RangerG Posted January 23, 2015 Share Posted January 23, 2015 Here is my issue: Whenever I power up the 5200, the controllers don't completely work. Usually down on the joystick doesn't work. Sometimes, down and the fire buttons don't work. Now, here is how I get it to work. I power the machine off and on and then the joystick will go down. But, sometimes I end up powering it off and on up to four times to get all the functions working, first direction, then fire button, then keypad, etc. It always works eventually, but this can't be good for the system and it must be a symptom of something that needs fixing. But what? This happens on multiple types of controllers, so it is not the joystick or controller (which is what I used to think, as I took them apart and looked for issues). Any help appreciated! Quote Link to comment Share on other sites More sharing options...
RangerG Posted January 29, 2015 Author Share Posted January 29, 2015 I was hoping someone else had this problem before. I literally need to click the power button on and off 5 or 6 time to make sure everything on the controllers will work. Could it be the controller ports, the power button, etc.? Quote Link to comment Share on other sites More sharing options...
+DamonicFury Posted January 29, 2015 Share Posted January 29, 2015 I really don't have any idea why powering the system on and off would help make your controls work better. That said, I can suggest the usual remedies for 5200 controls... 1. Sticks not working, especially in a certain direction. That really sounds like the control pot needs to be calibrated. Check the below thread for instructions: http://atariage.com/forums/topic/181930-my-5200-is-acting-kinda-strange/?p=2280867&hl=calibration%20pot&fromsearch=1&do=findComment&comment=2280867 2. Buttons not working. This may be the single most common problem with the original 5200 joysticks. Perhaps you are already familiar with the tin foil fix for them that is frequently suggested in this forum? But you say this problem occurs on different types of controllers... Do you mean controllers like the Wico and the Competition Pro? I've never heard of problems with the buttons on those, but perhaps you could try swapping the Pokey chip (see the above thread.) If it's not that, perhaps there's a problem with the controller port itself... You could try a 2 player game to check that. Good luck!!! Quote Link to comment Share on other sites More sharing options...
RangerG Posted January 29, 2015 Author Share Posted January 29, 2015 thanks for the tips, I'll start there Quote Link to comment Share on other sites More sharing options...
