7800fan Posted March 3, 2015 Share Posted March 3, 2015 After owning it for around 25 years, it finally stopped working. The CD mechanism just won't spin. I'm going under the assumption the lube went bad as there's quite a few web sites on this. Looking on eBay, non working drive can reach $100 and working drive costs almost as much as a working Duo. Why is it that? Duo does not need the system card to boot CD and later Duo handles CD-R while virtually all of Turbo CD and PCE CD are really bad with CD-R (due to them being out before CD-R technology) PS in case lube job fails, is there someone that can fix the drive? Assuming it's not the dreaded cracked gear, I think it needs recap but it's small and complicated for me. Quote Link to comment Share on other sites More sharing options...
7800fan Posted March 3, 2015 Author Share Posted March 3, 2015 I started taking it apart and the first thing I did was to check the gears. It didn't want to turn at first so yeah dried lube. Still hoping it doesn't need recap. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted March 3, 2015 Share Posted March 3, 2015 look around the bases of the cap, does it look wet or like it was wet, if so then you will want to start thinking about a recap Quote Link to comment Share on other sites More sharing options...
7800fan Posted March 3, 2015 Author Share Posted March 3, 2015 I didn't see any obvious sign of wet or leaking cap or discolored or bulging top. However that is just the CD drive. The base unit is a bitch to take a apart, I found a guide on pcenginefx forum, there's lots of solder brade to desolder, lots of cables to disconnect, lots of screws, etc. I think I'll just pay and let someone recap the base. Quote Link to comment Share on other sites More sharing options...
7800fan Posted March 5, 2015 Author Share Posted March 5, 2015 Got white lithium grease, cleaned the old parts, applied the grease, put it back together, spend the next 30 minutes cursing whoever thought of using a tiny locking washer to hold the middle gear in (about the size of pin head). Tested it with a CD game, it worked fine. Still I'll sooner pay someone than to take my CD apart again, it was a major pain in the butt to get all of the 100 or so tiny pieces in the right place without losing one piece or ending up with a leftover. Quote Link to comment Share on other sites More sharing options...
