scroll1 Posted March 23, 2016 Share Posted March 23, 2016 Hi, I wonder if anyone can tell me what this icon means. I have a 1040STE 1MB ram and this image appears at a boot screen just before going to the desktop. Once it starts it seems to run fine. it displays for a few seconds. any help explaining what the icon means would be helpful. thanks, Wayne Quote Link to comment Share on other sites More sharing options...
Tillek Posted March 23, 2016 Share Posted March 23, 2016 Do you have a disk in the drive when booting? Not something I've ever seen or heard of from TOS. Quote Link to comment Share on other sites More sharing options...
David Baldwin Posted March 23, 2016 Share Posted March 23, 2016 maybe its a old boot virus joke look for something that might say cockroach in startup or something. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted March 23, 2016 Share Posted March 23, 2016 It could mean: no bug - what could be actually message that no virus in bootsector. Post image of that floppy, pls. Quote Link to comment Share on other sites More sharing options...
scroll1 Posted March 23, 2016 Author Share Posted March 23, 2016 Thanks for the replies. I haven't had s chance to get back in front of the machine. The boot disk is a copy of the U.K. Language disk. I formatted a new disk and then made a copy because the original disk was starting to give me errors. I'll check the all the disks and even try booting with a formatted blank disk in the drive to see if the symbol still appears and post my findings over the next few days. cheers, Wayne Quote Link to comment Share on other sites More sharing options...
scroll1 Posted March 26, 2016 Author Share Posted March 26, 2016 Hi, I've attached a .st image of the Language disk. I hope it helps, I'm not sure how to look for hidden files on the disk. ... and I hope the imaging system worked it is contained within a zip file (I did it in a linux VM using dd ) cheers, Wayne UKLangDisk.zip Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted March 26, 2016 Share Posted March 26, 2016 I looked it - it's as expected bootsector code, in purpose to inform user that some virus was not installed there - then user will not see it anymore - because virus would overwrite it. But ST image you posted boots not - bootsector checksum is not OK, it is $1235 instead $1234 . Maybe dd corrected something in bootsector ? Quote Link to comment Share on other sites More sharing options...
scroll1 Posted March 26, 2016 Author Share Posted March 26, 2016 Thanks Dragonstomper for the info ... The original disk is giving me errors trying to read it in the machine, the copied disk was done on the atari. I found another UK language disk image online, but when I copied the image under linux using dd to a floppy, no of the files show up on the atari even though I can see them listed on the linux machine ... In the end, I'm assuming that the boot sector virus checker is not a problem for me, so I guess I'll continue using it for the time being. thanks for your help Quote Link to comment Share on other sites More sharing options...
scroll1 Posted March 27, 2016 Author Share Posted March 27, 2016 ... actually, it seems I'm having trouble writing .st files back to floppies under Linux . The command seems to write the image file, and when I look at the contents of the disk under Linux all the files are there, but when I put the disk in the Atari it shows a blank disk, no files. Any ideas? Thanks Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted March 27, 2016 Share Posted March 27, 2016 Most likely floppy drives in your Atari and PC does not match - head align may differ. I recommend to format floppy on Atari - to DS, and then copy files on it under Linux. That should be more reliable. And some head cleaning of drives could help too. Quote Link to comment Share on other sites More sharing options...
