SoundGammon Posted March 8, 2015 Share Posted March 8, 2015 Yes, that translation seems messed up. The display of the text on the site keeps going past the margin also. It looks like it is supposed to be the manual. What is the connector just above the red led? It looks like a USB port from the top view. From the listing of the one I got: The tester uses 3.7V rechargeable lithium battery (battery model: 14500) powered portable design, but you can use the T-MINIUSB outlet to charge the battery and power the system for a long time in the indoor use of more economical and convenient, eliminating the need always to be replaced battery of economic input! Not sure, but sounds like someone running for a political office! 2 Quote Link to comment Share on other sites More sharing options...
Osgeld Posted March 8, 2015 Share Posted March 8, 2015 (edited) what is the advantage of that over a 20$ meter that does all that and has a shell and proper probes maybe its just me but I would rather have a couple probes instead of a handful of eyelets that will wear out a few dozen uses into it, and fry itself if it gets a drop of water near it heh Edited March 8, 2015 by Osgeld Quote Link to comment Share on other sites More sharing options...
Keatah Posted March 9, 2015 Share Posted March 9, 2015 From the listing of the one I got: The tester uses 3.7V rechargeable lithium battery (battery model: 14500) powered portable design, but you can use the T-MINIUSB outlet to charge the battery and power the system for a long time in the indoor use of more economical and convenient, eliminating the need always to be replaced battery of economic input! Not sure, but sounds like someone running for a political office! Sure does.. I asked the seller a question before buying, and they thought I wanted a refund! And that's all they were fixated on, was trying to satisfy me through ample apologies and refund. They wouldn't give up. Went round and round. It finally stopped when I accepted it. 1 Quote Link to comment Share on other sites More sharing options...
Keatah Posted March 9, 2015 Share Posted March 9, 2015 what is the advantage of that over a 20$ meter that does all that and has a shell and proper probes It's hobbyist & science-project stuff. Not pro-level Fluke or Agilent. You won't feel guilty when you take it apart to mount it in your own casing or custom-whatever-assemblage. But you would if you cannibalized a $200 DMM. Or even a basic $50 meter from HomeDepot. maybe its just me but I would rather have a couple probes instead of a handful of eyelets that will wear out a few dozen uses into it, and fry itself if it gets a drop of water near it heh Obviously. Quote Link to comment Share on other sites More sharing options...
SoundGammon Posted March 9, 2015 Share Posted March 9, 2015 what is the advantage of that over a 20$ meter that does all that and has a shell and proper probes maybe its just me but I would rather have a couple probes instead of a handful of eyelets that will wear out a few dozen uses into it, and fry itself if it gets a drop of water near it heh Hate older meters that you had to do multiple tries to figure out a transistor...is it npn or pnp, which leg is the base/collector/emitter? Just hook this unit up and it tells you what pin is what AND npn or pnp. Don't have to buy another meter to check caps or another meter for inductors...don't plan on using the eyelets-only the probes with clips where there is connect and slip-no connect-do again...and like all my other equipment, I take care of it... Quote Link to comment Share on other sites More sharing options...
SoundGammon Posted March 9, 2015 Share Posted March 9, 2015 Sure does.. I asked the seller a question before buying, and they thought I wanted a refund! And that's all they were fixated on, was trying to satisfy me through ample apologies and refund. They wouldn't give up. Went round and round. It finally stopped when I accepted it. Someone once asked me if I understood Chinese, I said, "Are you kidding? I don't understand their English!" Quote Link to comment Share on other sites More sharing options...
Osgeld Posted March 9, 2015 Share Posted March 9, 2015 Hate older meters that you had to do multiple tries to figure out a transistor...is it npn or pnp, which leg is the base/collector/emitter? Just hook this unit up and it tells you what pin is what AND npn or pnp. Don't have to buy another meter to check caps or another meter for inductors...don't plan on using the eyelets-only the probes with clips where there is connect and slip-no connect-do again...and like all my other equipment, I take care of it... I just use the datasheet and almost all meters now do caps, most do inductance whatever makes you happy though Quote Link to comment Share on other sites More sharing options...
