Tyler Frisbee Posted January 31, 2015 Share Posted January 31, 2015 I'm trying to program my game so when missile1 hits player0, if player0 is holding the fire button, the missile will bounce in the opposite direction and hit player1. Currently, the missile will deflect the first time you try it, but it will pass through player1 without anything happening, and player1 won't fire any more missiles afterward. I've been staring at and changing this code for hours and its beginning to drive me insane. I don't want to bother anyone, but can anyone spot how I screwed up? I just can't figure it out... if d = 0 then goto checkfire if d = 1 then goto reverse reverse missile1x = missile1x + 2:goto draw checkfire if missile1x>153 then goto skip missile1x = missile1x - 2 : goto draw rem if a missile hasn't been fired, then fire missile skip missile1y=player1y-3:missile1x=player1x-5 if missile1x=11 then missile1y=250 rem---------------------------------------------- rem Draw output to screen draw drawscreen if collision(missile1,player0) && joy0fire then score=score+1:d=1 if collision(missile1,player1) then score=score+1:d=0:player1x=153:player1y=(rand&81)+1:missile1y=255 Hack Attack.bas.bin Hack Attack.bas Quote Link to comment Share on other sites More sharing options...
Mountain King Posted February 1, 2015 Share Posted February 1, 2015 I found that I am able to deflect the missile back at player1. If he is there the missile kills him and he fires again. But if he is not there, no collision happens and the missile continues to the right side of the screen and wraps around to the right in which case it gets stuck and player1 stops shooting. I'm guessing if you put a limit on the missile on the right side, have it reset or something. It may fix the problem. 1 Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted February 1, 2015 Share Posted February 1, 2015 Looks like I fixed one problem: hack_attack_2015y_01m_31d_2035t.bin hack_attack_2015y_01m_31d_2035t.bas I see that you are using rand& with numbers not in the list: randomterrain.com/atari-2600-memories-batari-basic-commands.html#rand I also see that you are using reboot which can screw up random numbers: randomterrain.com/atari-2600-memories-batari-basic-commands.html#reboot 1 Quote Link to comment Share on other sites More sharing options...
Tyler Frisbee Posted February 1, 2015 Author Share Posted February 1, 2015 Looks like I fixed one problem: hack_attack_2015y_01m_31d_2035t.bin hack_attack_2015y_01m_31d_2035t.bas I see that you are using rand& with numbers not in the list: randomterrain.com/atari-2600-memories-batari-basic-commands.html#rand I also see that you are using reboot which can screw up random numbers: randomterrain.com/atari-2600-memories-batari-basic-commands.html#reboot Oops...thats probably it. Apparently I neglected to read the sentence stating that you could only use those numbers with rand&. Thanks for the help everyone! Quote Link to comment Share on other sites More sharing options...
