walter_J64bit Posted June 14, 2015 Share Posted June 14, 2015 (edited) Ok, I've got an AV device that let me use my SC1224 with my A8 but I'm looking for a way I can switch to my STE and back to my A8 with out having to disconnecting cables on the two systems is there a switchbox and where can I get one? Edited June 14, 2015 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
moonlight_mile Posted June 14, 2015 Share Posted June 14, 2015 What A/V device? Pics please. Thanks Quote Link to comment Share on other sites More sharing options...
+wood_jl Posted June 18, 2015 Share Posted June 18, 2015 The only thing I can think of would be to acquire - and modify (if possible) something like the "Monitor Master" from Practical Peripherals. As you probably know, different lines were connected when either color or monochrome were connected. If you hit the button while the system is on (I didn't like doing that), the system would reboot. However, the Monitor Master has the rare 13-pin connectors, and could *possibly* be re-wired and repurposed to switch between 2 computers, with additional cabling. However, it would probably be easier and just as cheap to buy a 2nd SC1224, if you bide your time and wait for a bargain. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted June 19, 2015 Author Share Posted June 19, 2015 I've got the Monitor Master too bad it didn't work like I want. The only use I've ever got out the Monitor Master is that handy audio out, I'd have my old 1040STfm hooked up to a boom box back in the day! Quote Link to comment Share on other sites More sharing options...
Kylev Posted June 21, 2015 Share Posted June 21, 2015 Monitor Master was a god-send for me, back in the day. I had both SC???? and the SM???? (I forget the numbers for the monochrome and color models). I had a number of programs that just looked better in monochrome. Not having to shutdown, unplug the monitor, plug in the other one, and reboot really made life much simpler. Not sure how that device would fit in the scenario of the OP, though. Quote Link to comment Share on other sites More sharing options...
locnar77 Posted June 28, 2015 Share Posted June 28, 2015 I have a monitor master too, and a JVC sc1224 monitor, so i hooked the monitor master backwards to see if it would work, it does on the color side, but no signal on the mono side. (must only uses the basic pinout on that side) Quote Link to comment Share on other sites More sharing options...
