Marius Posted September 5, 2015 Share Posted September 5, 2015 Hi all, Is there a source of DB9 female connectors without those parts left and right from the connector (with the screws). They look like 'ears' and IIRC it is called 'ears' but I'm not sure about that. I want to fix some of my joysticks but the broader DB9 connectors do not fit in my XE computers. Another alternative is buying joystick extention cables and cut those. Thanks M. Quote Link to comment Share on other sites More sharing options...
gozar Posted September 5, 2015 Share Posted September 5, 2015 Check eBay. https://ebay.com/itm/161772233395 Quote Link to comment Share on other sites More sharing options...
Joey Z Posted September 5, 2015 Share Posted September 5, 2015 (edited) Check eBay. https://ebay.com/itm/161772233395 those are male sockets, I think he wanted female plugs. PSA: Once again people, socket or receptacle, and plug, refer to the connector body. Male and female refer to the actual pins themselves. Often, you will have female plugs and male sockets. For example, the SIO port or the joystick port on the actual atari computer or console, is a male receptacle. The connector on the ends of an SIO cable, or a joystick cable, are female plugs. Edited September 5, 2015 by Joey Z 1 Quote Link to comment Share on other sites More sharing options...
gozar Posted September 5, 2015 Share Posted September 5, 2015 Duh, I was reading it as fixing ports on the computer, not joysticks.:-( And the ones I linked to still have the little "ears", but I think they'd probably still work. Quote Link to comment Share on other sites More sharing options...
Marius Posted March 4, 2023 Author Share Posted March 4, 2023 Sorry for bumping my own old thread, but the question is still open for me. Let me be more specific: Joystick cables are vulnerable parts. I think it is not too difficult to replace or repair a joystick cable but at some point it would be nice if I could simply install a fresh new cable on a joystick, even when I have to create the cable myself. But the standard DB9 connectors do have these 'ears' When I would create a joystick cable from a RS232 cable with a female DB9 connector, It won't fit in a 130XE. And it does not fit very nicely in an 800XL as well (although it works). So do these DB9 female connectors exist without the ears? Or is there a trick to remove the metal ears without damaging everything? Or are there any other suggestions? Or is there a source of joystick cables that is not sold out? Quote Link to comment Share on other sites More sharing options...
Rybags Posted March 4, 2023 Share Posted March 4, 2023 I can remember snipping or using a small cutoff wheel years ago to remove them but also remember it looking like arse and having sharp edges as well as causing some deformation of the overall shell. The ones that take ribbon cable are about the same though might be easier to trim if you went that way. I can't recall ever seeing any DIY types that don't have the mounting holes. Fairly sure even the old RS232 cables would usually have the retaining screws with knurled thumbscrews as well. And such things are a rarity in themselves these days. I don't think much equipment at all these days use them, they've gone the way of most of the DB and DE type plugs and the only ones you get are the generic types from electronics suppliers. I wonder though - couldn't you just drill out the pressed part in the hole that holds the metal shield on and just remove the whole thing? 1 Quote Link to comment Share on other sites More sharing options...
Ppyo Posted March 4, 2023 Share Posted March 4, 2023 1 hour ago, Marius said: Sorry for bumping my own old thread, but the question is still open for me. Let me be more specific: Joystick cables are vulnerable parts. I think it is not too difficult to replace or repair a joystick cable but at some point it would be nice if I could simply install a fresh new cable on a joystick, even when I have to create the cable myself. But the standard DB9 connectors do have these 'ears' When I would create a joystick cable from a RS232 cable with a female DB9 connector, It won't fit in a 130XE. And it does not fit very nicely in an 800XL as well (although it works). So do these DB9 female connectors exist without the ears? Or is there a trick to remove the metal ears without damaging everything? Or are there any other suggestions? Or is there a source of joystick cables that is not sold out? You could always use a Dremel tool to cut off the "ears", and to "sand" them off a little, and some solder to seal the cut sides. Done that, works well. 1 Quote Link to comment Share on other sites More sharing options...
cbelcher Posted March 4, 2023 Share Posted March 4, 2023 You can use pliers to bend the "ears" back and forth until the metal fatigues and fractures, then take the entire metal shell off. The blue plastic is in two pieces that can be superglued together and generally has held up fairly well for me. I do this on the edge of projects all the time. 4 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted March 4, 2023 Share Posted March 4, 2023 I use these for joystick extenders, plastic and easy to remove the "ears" https://www.ebay.co.uk/itm/155034889004? that's the female, you will obviously need a male for the other end 2 Quote Link to comment Share on other sites More sharing options...
Marius Posted March 4, 2023 Author Share Posted March 4, 2023 Wow thank you all so much! This is interesting and inspiring! Quote Link to comment Share on other sites More sharing options...
RevEng Posted March 4, 2023 Share Posted March 4, 2023 The holes in the ears is where the two halves are joined together. You can just secure one ear in a vice, drill out the hole in the other ear, and then pry apart the halves with a small screwdriver. Takes less than a minute. 2 Quote Link to comment Share on other sites More sharing options...
