Shift838 Posted April 7, 2016 Share Posted April 7, 2016 Ok, So I got my MiST in yesterday and got it loaded with the Atari ST cores and images. I got a USB to serial like this : HERE I know it works as I had it working just clipping the pins. But I think my color blindness got the better of me and when I soldered it it's a no go. All connects are good. I am trying to connect a UDS1100 device up to it. Has anyone done this with the MiST and possibly has the pinouts that I can use to create a cable? I thought the pin outs were mapped to the below, but i must have mapped them wrong as now I cannot send AT commands. DB9 DB25 ---------------------- 1 ------> 8 2 -----> 3 3 -----> 2 4 -----> 20 5 -----> 7 6 -----> 6 7 -----> 4 8 -----> 5 9 -----> 22 Quote Link to comment Share on other sites More sharing options...
galax Posted April 7, 2016 Share Posted April 7, 2016 Are you trying to use the MiST's support for USB to ethernet, by going USB->Serial DB9, DB9->DB25, and DB25 Serial->ethernet? Several places that could go wrong: you could try the whole thing with a PC first to check that it's wired up correctly. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted April 7, 2016 Author Share Posted April 7, 2016 Are you trying to use the MiST's support for USB to ethernet, by going USB->Serial DB9, DB9->DB25, and DB25 Serial->ethernet? Several places that could go wrong: you could try the whole thing with a PC first to check that it's wired up correctly. i have hooked up a USB to Serial to the USB port on the MiST then of course a 9pin serial female from the USB serial connection to the a 25 pin male on the UDS device. I know the mist system is setup for serial IO in the system settings. in the terminal program I have made sure its set to 'SERIAL1'. as I said I saw it working before I had the pins soldered they were just push on pins, but I must have wrote them down wrong. I thought, correct me if I am wrong, but the ATARI core on the Mist will use a standard serial cable. I do have a DLINK hub e-100, if there was a terminal I could use to make telent connections to BBS for transfers, etc would be great too. Quote Link to comment Share on other sites More sharing options...
bugs Posted April 7, 2016 Share Posted April 7, 2016 (edited) *deleted* Edited April 7, 2016 by bugs Quote Link to comment Share on other sites More sharing options...
