0078265317 Posted September 22, 2015 Share Posted September 22, 2015 http://www.l-com.com/d-sub-db15-y-splitter-adapter-db15m-db15f-db15f Would this work on 5200? I know 5200 has pins so I need a gender changer for the other side. But other than that would this work? I use gender changers on a y cable so that is not an issue. Problem is the extension y cable I have is super long so I want to shorten this. So will this adapter work instead? Quote Link to comment Share on other sites More sharing options...
bohoki Posted September 23, 2015 Share Posted September 23, 2015 what is your intended purpose ? Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 23, 2015 Author Share Posted September 23, 2015 That instead of a y cable. Just shorter cable is too bulky. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 23, 2015 Author Share Posted September 23, 2015 I saw your 16 dollar keypad on ebay for wico. I still have your wico you sold me long time ago on ebay. And I have the masterplay clone low_budget made long ago and sold on ebay also. So a second keypad is probably a repeat. But the masterplay clone doesn't allow the wico probably as it probably expects a digital and wont except an analog. But with a y cable it works great. MP clone keypad on one side and the wico with on the other side. The y is broke off but still 15 to 9 works. So it works with a separate y. But Y is too long. So that adapter might help shorten things but not sure. Quote Link to comment Share on other sites More sharing options...
bohoki Posted September 23, 2015 Share Posted September 23, 2015 (edited) its hard to start ok first off the "5200 wico stick" while it has a 9 pin female end it is not wired any similarity to a 2600 joystick the masterplay uses a 2600 joystick it will use wico 2600 sticks obviously its just the analog wico is a one off design and i think it was a mistake for them to use a 9 pin connector cause it has confused countless others mostly ones with the y cord that comes with the 5200 stick also the wico keypad many thought was a 2600 controller adapter , they think they can use any 2600 stick with it so that was a fiasco but much about the 5200 was a fiasco like people using the first 5200 plugged it into their tin switchbox and then couldnt figure out where to plug the power in as to the y unit you were contemplating if you plug in 2 items that use the joystick portion it will half the resistance of the controllers i would suggest that it has very little use besides the shielded d plugs wont stay put in the deep shell of the 5200 jack as to my keypad with wico adapter i originally intended to just make it a keypad suppliment for my gameport to 5200 adapter but i thought heck for like .60 cents i could throw a wico plug on it and have it double duty but i think that may have confused people as it is still a keypad that plugs into the gameport adapter as to your broken y if you send it back to me with $2 return postage i will fix it i apologize the wire i used was not durable but i was attempting to make these as cheap as i could and what i had was some old used solid cat 5 cable which was intended to run behind the wall and never be touched again Edited September 23, 2015 by bohoki Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 23, 2015 Author Share Posted September 23, 2015 PM me your address. Anyhow my thick y cable works no issues. So weird. No half resistance it seems like. One side mp clone and other size wico. Wico plugged into the Y cable not mp clone so it works fine. But your keypad are you saying it won't work on my 5200 without that pc adapter. I know gender changers work on my 5200 I have used them before. As for the cable I will give you more than 2 dollars. If you can turn it into an adapter. I mean maybe we can shove the ends into small tiny boxes possibly. Like this. http://mvvg.blogspot.com/2015/09/wico-y.html Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 24, 2015 Author Share Posted September 24, 2015 http://mvvg.blogspot.com/2015/09/wico-t-adapter.html Quote Link to comment Share on other sites More sharing options...
0078265317 Posted September 25, 2015 Author Share Posted September 25, 2015 (edited) Or would something like this work. Plug the 15 pin into the atari 5200 and the 9 pin to the wico (with gender changer of course to plug into the wico). Or that pinout may not be correct. Or the 9 pin part is not analog. http://m.ebay.co.uk/itm/121743316750?_mwBanner=1 Edited September 25, 2015 by 0078265317 Quote Link to comment Share on other sites More sharing options...
bohoki Posted September 25, 2015 Share Posted September 25, 2015 you have to contact the seller to see what it does i am not familiar with others schemes Quote Link to comment Share on other sites More sharing options...
