be rem indented. rem The frame counter will be used in animating the sprite. rem We'll draw a different picture for the sprite, depending on rem what the value of f is. Generally, the animation should rem cycle through at least 3 different images to give a decent rem illusion of movement. if f=10 then player1: %00111010 %00000000 %00011010 %00010000 %00001010 %00011110 %10001110 %11110110 %00111010 %11011110 %00100100 %00011000 %00101100 %00111100 %00010100 %00111000 end if f=20 then player1: %01110011 %00000001 %00110010 %00010000 %00001010 %00011110 %10001110 %11110110 %00111010 %11011110 %00100100 %00011000 %00101100 %00111100 %00010100 %00111000 end rem This defines the adventure 'light' sprite light player0: %01111110 %11111111 %11111111 %11111111 %11111111 %11111111 %11111111 %11111111 %11111111 %11100111 %11000011 %11000011 %11000011 %11000011 %11000011 %11000011 %11000011 %11000011 %11000011 %11000011 %11000011 %11000011 %11000011 %11100111 %11111111 %11111111 %11111111 %11111111 %11111111 %11111111 %11111111 %01111110 end rem The next statement ensures that f cycles continuously from rem 1 to 30 when we perform the "f=f+1" statement up above. if f=20 then f=0 rem Put the player on the screen at horizontal position x rem (which we initialized to 50). Valid range is 1 to 159. player0x=missile0x-14 rem Put the player on the screen at vertical position y (which rem we initialized to 50). Valid range is 1 to ~90. player0y=missile0y+12 rem This command instructs the program to write the data for rem the display (picture) to the TV screen. drawscreen rem Make the guy move. if joy0right then missile0x=missile0x+1 if joy0left then missile0x=missile0x-1 if joy0up then missile0y=missile0y-1 if joy0down then missile0y=missile0y+1 goto main Quote Link to comment Share on other sites More sharing options...
Retro Lord Posted January 1, 2015 Author Share Posted January 1, 2015 Nevermind, figured out I only had to switch player0 and player1 around and that solved it. Quote Link to comment Share on other sites More sharing options...
