gozar Posted January 30, 2016 Share Posted January 30, 2016 Back in the late 90s I purchased a bunch of stuff from eBay, on thing being a fellow's 8-bit and ST collection. Among the gems was an Atari PS3000. I've never used it since my SC1224 was fine and the floppy drive in the PS3000 was only single sided. Well, my SC1224 decided to die, and I thought I'd put the PS3000 into service. Well, bad news, I can't find the video cable. Luckily I did find the adapter! Is my only option to make a cable? Or should I just get a Best VGA cable and use a VGA monitor in mono? This is for use on my MegaSTe. I have another SC1224 that's flakey (I think there's a wire loose in the cable because it will show different colors) that I can use on my 1040ST for games. Quote Link to comment Share on other sites More sharing options...
galax Posted February 1, 2016 Share Posted February 1, 2016 I don't know what the connector on the back of the PS3000 looks like so it's hard to say, can you take a photo? Is it a standard ST monitor connector? It's an RGB monitor though, so will only display ST low/medium resolution, not the mono high rez. I doubt Best's colour VGA cable will work with it unless it has a D-15 SVGA connector on the back. Quote Link to comment Share on other sites More sharing options...
gozar Posted February 1, 2016 Author Share Posted February 1, 2016 It's the same 13-pin DIN. I found a Roland guitar cable that I think may work: http://www.ebay.com/itm/391373169443 For $15 I thought I'd take the risk. 1 Quote Link to comment Share on other sites More sharing options...
galax Posted February 1, 2016 Share Posted February 1, 2016 (edited) From what I can find, the Roland cables are wired "1 to 1" (straight-through, pin 1 to pin 1 etc.) for all pins, so that should work. You might want to verify that before plugging it in though. It should be an easy cable to make from some 13-pin DIN plugs, I usually use old VGA cables as the R/G/B pins are quite well shielded. Edited February 1, 2016 by galax Quote Link to comment Share on other sites More sharing options...
gozar Posted February 1, 2016 Author Share Posted February 1, 2016 That was going to be my next route, I just wasn't looking forward to soldering onto a 13 pin DIN... Twice... Quote Link to comment Share on other sites More sharing options...
galax Posted February 1, 2016 Share Posted February 1, 2016 (edited) The ones with solder cups aren't too bad if you fill the cups with solder and tin the wires first. You only need to solder 6 of the wires on each end. Edited February 1, 2016 by galax Quote Link to comment Share on other sites More sharing options...
