pacgreg Posted January 2, 2018 Share Posted January 2, 2018 (edited) Trying to do audio for the first time, I guess my real question would be can you gosub jump to another bank and still use sread normally? Can you use two sdata groupings at the same time for different sounds and music playing at the same time? Attached is the code I was trying to play with to use music and bankswitching. Thanks default.bas Edited January 2, 2018 by pacgreg Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted January 2, 2018 Share Posted January 2, 2018 I usually have the least amount of weirdness if I put the VisualbB generated sound engine and music data in the last bank. Same thing goes for the titlescreen kernel data and titlescreen loop. Technically you can call the routines from anywhere but, yeah. Personal preference and experience. UPDATE: Sorry, it's a little more than personal preference. It seems keeping the data and the routines that use it close is a real good idea. I experience the same phenomenon in sega genesis programming. Dunno the exact reason in assembly it works that way. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted January 2, 2018 Share Posted January 2, 2018 I usually have the least amount of weirdness if I put the VisualbB generated sound engine and music data in the last bank. Same thing goes for the titlescreen kernel data and titlescreen loop. Technically you can call the routines from anywhere but, yeah. Personal preference and experience. UPDATE: Sorry, it's a little more than personal preference. It seems keeping the data and the routines that use it close is a real good idea. I experience the same phenomenon in sega genesis programming. Dunno the exact reason in assembly it works that way. Since a bunch of things already go in the last bank, it might be better to stick sound in a different one (if you are using more than two banks). Trying to do audio for the first time, I guess my real question would be can you gosub jump to another bank and still use sread normally? Can you use two sdata groupings at the same time for different sounds and music playing at the same time? Attached is the code I was trying to play with to use music and bankswitching. Thanks This example program uses sdata: randomterrain.com/atari-2600-memories-batari-basic-commands.html#ex_sound_with_bg_music Looks like I forgot to mention on the bB page that it uses sdata. I'll fix that now and I'll also add a link to the example from the sdata section. 1 Quote Link to comment Share on other sites More sharing options...
