walter_J64bit Posted February 26, 2016 Share Posted February 26, 2016 (edited) Can the SC1224 "US" use RGB SCART singals? I want to use my Sega CDX "NTSC" with my SC1224. Edited February 26, 2016 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
galax Posted February 26, 2016 Share Posted February 26, 2016 If your SCART cable carries RGB, and the Sega CDX outputs a 50/60Hz vertical 15kHz horizontal signal (which I think it does), then yes, it should. SCART cables also carry other signals such as composite and component, so it depends on how your cable was built- it may only carry the CDX's composite signal. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted February 26, 2016 Author Share Posted February 26, 2016 If your SCART cable carries RGB, and the Sega CDX outputs a 50/60Hz vertical 15kHz horizontal signal (which I think it does), then yes, it should. SCART cables also carry other signals such as composite and component, so it depends on how your cable was built- it may only carry the CDX's composite signal. I was thinking it could now need to do some homework on RGB outputs 50/60Hz vertical 15kHz horizontal signal. Quote Link to comment Share on other sites More sharing options...
goaltoss Posted February 27, 2016 Share Posted February 27, 2016 (edited) Yep it will work. I've used my CDX on a SC1224 then a Amiga 1080, then moved to XRGB2 and finally settled on a SONY PVM. Hell your close enough I even have a PVM you could have it you wanted to pick it up Edited February 27, 2016 by goaltoss Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted February 27, 2016 Author Share Posted February 27, 2016 Yep it will work. I've used my CDX on a SC1224 then a Amiga 1080, then moved to XRGB2 and finally settled on a SONY PVM. Hell your close enough I even have a PVM you could have it you wanted to pick it up Thanks but my other half would kill me if I get a other pace of hardware but I would like to get the info on using the CDX on a SC1224 I'm going to mod a SCART cable. Quote Link to comment Share on other sites More sharing options...
goaltoss Posted February 27, 2016 Share Posted February 27, 2016 I just matched the pin out from online. RGB Composit Synch an Ground. Some p used caps but my monitor worked perfectly fine with out any caps of resistors on the RGB I got the Sega pinouts from here but you can just route it to the correct pinouts for the sc1224 http://www.sega-16.com/forum/showthread.php?16337-Connecting-a-Genesis-to-a-Commodore-Amiga-1080-using-RGB Quote Link to comment Share on other sites More sharing options...
