Panther Posted April 10, 2016 Share Posted April 10, 2016 (edited) I decided to upgrade a 400 sitting here just for the heck of it. I found two versions, one by Claus Buchholz, and another one that actually appeared to be closer to the factory 48K upgrade as far as motherboard modifications. I decided to use the version by Claus. The memory card mods were quite straightforward: The motherboard changes were a bit more work, but not too bad: Success: Thank you, Claus. Edited April 10, 2016 by Panther 3 Quote Link to comment Share on other sites More sharing options...
J.Ivy Posted April 10, 2016 Share Posted April 10, 2016 Very cool. Is modding the motherboard the only way that you can use this much ram? Quote Link to comment Share on other sites More sharing options...
Panther Posted April 10, 2016 Author Share Posted April 10, 2016 Yes, since without mods the 400 and 800 can only handle up to 32K per memory slot, and the 400 has only one memory slot. Quote Link to comment Share on other sites More sharing options...
ACML Posted April 10, 2016 Share Posted April 10, 2016 (edited) Yes, since without mods the 400 and 800 can only handle up to 32K per memory slot, and the 400 has only one memory slot. Wow! The mods look like it's not too extensive. Can you post the design schematics? I just happen to have 8 4164s lying around. Edited April 10, 2016 by ACML Quote Link to comment Share on other sites More sharing options...
ClausB Posted April 10, 2016 Share Posted April 10, 2016 Nice work, Panther. Here's the article: http://atariage.com/forums/topic/123207-expanding-the-400/?do=findComment&comment=1488304 Quote Link to comment Share on other sites More sharing options...
Panther Posted April 11, 2016 Author Share Posted April 11, 2016 Thanks, I assembled those into a .pdf for easier storage. Atari 400 48K Upgrade.pdf 2 Quote Link to comment Share on other sites More sharing options...
Panther Posted May 8, 2016 Author Share Posted May 8, 2016 For a certain person getting ready to perform this upgrade, here are some photos of the 74LS02 and wiring without the shrink tubing over it. Note that I did not use a socket and opted to wire directly to the chip. I also removed the unused pins and trimmed the remaining leads. 2 Quote Link to comment Share on other sites More sharing options...
Marius Posted May 8, 2016 Share Posted May 8, 2016 Some time ago i did this too but i experienced issues with atarimax 8mbit carts. Other carts did not have issues. Do you have those issues too? Quote Link to comment Share on other sites More sharing options...
Panther Posted May 8, 2016 Author Share Posted May 8, 2016 Unfortunately, I barely did more than see if the memory showed up. This 400 doesn't really get used at all. I'll hook it up sometime and test things more thoroughly. Quote Link to comment Share on other sites More sharing options...
KLund1 Posted May 8, 2016 Share Posted May 8, 2016 Panther, Thanks a lot for the additional photos. Very, very helpful !!!!! Quote Link to comment Share on other sites More sharing options...
TechCowboy Posted June 22, 2017 Share Posted June 22, 2017 Unfortunately, I barely did more than see if the memory showed up. This 400 doesn't really get used at all. I'll hook it up sometime and test things more thoroughly. I see this was quite some time ago Moonsweeper; did you ever do any testing? Quote Link to comment Share on other sites More sharing options...
Awch Posted June 22, 2017 Share Posted June 22, 2017 I see this was quite some time ago Moonsweeper; did you ever do any testing? Seconded. I've got the chips and am looking to upgrade my 400 soon. Thanks for any help! Quote Link to comment Share on other sites More sharing options...
