greenflannel Posted January 3, 2018 Share Posted January 3, 2018 Hello, I am a newish member of the forums and I have searched for answers, but can't seem to find exactly what I'm after. I have a 1040 STF that was in a closet for about the last 16 years that I bought at a yard sale for $5. Since I was just a kid I didn't realize what I had actually purchased, and quickly realized I had no way of hooking up a monitor, so in the closet it went. Anyways, I purchased a VGA cable to hook it up to my monitor; I know the stipulations about the 15KHz, but I wanted to just see if it worked at all, and figured the hi-res mode should work with my monitor. When I turn it on, I usually get nothing, my monitor says it's waiting for a signal. Sometimes I get a black screen, sometimes I get a constant adjusting picture. One time I got a pink and green flash. What I want to find out, is there a way to toggle hi-res mode without first being able to see anything on the display? I really want to know if it works before I go in search of the elusive multi-sync monitor. I have enough monitors at home, that I don't want to spend that kind of money unless the ST works. Any advice is appreciated, thank you! Quote Link to comment Share on other sites More sharing options...
Zogging Hell Posted January 3, 2018 Share Posted January 3, 2018 The mono select is caused by a pin on the cable/ and monitor port. If it is present then the ST boots in mono, if not then it boots in low res. If your cable doesn't have the pin, it won't boot in mono. Check the pin outs on your cable. Quote Link to comment Share on other sites More sharing options...
anzac Posted January 3, 2018 Share Posted January 3, 2018 What kind of VGA adapter are you using? Quote Link to comment Share on other sites More sharing options...
greenflannel Posted January 4, 2018 Author Share Posted January 4, 2018 I'm using one from Cool Novelties, https://coolnovelties.co.uk/coolnovelties/atari-st-video-cables/290-atari-st-to-vga-multi-sync-rgb-colour-monitor-cable.html?search_query=Atari+st&results=33 Quote Link to comment Share on other sites More sharing options...
tjlazer Posted January 11, 2018 Share Posted January 11, 2018 (edited) The problem you're having is that cable is for color monitors that sync down to 15 kHz. So your monitor cannot display the image. That cable doesn't do mono, you need a different cable. They are for slaw on eBay all the time and are cheaper. Edited January 11, 2018 by tjlazer 1 Quote Link to comment Share on other sites More sharing options...
Bikerbob Posted January 12, 2018 Share Posted January 12, 2018 (edited) Look up the specs for your monitor you say you have lots of them. 31khz for hi-res. A lot of monitors can get down to that on a push. If you are confident enough to do a little soldering on to a switch you could modify that cable to work as both a mono and a colour cable. James Edited January 12, 2018 by Bikerbob Quote Link to comment Share on other sites More sharing options...
Spanner Posted January 17, 2018 Share Posted January 17, 2018 Or use composite I do on my Atari 130XE and its in colour,if you use your monitor with your PC too then get a Easy Cap,its a capture usb card,that how i use mine,so I am able look on here and in the left bottom of my screen I have my A130XE displying and I click on it and it goes full screen when I want to play a game. Quote Link to comment Share on other sites More sharing options...
mellis Posted January 17, 2018 Share Posted January 17, 2018 Or use composite I do on my Atari 130XE and its in colour,if you use your monitor with your PC too then get a Easy Cap,its a capture usb card,that how i use mine,so I am able look on here and in the left bottom of my screen I have my A130XE displying and I click on it and it goes full screen when I want to play a game. Can't use composite on a 1040STF - composite requires an STFM. Quote Link to comment Share on other sites More sharing options...
