Rick Dangerous Posted January 27, 2016 Share Posted January 27, 2016 So after playing with my 1040STe last night it became apparent pretty quickly that the first thing I will be needing is some more ram. Many of the programs on my Ultrasatan require it. My plan is to eventually send the computer to exxosuk in the UK for "the royal treatment" upgrade service, but for functionality and for use in the meantime, I need RAM now...the 1mb is just not cutting it. The issue is, I can't solder, so I'm wondering if I can upgrade to 4MB myself, and if its a "plug and play" operation... Here is some RAM I found: http://www.ebay.com/itm/Atari-ST-computer-4mb-memory-upgrade-simm-ram-4x-1mb-520-1040-STFM-STE-Mega-NEW-/151932696423?hash=item235fe4f767:g:hKcAAOSw37tWDCrY Does anyone know if this would work, and if not can you recommend an alternative? Has anyone ever done a video or a tutorial, step by step of a 4mb RAM upgrade on the ST? I am generally okay with electronics but need my hand held a little bit with stuff like this. Thanks, and much appreciated!! Quote Link to comment Share on other sites More sharing options...
galax Posted January 27, 2016 Share Posted January 27, 2016 (edited) That should work, it should be as simple as removing the screws, opening the machine, removing all existing SIMMs, and replace with the new ones. No soldering needed, and you don't even need to remove the shielding. Ensure that you are grounded and avoid touching any of the components, and you should be fine. Pretty much the same as doing it on a modern PC or laptop. Your STE will almost certainly have SIMM sockets, which look like this when empty. To remove the SIMM, ease the little plastic clips apart, which should unhook and the memory card will rotate a little and come loose. Don't force it. To insert, line up the bottom of the SIMM and then rotate it into position. It's easier to do than describe. Edited January 27, 2016 by galax 1 Quote Link to comment Share on other sites More sharing options...
Rick Dangerous Posted January 27, 2016 Author Share Posted January 27, 2016 That should work, it should be as simple as removing the screws, opening the machine, removing all existing SIMMs, and replace with the new ones. No soldering needed, and you don't even need to remove the shielding. Ensure that you are grounded and avoid touching any of the components, and you should be fine. Pretty much the same as doing it on a modern PC or laptop. Your STE will almost certainly have SIMM sockets, which look like this when empty. mem-slots1.png To remove the SIMM, ease the little plastic clips apart, which should unhook and the memory card will rotate a little and come loose. Don't force it. To insert, line up the bottom of the SIMM and then rotate it into position. It's easier to do than describe. 001.JPG Awesome, thank you! I will order my 4MB ram kit tonight! The PSU and Processor can wait, but the RAM really needs to happen sooner rather than later...lol 1 Quote Link to comment Share on other sites More sharing options...
Rick Dangerous Posted February 11, 2016 Author Share Posted February 11, 2016 (edited) Mission Successful! The hardest part was taking off the 20 screws to get access. The ram clipped in very easily. Test shows that it was okay. Looks like the computer was last checked over by B&C in 1997! lol. Guess I should look for a 4160STe badge now! Edited February 11, 2016 by travistouchdown 1 Quote Link to comment Share on other sites More sharing options...
Lynxpro Posted February 11, 2016 Share Posted February 11, 2016 What about a 14MB installation? Is there a specific TOS version also required to use that much RAM? Quote Link to comment Share on other sites More sharing options...
Rick Dangerous Posted February 11, 2016 Author Share Posted February 11, 2016 What about a 14MB installation? Is there a specific TOS version also required to use that much RAM? I don't believe there is space for in on an STe, as far as I know only the Falcon and TT can handle that much ram. My understanding is that 4mb is max capacity for STe models. Quote Link to comment Share on other sites More sharing options...
galax Posted February 11, 2016 Share Posted February 11, 2016 (edited) The ST's MMU can only access 4MB of RAM but the 68000's 24-bit address space has room for 16MB (some of which is used by ROM and hardware). The MonSTer board adds 8MB of ALT RAM, which TOS 2.06 and ALT RAM aware software can recognise: http://www.fairlite.co.uk/AtariKit//monster/monster.html 14MB sound like an unmodified Falcon's memory upgrade. Edited February 11, 2016 by galax Quote Link to comment Share on other sites More sharing options...
