dsullo Posted March 7, 2016 Share Posted March 7, 2016 Hello I was able to score a 7800 system to get back into both 2600/7800 gaming. I noticed the picture quality through the standard RF is a little lacking. Somehow I remember it looking better as a child. I was wondering if anyone has invested in a RF Interference Filter and it it makes a difference? http://www.amazon.com/RadioShack-RF-Interference-Filter-1500025/dp/B00LMGM23E Not that its a big investment , but I am looking for an inexpensive solution to get the best quality. Quote Link to comment Share on other sites More sharing options...
supercoupe91 Posted March 7, 2016 Share Posted March 7, 2016 I have used one and and it made absolutely no difference. I would make sure your rf cable is good first. Quote Link to comment Share on other sites More sharing options...
dsullo Posted March 7, 2016 Author Share Posted March 7, 2016 OK the RF cable looks original. I should be able to buy a new one at radio shack, I assume Quote Link to comment Share on other sites More sharing options...
dsullo Posted March 7, 2016 Author Share Posted March 7, 2016 is there a place to buy an RF cable that is recommended? Quote Link to comment Share on other sites More sharing options...
Ransom Posted March 7, 2016 Share Posted March 7, 2016 I've had the best luck with shielded cables. Since the RF cable connector is basically an RCA plug, I've bought shielded composite video cables and the like. But you have to be careful they'll fit into wherever the connector is located -- sometimes they're in a tight space. I don't recall about the 7800 specifically (I use a composite mod with my these days), but I recall seeing good improvement with a shielded cable when used with my Intellivision. Quote Link to comment Share on other sites More sharing options...
dsullo Posted March 7, 2016 Author Share Posted March 7, 2016 Ok Thank you Quote Link to comment Share on other sites More sharing options...
+GoldenWheels Posted March 7, 2016 Share Posted March 7, 2016 With ALL my RF systems, I've had better luck using some good shielded RG6 and putting an f type converter (below) on that for the system end. My picture immediately had less static and was less prone to being fussy by position of the cord (that is, it didn't seem to matter much any more if the cable moved/got jiggled). To be fair though, the composites I put this method up against were all "from the box" in my workshop. I don't think any of them were advertised as shielded, they were just typical RCAs. 1 Quote Link to comment Share on other sites More sharing options...
Ransom Posted March 7, 2016 Share Posted March 7, 2016 Yeah, that method would work great, too. It's basically the same as what I do, just using a different cable type (I use the F-Type to RCA converter; I should have mentioned that above -- much better than any switch box!). Quote Link to comment Share on other sites More sharing options...
dsullo Posted March 7, 2016 Author Share Posted March 7, 2016 I only use one of the F type to RCA to connect into the TV. Maybe I should use one from the system to? Quote Link to comment Share on other sites More sharing options...
Ransom Posted March 7, 2016 Share Posted March 7, 2016 If you're using RCA-type cables, you don't need to use a converter at the system. Quote Link to comment Share on other sites More sharing options...
7800fan Posted March 7, 2016 Share Posted March 7, 2016 For a quick and cheap solution, get male RCA (has pins) to female F (has hole) and use a decent cable with F-type at both end to a TV or good quality RF switch box. Leave out the old RCA cable. Modern basic cable are cheaply made, and the good quality cable often comes bundled with multiple connectors like composite and 2 audio or 3 component. Don't need 3 and no need to waste $20+ for 3 cables that you won't use all. Quote Link to comment Share on other sites More sharing options...
Tartfox Posted March 8, 2016 Share Posted March 8, 2016 (edited) I can definitely vouch for the shielded cables as they do provide better video quality in comparison to the RCA video cable + RF TV connector (at least for me). The one I use comes with a EMI RFI noise filter attached to prevent RFI and EMI interference to give you better audio and picture quality. Have a look here, it's probably the best quality you'll get using RF route- http://www.ebay.com/itm/ATARI-2600-JUNIOR-RF-CABLE-HIGH-PERFORMANCE-FULLY-SHIELDED-GROUNDED-NEW-/201496432385?_trksid=p2047675.l2557&ssPageName=STRK%3AMEBIDX%3AIT&nma=true&si=IejvkKLMjR%252Bkq5duYzBhmrXG7Mo%253D&orig_cvip=true&rt=nc *Note*- even though it's sold out, you can at least have a look at the cable to see what it looks like, plus the seller appears to have the same cord for the Commodore 64 for sale. You can always email them to ensure that it'll be compatible with the 7800 too. Edited March 8, 2016 by Tartfox 1 Quote Link to comment Share on other sites More sharing options...
imstarryeyed Posted March 9, 2016 Share Posted March 9, 2016 I use snap on Ferrite connectors. Snap a tight fitted ferrite on the cord near the console or near the TV side and I notice a good improvement. I did have to try out a few RCA cables as some are made better than others. The nice thing about a ferrite is that since it snaps on its not a problem to find a proper cable. I would say a snap on ferrite can improve your picture up to 25%. Quote Link to comment Share on other sites More sharing options...
dsullo Posted March 16, 2016 Author Share Posted March 16, 2016 are the original NES cables (the colored ones) shielded? Quote Link to comment Share on other sites More sharing options...
