icemanxp300 Posted March 30, 2017 Share Posted March 30, 2017 So I got a 32x in a few weeks back but it was system and a/c only. I grabbed my link cable and tested it and it worked. So I went on ebay looking for replacements and found some from China for $2.26 each. So today I got them in and they look good. I fired it up and bam works like a charm until you go to power off the genesis (model 2). It would not power off LOL. I was like wtf seriously? So I unplugged the genesis but not the 32x and it still ran with the a/c unplugged from the Genesis LOL. Well I had noticed the aftermarket link cable had an extra pin that the original did not. After about a 30 second Google search I found multiple threads as to how that pin shorts the 5V rails. So I used a dremel and cut that pin off, one side only (kind of redundant to do both ends). I then powered it on and it worked properly this time. The genesis shuts off when it should. So if you want a cheap replacement just know you need to cut a pin for it to work properly. I'm still on the fence on what feedback should be given as in my opinion this item is defective and not made for a 32x link cable. I took pictures to show the difference and pin that needs to be cut. http://www.ebay.com/itm/401223816825?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT ... 2 Quote Link to comment Share on other sites More sharing options...
phoenixdownita Posted March 30, 2017 Share Posted March 30, 2017 Thanks for sharing. If I may the picture before the "dremmel-action" is a little blurry. I know that unfortunately you can't go back in time and take a better one, just noticing. In any case the last picture shows exactly what to do. At <2.5$ they are really cheap!!!! Quote Link to comment Share on other sites More sharing options...
Austin Posted March 30, 2017 Share Posted March 30, 2017 Interesting.. Good to know! Quote Link to comment Share on other sites More sharing options...
icemanxp300 Posted March 30, 2017 Author Share Posted March 30, 2017 Thanks for sharing. If I may the picture before the "dremmel-action" is a little blurry. I know that unfortunately you can't go back in time and take a better one, just noticing. In any case the last picture shows exactly what to do. At <2.5$ they are really cheap!!!! I know it was blurry but figured it didn't matter much anyhow as the last picture is the same just after the pin is cut down. So I didn't bother retaking it. I did take this new one just now because the seller wants me to send them a picture so they can confirm this. Kind of irritates me they can't figure it out on their own. A simple google search shows what an original looks like and they obviously can look at theirs. This is a clearer image. ... Quote Link to comment Share on other sites More sharing options...
Jeremy Popp Posted March 30, 2017 Share Posted March 30, 2017 Funny you posted this, I ran into this situation just a few weeks ago and had to do the same thing. At least it was cheap, I left positive feedback, but made sure to mention it in the feedback: "Works, However all 9 pins are connected. I cut the 5v pin as precautionary" Quote Link to comment Share on other sites More sharing options...
