TheMontezuma Posted May 20, 2020 Share Posted May 20, 2020 I flashed the file from: http://www.64kib.com/autobuild/20191111/eclaireXL_ITX/build_A2EBAv3rom/output_files/ Quote Link to comment Share on other sites More sharing options...
foft Posted May 20, 2020 Share Posted May 20, 2020 Yes this is bug, I think dvi works. Quote Link to comment Share on other sites More sharing options...
TheMontezuma Posted May 20, 2020 Share Posted May 20, 2020 I rolled back to v35 (http://www.64kib.com/autobuild/20190719/eclaireXL_ITX/) and f9 (reset) works again. Now looking forward for v38 Quote Link to comment Share on other sites More sharing options...
foft Posted May 20, 2020 Share Posted May 20, 2020 Ah good to know I broke that between v35 and v37. Thanks. Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted May 20, 2020 Share Posted May 20, 2020 My Eclaire and Eclaire mini are both eagerly awaiting v38... 2 Quote Link to comment Share on other sites More sharing options...
bocianu Posted May 26, 2020 Share Posted May 26, 2020 (edited) It looks like Eclaire is not reacting to signals PROCEED and INTERRUPT on SIO pins. I'm heavily testing it with #FujiNet interface, and I wrote a piece of code that is supposed to wait for interrupts incoming from the device, and it works like a charm on real hardware, but it hangs on Eclaire in the point of waiting for interrupt. I did this test on both pins - no success. Is it a known issue? Or maybe it just my unit? Edited May 26, 2020 by bocianu typo Quote Link to comment Share on other sites More sharing options...
+David_P Posted May 26, 2020 Share Posted May 26, 2020 #FujiNet is one of the first hardware items I know of that uses PROCEED and INTERRUPT; it may be that they are not currently in the Eclaire design. (Only other item I know of is the Atari Zucchini from ANALOG Computing from issue 59ff - see https://www.atarimagazines.com/analog/issue59/bits_pieces.php) Quote Link to comment Share on other sites More sharing options...
bocianu Posted May 26, 2020 Share Posted May 26, 2020 10 minutes ago, David_P said: #FujiNet is one of the first hardware items I know of that uses PROCEED and INTERRUPT; it may be that they are not currently in the Eclaire design. I would be sad if it were true. Quote Link to comment Share on other sites More sharing options...
StickJock Posted May 26, 2020 Share Posted May 26, 2020 The Zucchini! I built one of those back in the late 80s. IIRC, there was some problem with mine where it looked like one of the output pins (I think - it's been over 30 years) was inverted, so it never worked. I never did fix it, nor debug it enough to figure out if it was a software issue or a hardware issue. I remember thinking that if i had the source code, I could easily have inverted the signal in the code to make it work. 1 Quote Link to comment Share on other sites More sharing options...
santosp Posted May 26, 2020 Author Share Posted May 26, 2020 I am sure that foft will reply here about this. Quote Link to comment Share on other sites More sharing options...
venom4728a Posted May 27, 2020 Share Posted May 27, 2020 Is there a how to document on updating the firmware and or Software on the Eclair XL? I have the single board Eclaire, getting the keyboard lock up after being powered on for awhile also, many times the system does not recognize that a disk change has been made. I noticed it alot using "the Print Shop" by Broderbund. Insert Side A and boot, When it asks for Side B, I would go and change the Atr/x to the side B image but the software keeps asking for side b. Hit Return 10 times then it proceeds. Just want to update to the latest stable release. I love the Eclair XL, so nice and compact!! Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted May 27, 2020 Share Posted May 27, 2020 1 hour ago, venom4728a said: Is there a how to document on updating the firmware and or Software on the Eclair XL? Read from here up to post #82 of that thread. Quote Link to comment Share on other sites More sharing options...
foft Posted May 27, 2020 Share Posted May 27, 2020 There is a fix for the usb one http://www.64kib.com/redmine/projects/eclairexl/wiki Quote Link to comment Share on other sites More sharing options...
bocianu Posted May 27, 2020 Share Posted May 27, 2020 hello foft, have you seen post #106? Quote Link to comment Share on other sites More sharing options...
foft Posted May 27, 2020 Share Posted May 27, 2020 It’s theoretically supported but not sure anything is using is so there is perhaps a mistake on the vhdl. Do you have some test code? Quote Link to comment Share on other sites More sharing options...
bocianu Posted May 27, 2020 Share Posted May 27, 2020 yes, but this code uses #FujiNet peripherial, to put signal slope on PROCEED pin: https://gitlab.com/bocianu/fujinet-udp-shoutbox I will prepare something simplier for You, gimmie 10 minutes Quote Link to comment Share on other sites More sharing options...
bocianu Posted May 27, 2020 Share Posted May 27, 2020 siofix.passiofix.xex This piece of code will display messages on screen, when it will detect signal slope on PROCEED and INTERRUPT pins. I hope it will help! Quote Link to comment Share on other sites More sharing options...
foft Posted May 27, 2020 Share Posted May 27, 2020 Thanks I’ll give that a spin tonight. 3 Quote Link to comment Share on other sites More sharing options...
mozzwald Posted May 27, 2020 Share Posted May 27, 2020 Not sure if this would be an issue regarding the FujiNet and eclaire. The FujiNet high output is 3.3V. Is the fpga expecting a higher voltage? Quote Link to comment Share on other sites More sharing options...
foft Posted May 27, 2020 Share Posted May 27, 2020 The fpga is 3.3v based lvttl. So 2v is the high input threshold. http://www.interfacebus.com/voltage_LV_threshold.html For output the fpga pin is either low or high impedance, with a pull up to 5V on the other side of a level converting fet switch. 1 Quote Link to comment Share on other sites More sharing options...
foft Posted May 27, 2020 Share Posted May 27, 2020 6 hours ago, foft said: Thanks I’ll give that a spin tonight. Confirmed that the test app works on my 600XL and not the EclaireXL, I'll investigate further. 7 Quote Link to comment Share on other sites More sharing options...
venom4728a Posted May 27, 2020 Share Posted May 27, 2020 17 hours ago, DjayBee said: Read from here up to post #82 of that thread. Thank you, that was a very easy update to make. I went from v24 to V37. 3 Quote Link to comment Share on other sites More sharing options...
TheMontezuma Posted May 28, 2020 Share Posted May 28, 2020 15 hours ago, venom4728a said: Thank you, that was a very easy update to make. I went from v24 to V37. Do you observe any issues with v37 when pressing F9 (normal reset)? Quote Link to comment Share on other sites More sharing options...
venom4728a Posted May 28, 2020 Share Posted May 28, 2020 7 hours ago, TheMontezuma said: Do you observe any issues with v37 when pressing F9 (normal reset)? I have not used the Eclaire Xl since the update. I will try it out tomorrow. Quote Link to comment Share on other sites More sharing options...
venom4728a Posted May 28, 2020 Share Posted May 28, 2020 (edited) On 5/20/2020 at 7:43 AM, santosp said: This is the initial firmware which I shipped in that. v35_eba2_v3.1.rar 791.62 kB · 2 downloads I just updated to v37 Core, from V24 that the Eclaire XL shipped with, should I also update the Firmware? What is the latest Firmware and how do I find out what I have? Edited May 28, 2020 by venom4728a Quote Link to comment Share on other sites More sharing options...
