+SoulBuster Posted March 31, 2015 Share Posted March 31, 2015 (edited) Anyone know where to get one of these? I know, I can build it, but my projects always look like Dr. Frankenstein built them. Is the "15.75 kHz Horizontal sync" a problem? Would an upscaler fix that? Or can someone build one? Link VGA Color Cable This cable allows to connect an Atari running in Med-Low resolution color mode to a VGA/SVGA monitor. The cables use on one side a DIN13 male connector connected to the Atari and on the other side a D-SUB15 male connector connected to the monitor. The Atari is automatically set to Med/Low-resolution mode (pin 4 left open). Note that if you want to hear the sound from the Atari you need an extra audio cable (connected to pin 1) going to an audio connector (e.g. a mini jack or RCA connector). Important notice: This solution only works if your monitor accepts a 15.75 kHz Horizontal sync (see Connecting Modern LCD/CRT Monitors to an Atari for the video signals charateristics). Signal Name Atari DB15 RemarkAudio Out 1 Audio connector Monochrome Detect 4 Open Green 6 to 2 Red 7 to 1 H-Sync 9 to 13 Blue 10 to 3 V-Sync 12to 14 GND 13 to 5+6+7+8+10 Edited March 31, 2015 by SoulBuster Quote Link to comment Share on other sites More sharing options...
Fletch Posted March 31, 2015 Share Posted March 31, 2015 Best Electronics sells them. Quote Link to comment Share on other sites More sharing options...
galax Posted April 1, 2015 Share Posted April 1, 2015 Is the "15.75 kHz Horizontal sync" a problem? Would an upscaler fix that? Yes, the ST's horizontal sync is too slow for most modern monitors, info about compatible LCD monitors here: http://atariage.com/forums/topic/230561-lcd-monitor-that-supports-st-low-res-nec-multisync-lcd-1970vx/ Yes with most modern monitors you'd need to use an upscaler. I can make these cables- it's pretty simple if you don't need a colour/mono switch, a bit more effort if you do. Quote Link to comment Share on other sites More sharing options...
ataricrypt Posted April 29, 2016 Share Posted April 29, 2016 For some reason, I've only just discovered this ... http://coolnovelties.co.uk/coolnovelties/atari-st-video-cables/290-atari-st-to-vga-multi-sync-rgb-colour-monitor-cable.html#/audio_output-with_audio_output :-) Quote Link to comment Share on other sites More sharing options...
galax Posted April 29, 2016 Share Posted April 29, 2016 For some reason, I've only just discovered this ... http://coolnovelties.co.uk/coolnovelties/atari-st-video-cables/290-atari-st-to-vga-multi-sync-rgb-colour-monitor-cable.html#/audio_output-with_audio_output :-) Nice, it's less fiddly to build if you don't need the colour/mono switch. 1 Quote Link to comment Share on other sites More sharing options...
