rapoza609 Posted April 16, 2017 Share Posted April 16, 2017 So a while back I installed an AV on my colecovision. Recently I started getting a green screen sometime accompanied by a tone of some sort. Usually the games play but in that green shaded screen. If I loosen the casing it would go away. Not sure what the issue is. I rechecked all the soldering points and everything is secure. Any idea what the issue is? Quote Link to comment Share on other sites More sharing options...
the_crayon_king Posted May 21, 2017 Share Posted May 21, 2017 So a while back I installed an AV on my colecovision. Recently I started getting a green screen sometime accompanied by a tone of some sort. Usually the games play but in that green shaded screen. If I loosen the casing it would go away. Not sure what the issue is. I rechecked all the soldering points and everything is secure. Any idea what the issue is? Sounds like something is shorting to the ground plate. Either find what it is and fix it or just leave the plate off. Quote Link to comment Share on other sites More sharing options...
rednakes1 Posted June 8, 2017 Share Posted June 8, 2017 Did you manage to solve the issue? Did you put the metal lid for the RF box back on after modding? You might have shorted one of your wires or components with the lid. Quote Link to comment Share on other sites More sharing options...
