Tickled_Pink Posted January 27, 2016 Share Posted January 27, 2016 Just a quick question from a non-Falcon owner (sadly - they're a bit too rich for me). I've noticed that the Falcon uses the DS1287 NVRAM RTC module but many users opt to add the 12887 or even design an entirely different setup altogether. Why is this? There are still stocks of the DS1287 floating around. Is there an issue with the DS1287 that makes Falcon owners jump ship to a different RTC solution? Quote Link to comment Share on other sites More sharing options...
Christos Posted January 27, 2016 Share Posted January 27, 2016 Main problem, you will need to change it again in 10 years. Also people use what is available to them as long as it's compatible. Quote Link to comment Share on other sites More sharing options...
leech Posted January 28, 2016 Share Posted January 28, 2016 Main problem, you will need to change it again in 10 years. Also people use what is available to them as long as it's compatible Could be worse, like the Amigas where they used the barrel batteries that would leak acid after so long and ruin your motherboard. Quote Link to comment Share on other sites More sharing options...
