STGraves Posted January 24, 2015 Share Posted January 24, 2015 Well I'm currently developping a simple atari game, I want to add a deadscreen, I've added it but i haven't been capableto make it appear after you die on the game, here is the conde, can anyone help me please? rem Generated 1/4/2010 1:48:01 PM by Visual bB Version 1.0.0.548 rem ********************************** rem *<Tinkernut World> * rem *<Shoot the squirrel before he * rem *eats you.> * rem *<admin@tinkernut.com> * rem *<www.tinkernut.com> * rem ********************************** rem Create the dead screen deadscreen playfield: .............XX................. ............XXXX................ .............XX................. .........XXXXXXXXXX............. ........XX........XX............ ........XXXXX.X..XXX............ ........XX.X..X..XXX............ ........XX.X...XX.XX............ ........XX........XX............ ........XX........XX............ ........XX........XX............ end rem Create the title screen opening playfield: .XX.XXX.XX..XXX...XX..X.X.XXX.XX X....X.X....X..X.X..X.X.X.X..X.. .X...X.X.XX.XXX..XXXX.X.X.XX..X. ..X..X.X..X.X.X..X..X.X.X.X....X XX...X..XX..X..X.X..X..X..XXX.XX ................................ ....X...X.XXXX.XXX..X...XXX..... ....X...X.X..X.X..X.X...X..X.... ....X...X.X..X.XX...X...X..X.... ....X.X.X.X..X.X.X..X...X..X.... ....XX.XX.XXXX.X..X.XXX.XXX..... end rem Loop the screen until the spacebar is pressed title COLUBK = $00 COLUPF = $0E drawscreen if joy0fire || joy1fire then goto skiptitle goto title rem This function displays after the title is skipped skiptitle rem Colors COLUPF = $40 COLUBK = $60 COLUP0 = 222 rem Player location player0x = 50 : player0y = 50 player1x = 20 : player1y = 20 rem Score setting and color score = 0 : scorecolor = $F8 rem Missle size and location missile1height=6:missile1y=255 NUSIZ0 = 25 rem Create a variable to keep up with lives a = 5 rem Create the playfield playfield: ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX.XXX..XXX.XX..XX end rem This main function is what loops constantly main rem This is the animation function animate rem This frame variable slows down the animation v = v + 1 rem This code animates the sprites if v = 7 && w = 0 then ax if v = 7 && w = 1 then bx if v = 7 && w = 2 then cx if v = 7 && w = 3 then dx goto nextstep rem These four sprites are different stages of the animation ax v = 0 w = 1 player1: %00011000 %01111110 %01111110 %01111110 %00100100 %11000011 %01000010 %11000011 end goto nextstep bx v = 0 w = 2 player1: %00011000 %01111110 %01111110 %01111110 %00100100 %11000011 %01000010 %11000011 end goto nextstep cx v = 0 w = 3 player1: %00011000 %01111110 %01011010 %01111110 %00100100 %11000011 %01000010 %11000011 end goto nextstep dx v = 0 w = 0 player1: %00011000 %01111110 %01011010 %01111110 %00100100 %11000011 %01000010 %11000011 end goto nextstep rem Create acorn sprite nextstep player0: %01111110 %01000010 %01011010 %11000010 %01100111 %11111110 %01010101 %10010010 end rem check to see if a missile has already been fired checkfire if missile1y>100 then goto skip missile1y = missile1y - 2 : goto draw rem if a missile hasn't been fired, then fire missile skip if joy0fire then missile1y=player0y-2:missile1x=player0x+4 rem Draw output to screen draw drawscreen rem Fix player wraparound bug if player0x < 8 then player0x = 8 if player0x > 150 then player0x = 150 if player0y < 8 then player0y = 8 if player0y > 84 then player0y = 84 rem Have player 1 chase player 2 if player1y < player0y then player1y = player1y + 1 if player1y > player0y then player1y = player1y - 1 if player1x < player0x then player1x = player1x + 1 if player1x > player0x then player1x = player1x - 1 player1x = player1x : player1y = player1y rem Detect missile collision with squirrel if collision(missile1,player1) then score=score+1:player1x=rand/2:player1y=0:missile1y=255:goto pointsound rem Detect squirrel collision with the acorn if collision(player0,player1) then score=score-1:player1x=rand/2:player1y=0:missile1y=255:a=a-1:goto deadsound rem joystick movements if joy0up then player0y = player0y-1 : goto skipmove if joy0down then player0y = player0y+1 : goto skipmove if joy0left then player0x = player0x-1 : goto skipmove if joy0right then player0x = player0x +1 : goto skipmove rem refresh the screen skipmove goto main rem Play point sound pointsound AUDV0 = 5 : AUDC0 = 8 : AUDF0 = 10 p = p + 1 drawscreen if p < 2 then pointsound p = 0 AUDV0 = 0 : AUDC0 = 0 : AUDF0 = 0 goto main rem Play dead sound deadsound AUDV1 = 8 AUDC1 = 6 AUDF1 = 12 p = p + 1 drawscreen if p < 5 then deadsound p = 0 AUDV1 = 0 : AUDC1 = 0 : AUDF1 = 0 if a = 0 then goto deadscreen goto main Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted January 25, 2015 Share Posted January 25, 2015 I think it's because you have the title screen right after the deadscreen. So you're drawing the deadscreen first and then immediately drawing over it with the title screen. Maybe add a loop right after the dead screen to draw the screen and wait for input like you did for the title screen? Quote Link to comment Share on other sites More sharing options...
STGraves Posted January 25, 2015 Author Share Posted January 25, 2015 Thanks let muy try it Quote Link to comment Share on other sites More sharing options...
bogax Posted January 25, 2015 Share Posted January 25, 2015 (edited) here I've set a (lives) right at the beginning then choose the deadscreen or the title based on that (you still need to set it when you begin again after you've run out of lives (sorry I was messing with your code so I don't know what I might have messed up) it would be nice if you used the code tags and/or attach your code rem Generated 1/4/2010 1:48:01 PM by Visual bB Version 1.0.0.548 rem ********************************** rem *<Tinkernut World> * rem *<Shoot the squirrel before he * rem *eats you.> * rem *<admin@tinkernut.com> * rem *<www.tinkernut.com> * rem ********************************** rem Create a variable to keep up with lives a = 5 deadscreen if a then opening rem Create the dead screen playfield: .............XX................. ............XXXX................ .............XX................. .........XXXXXXXXXX............. ........XX........XX............ ........XXXXX.X..XXX............ ........XX.X..X..XXX............ ........XX.X...XX.XX............ ........XX........XX............ ........XX........XX............ ........XX........XX............ end rem added a delay so deadscreen shows rem if your still firing a = 60 delay drawscreen a = a - 1 if a then delay goto title rem Create the title screen opening playfield: .XX.XXX.XX..XXX...XX..X.X.XXX.XX X....X.X....X..X.X..X.X.X.X..X.. .X...X.X.XX.XXX..XXXX.X.X.XX..X. ..X..X.X..X.X.X..X..X.X.X.X....X XX...X..XX..X..X.X..X..X..XXX.XX ................................ ....X...X.XXXX.XXX..X...XXX..... ....X...X.X..X.X..X.X...X..X.... ....X...X.X..X.XX...X...X..X.... ....X.X.X.X..X.X.X..X...X..X.... ....XX.XX.XXXX.X..X.XXX.XXX..... end COLUBK = $00 COLUPF = $0E rem Loop the screen until the spacebar is pressed title drawscreen if !joy0fire && !joy1fire then title rem This function displays after the title is skipped skiptitle rem Colors COLUPF = $40 COLUBK = $60 COLUP0 = 222 rem Player location player0x = 50 : player0y = 50 player1x = 20 : player1y = 20 rem Score setting and color score = 0 : scorecolor = $F8 rem Missle size and location missile1height=6:missile1y=255 NUSIZ0 = 25 rem Create a variable to keep up with lives a = 5 rem Create the playfield playfield: ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX.XXX..XXX.XX..XX end rem Create acorn sprite player0: %01111110 %01000010 %01011010 %11000010 %01100111 %11111110 %01010101 %10010010 end rem This main function is what loops constantly main rem This is the animation function animate rem This frame variable slows down the animation v = v + 1 rem This code animates the sprites if v > 7 then on w gosub ax bx cx dx : v = 0 : w = w + 1 : if w > 3 then w = 0 nextstep rem check to see if a missile has already been fired checkfire if missile1y > 100 then goto skip missile1y = missile1y - 2 : goto draw rem if a missile hasn't been fired, then fire missile skip if joy0fire then missile1y = player0y - 2 : missile1x = player0x + 4 rem Draw output to screen draw drawscreen rem Fix player wraparound bug if player0x < 8 then player0x = 8 if player0x > 150 then player0x = 150 if player0y < 8 then player0y = 8 if player0y > 84 then player0y = 84 rem Have player 1 chase player 2 if player1y < player0y then player1y = player1y + 1 if player1y > player0y then player1y = player1y - 1 if player1x < player0x then player1x = player1x + 1 if player1x > player0x then player1x = player1x - 1 player1x = player1x : player1y = player1y rem Detect missile collision with squirrel if collision(missile1,player1) then score = score + 1 : player1x = rand / 2 : player1y = 0 : missile1y = 255 : goto pointsound rem Detect squirrel collision with the acorn if collision(player0,player1) then score = score - 1 : player1x = rand / 2 : player1y = 0 : missile1y = 255 : a = a - 1 : goto deadsound rem joystick movements if joy0up then player0y = player0y - 1 if joy0down then player0y = player0y + 1 if joy0left then player0x = player0x - 1 if joy0right then player0x = player0x + 1 rem refresh the screen skipmove goto main rem These four sprites are different stages of the animation ax player1: %00011000 %01111110 %01111110 %01111110 %00100100 %11000011 %01000010 %11000011 end return bx player1: %00011000 %01111110 %01111110 %01111110 %00100100 %11000011 %01000010 %11000011 end return cx player1: %00011000 %01111110 %01011010 %01111110 %00100100 %11000011 %01000010 %11000011 end return dx player1: %00011000 %01111110 %01011010 %01111110 %00100100 %11000011 %01000010 %11000011 end return rem Play point sound pointsound AUDV0 = 5 : AUDC0 = 8 : AUDF0 = 10 p = p + 1 drawscreen if p < 2 then pointsound p = 0 AUDV0 = 0 : AUDC0 = 0 : AUDF0 = 0 goto main rem Play dead sound deadsound AUDV1 = 8 AUDC1 = 6 AUDF1 = 12 p = p + 1 drawscreen if p < 5 then deadsound p = 0 AUDV1 = 0 : AUDC1 = 0 : AUDF1 = 0 if a = 0 then goto deadscreen goto main edit: added a delay so that the deadscreen shows if you're still firing Edited January 25, 2015 by bogax 1 Quote Link to comment Share on other sites More sharing options...
STGraves Posted January 26, 2015 Author Share Posted January 26, 2015 Thanks i finally got it to work, it was a matter of making a loop for the screen and to change it from firing to pressing up. Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted January 26, 2015 Share Posted January 26, 2015 Thanks i finally got it to work, it was a matter of making a loop for the screen and to change it from firing to pressing up. Glad to hear you got it working. If you're having problems with the deathscreen being skipped in situations where the player is pressing up when they die, you may need to make the loop ignore the controller input for 30 frames or so to give the player some time to release the joystick/button before proceeding. Another option is to add logic that requires the up button be released and then pressed before proceeding. I hope that makes sense, it's difficult to explain. Quote Link to comment Share on other sites More sharing options...
