RevEng Posted April 7, 2021 Share Posted April 7, 2021 How about Mame - does it do the same? Quote Link to comment Share on other sites More sharing options...
Atari Nut Posted April 7, 2021 Share Posted April 7, 2021 1 hour ago, RevEng said: How about Mame - does it do the same? No actually. MAME uses about 4% CPU. Quote Link to comment Share on other sites More sharing options...
RevEng Posted April 7, 2021 Share Posted April 7, 2021 Interesting. I think we'll have to do some investigation for the next release, playing with target and compilers and such, but I'm pretty tied up with projects, so it probably won't be soon. Quote Link to comment Share on other sites More sharing options...
Atari Nut Posted April 7, 2021 Share Posted April 7, 2021 3 minutes ago, RevEng said: Interesting. I think we'll have to do some investigation for the next release, playing with target and compilers and such, but I'm pretty tied up with projects, so it probably won't be soon. No problem. Thank you for looking into it. Quote Link to comment Share on other sites More sharing options...
+Propane13 Posted April 11, 2021 Share Posted April 11, 2021 Random question. How accurate is the a7800 emulator? Specifically, if a game has too many DL's in its graphics that real hardware wouldn't be able to display them all, would the emulator follow suit, or would it display those extra graphics? Just checking expectations since I haven't played with newer emulator versions in a while. I figure I should read up a bit. 1 Quote Link to comment Share on other sites More sharing options...
+mksmith Posted April 11, 2021 Share Posted April 11, 2021 5 hours ago, Propane13 said: Random question. How accurate is the a7800 emulator? Specifically, if a game has too many DL's in its graphics that real hardware wouldn't be able to display them all, would the emulator follow suit, or would it display those extra graphics? Just checking expectations since I haven't played with newer emulator versions in a while. I figure I should read up a bit. Mike can probably answer more scientifically!! than me but whilst developing I've found that side of it very accurate showing even partial images as it would. It's definitely very helpful when you get very close to the DL limits. 2 1 Quote Link to comment Share on other sites More sharing options...
RevEng Posted April 11, 2021 Share Posted April 11, 2021 Yep, it's implements DMA limits, and it's pretty faithful compared to real hardware. 2 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted April 11, 2021 Share Posted April 11, 2021 Regarding CPU usage, I find A7800 to be very resource-heavy as well. Part of my personal problem is that Win10 always seems to want to try to run it with the integrated Intel motherboard graphics chip rather than my 1070 GTX (my system is 5 years old). I had to go into the Nvidia Control Panel and force it to use the discrete card, but even so, it seems to use more processor and GPU than it ought to. Quote Link to comment Share on other sites More sharing options...
Bradsco Posted May 6, 2021 Share Posted May 6, 2021 Trying to launch the macOS version of a7800 with arguments: a7800 a7800 -cart1 xm -cart2 filename.a78 results in: unknown option: -cart2 Launching it with just a cart works as expected. I'm using what should be the latest version a7800-osx-v4.0. Am I missing anything? 1 Quote Link to comment Share on other sites More sharing options...
RevEng Posted May 6, 2021 Share Posted May 6, 2021 Make sure your .a7800/a7800.ini file has a "hashpath" entry that's pointing at the provided hash directory from the a7800 package. Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 8, 2021 Share Posted November 8, 2021 ok. I've been getting off my lazy butt to try out some recent Atari 7800 homebrew which does not run too well under older emulators *cough*emu7800*cough*cough*. Anywho... I've noticed that a7800 will let me select an .a78 file and it will load it just hunky dory. Which leaves me the impression it reads the header information. Does the main MAME fork which I know you guys split from support .a78 files? I'm just curious. I've been trying the ridiculous task of editing the mame a7800.xml file so it will load some of these said games and it is a bit of a pain in the neck to say the least. The only game I've had luck with so far is the Popeye Demo. Thank you Quote Link to comment Share on other sites More sharing options...
jstrotha0975 Posted November 8, 2021 Share Posted November 8, 2021 1 hour ago, Shannon said: ok. I've been getting off my lazy butt to try out some recent Atari 7800 homebrew which does not run too well under older emulators *cough*emu7800*cough*cough*. Anywho... I've noticed that a7800 will let me select an .a78 file and it will load it just hunky dory. Which leaves me the impression it reads the header information. Does the main MAME fork which I know you guys split from support .a78 files? I'm just curious. I've been trying the ridiculous task of editing the mame a7800.xml file so it will load some of these said games and it is a bit of a pain in the neck to say the least. The only game I've had luck with so far is the Popeye Demo. Thank you Not an expert, I've been using a7800 for about a month now and it works great. AFAIK is only uses .a78 files, which is convenient for me because I just bought an og 7800 and a concerto cart and can just transfer the roms to it. 2 Quote Link to comment Share on other sites More sharing options...
RevEng Posted November 8, 2021 Share Posted November 8, 2021 5 hours ago, Shannon said: Anywho... I've noticed that a7800 will let me select an .a78 file and it will load it just hunky dory. Which leaves me the impression it reads the header information. Does the main MAME fork which I know you guys split from support .a78 files? Yep. a78 header parsing has been in there well before the MESS->MAME update, let alone the a7800 fork. I've been using stand-alone a78 files exclusively for a very long time, since it suits my CLI dev style. 1 Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 8, 2021 Share Posted November 8, 2021 2 hours ago, RevEng said: Yep. a78 header parsing has been in there well before the MESS->MAME update, let alone the a7800 fork. I've been using stand-alone a78 files exclusively for a very long time, since it suits my CLI dev style. I did some testing ( I do it on my Laptop to reduce head aches to a minimum ) and I have discovered that with retroarch mame current I can hit tab and manually load an .a78 file through the menu system. Unfortunately I cannot do that on my xbox one without it locking up. I do have a question though when MAME loads an a.78 file is it possible for it to select options incompatible with the ones listedin a78_carts.h? Is there a way I can tell which cart "slot" or setting MAME is using when it loads an .a78 file? Thanks Quote Link to comment Share on other sites More sharing options...
RevEng Posted November 8, 2021 Share Posted November 8, 2021 6 minutes ago, Shannon said: I do have a question though when MAME loads an a.78 file is it possible for it to select options incompatible with the ones listedin a78_carts.h? Is there a way I can tell which cart "slot" or setting MAME is using when it loads an .a78 file? In a78_slot.cpp, the a78_cart_slot_device::call_load member function validates the header bits and sets hardware, so no, there shouldn't be incompatible options being set. I'm not really a MAME slot guru, but if you check out a7800.cpp, it uses "m_cart->get_cart_type()" to test which hardware is in the slot. Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 8, 2021 Share Posted November 8, 2021 38 minutes ago, RevEng said: In a78_slot.cpp, the a78_cart_slot_device::call_load member function validates the header bits and sets hardware, so no, there shouldn't be incompatible options being set. I'm not really a MAME slot guru, but if you check out a7800.cpp, it uses "m_cart->get_cart_type()" to test which hardware is in the slot. ok. Well thanks for helping. I determined that I can look at "slot devices" and it will tell me the type of mapper using when I load an .a78 file. So I can now plug that into the XML file without having to guess. The only downside is any value that uses SRAM seems to crash retroarch even though the game loads fine through the MAME load cartridge menu. So that is a bit of a downer. But at least I have a starting point. I'll probably have to report the SRAM bug on the retrorch issues section. 1 Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 9, 2021 Share Posted November 9, 2021 Well I've gotten pretty good at adding titles to the A7800.XML file so they will load on the retroarch mame "current" version. I'm currently working my way through a bunch of homebrew titles. If only I could figure out a way to have a game "autoload" the XM in cart slot 1 and the game in cart slot 2 for those handful of games that need the XM. I did figure out an awkward way of loading the XM and then a XM game can be selected from the software list. More experimentation definitely needed! Quote Link to comment Share on other sites More sharing options...
Trebor Posted November 9, 2021 Author Share Posted November 9, 2021 25 minutes ago, Shannon said: Well I've gotten pretty good at adding titles to the A7800.XML file so they will load on the retroarch mame "current" version. I'm currently working my way through a bunch of homebrew titles. If only I could figure out a way to have a game "autoload" the XM in cart slot 1 and the game in cart slot 2 for those handful of games that need the XM. I did figure out an awkward way of loading the XM and then a XM game can be selected from the software list. More experimentation definitely needed! If it helps, from a CL perspective, the difference between loading without and with the XM under MAME.. Without XM: mame a7800 -cart "C:\PATH\TO\ROMS\ROM FILE.a78" or mame a7800 -cart1 "C:\PATH\TO\ROMS\ROM FILE.a78" With XM: mame a7800 -cart1 xm -cart2 "C:\PATH\TO\ROMS\ROM FILE.a78" Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 9, 2021 Share Posted November 9, 2021 3 minutes ago, Trebor said: If it helps, from a CL perspective, the difference between loading without and with the XM under MAME.. Without XM: mame a7800 -cart "C:\PATH\TO\ROMS\ROM FILE.a78" or mame a7800 -cart1 "C:\PATH\TO\ROMS\ROM FILE.a78" With XM: mame a7800 -cart1 xm -cart2 "C:\PATH\TO\ROMS\ROM FILE.a78" Thanks... I saw that info on the a7800 wiki page. Now only if I could translate that in XML code. Maybe I'll take a chance and bug the MAME devs as cranky as they can be.. 1 Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 10, 2021 Share Posted November 10, 2021 (edited) I feel like such a dope. Retroarch Mame Current has an option to disable softlists and to "force" the media type. So when I disable softlists and force media type to cart it automatically loads the ROM as CART1. So at the very least that solves my problem of not being able to load .a78 file. And the best part? Games that use RAM don't crash! So that is one other problem solved. That just leaves the XM games which is gonna be tricky. But I'll burn that bridge down later. So I effectively have about 24 hours invested in A7800.XML editing for BIN images totally wasted. Ah well no complaints here... Things should move along faster and I can finally enjoy the newer homebrews without having the headache of dealing with older emulators or the A7800.XML file. ? Edited November 10, 2021 by Shannon 2 Quote Link to comment Share on other sites More sharing options...
+Karl G Posted November 16, 2021 Share Posted November 16, 2021 How difficult is it to add a new custom controller to a7800? It's not something that physically exists at the moment, but it would be various combinations of the 5 standard joystick inputs. 1 Quote Link to comment Share on other sites More sharing options...
RevEng Posted November 16, 2021 Share Posted November 16, 2021 The specifics really affect the answer. If it's just dumb buttons, like a track+field or starplex, you can remap the directions in an emulation session. If there's active electronics and/or interpretation of those lines, then someone will need to put together a new slotted controller driver. Less development time if it's like something that already exists and you can copy the driver. (and change whatever needs changing.) Quote Link to comment Share on other sites More sharing options...
+Karl G Posted November 16, 2021 Share Posted November 16, 2021 Well, in this case, the only difference from a standard joystick would be a single button activating multiple inputs, which is something I could not see a way to do in the GUI. Quote Link to comment Share on other sites More sharing options...
RevEng Posted November 16, 2021 Share Posted November 16, 2021 You can assign the same physical key press or physical controller input to multiple a7800 joystick inputs. Start the game up, hit tab, and go to the "console and controller inputs" menu, and assign how you like. I just tested with Xevious just now, and was able to map the LEFT arrow key to both the 7800 joystick 1 LEFT and fire buttons. Every time I moved left, the ship fired. 1 Quote Link to comment Share on other sites More sharing options...
+Karl G Posted November 16, 2021 Share Posted November 16, 2021 Thanks! I guess I wasn't thinking that though logically. It should be possible then to assign a key for all 32 possible combinations of those 5 inputs. Quote Link to comment Share on other sites More sharing options...
