+TheBF Posted July 15 Author Share Posted July 15 4 minutes ago, Vorticon said: Well nuts. This is what I did: bcd2hex mov r4,r5 ;isolate low digit andi r5,000fh mov r4,r6 ;isolate high digit andi r6,00f0h srl r6,4 mov r6,r4 ;save original value sla r6,3 ;multiply by 8 sla r4,1 ;multiply original value by 2 a r4,r6 ;high value has now been multiplied by 10 a r5,r6 ;add low and high numbers. r6 now has hex value b *r11 Welcome to my club. :-) If pascal or you have a hex output procedure you can use that on each byte. The clock just never counts past 9 for any digit. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted July 18 Author Share Posted July 18 Taking @Vorticon 's advice I implemented words to handle the UTI. (no, not a urinary tract infection) In this case the Update transfer inhibit bit. I also add words to set the time and date and went wild and added words to generate a time and date string which could be used to stamp a report. There are also words to convert BCD to single precision integers and the reciprocal operator as well. It would not be too hard to port this stuff to the other systems. My consultation services are available and my regular rates apply. 🙂 (For the Forth student it could be worth looking at how we get string concatenation here, reverse polish style, without including a whole string library.) \ IDECLOCK.FTH July 2024 B FOX \ INCLUDE DSK1.TOOLS ( DEBUG only) \ clock registers in memory HEX 4020 CONSTANT secs \ Register 0: Seconds. Valid values: >00 to >59. 4024 CONSTANT mins \ Register 2: Minutes. Valid values: >00 to >59. 4028 CONSTANT hrs \ Register 4: Hours. Valid values: >00 to >23, 402C CONSTANT day \ Register 6: Day of the month. Valid values: >01 through >31. 4032 CONSTANT month \ Register 9: Month. Valid values >01 to >12. 4034 CONSTANT year \ Register 10: Year. Valid values >00 to >99. 403C CONSTANT ctrl \ Register 14: Control register 1000 CONSTANT IDECARD DECIMAL 12 2* USER CRU \ address of R12 in any Camel Forth workspace \ Machine code CRU words HEX CODE 0SBO ( -- ) 1D00 , NEXT, ENDCODE CODE 0SBZ ( -- ) 1E00 , NEXT, ENDCODE CODE 1SBO ( -- ) 1D01 , NEXT, ENDCODE CODE 3SBO ( -- ) 1D03 , NEXT, ENDCODE \ BCD integer conversions : BCD>S ( bcd -- n ) \ "BCD to single" DUP 0F AND SWAP F0 AND 4 RSHIFT 0A * + ; DECIMAL : S>BCD ( n -- bcd ) 10 /MOD 4 LSHIFT + ; \ Update Transfer Inhibit : UTI-ON ( -- ) ctrl DUP C@ 8 OR SWAP C! ; : UTI-OFF ( -- ) ctrl DUP C@ 7 AND SWAP C! ; : CLOCK-ON IDECARD CRU ! 0SBO 1SBO \ enable mapping of >4000 - >40ff space 3SBO \ fixed page at >4000 - >40ff ; : TIME@ ( -- secs min hrs) CLOCK-ON UTI-ON secs C@ mins C@ hrs C@ UTI-OFF 0SBZ \ card off ; : DATE@ ( -- day month yr ) CLOCK-ON day C@ month C@ year C@ 0SBO ; \ formatted output \ convert n into a 2 digit string. can be used to create a time/date string : (##) ( n --) addr len ) 0 <# # # #> ; : .## ( n --) (##) TYPE ; : .TIME ( -- ) BASE @ >R HEX TIME@ .## ':' .## ':' .## R> BASE ! ; : .DATE BASE @ >R HEX DATE@ .## ." /" .## ." /" .## R> BASE ! ; : .DATE&TIME .DATE SPACE .TIME ; \ +PLACE concatenates (addr n) to counted string $addr : +PLACE ( addr n $addr -- ) 2DUP 2>R COUNT + SWAP MOVE 2R> C+! ; \ syntax suger: concatenate stack string to pad : & ( addr len -- ) PAD +PLACE ; \ usage: TIME@ >TIME$ : >TIME$ ( mins secs hrs -- addr len) PAD OFF BASE @ >R HEX (##) & S" :" & (##) & S" :" & (##) & R> BASE ! PAD COUNT ; \ Usage: DATE@ >DATE$ : >DATE$ ( day month year -- addr len) PAD OFF BASE @ >R HEX (##) & S" /" & (##) & S" /" & (##) & R> BASE ! PAD COUNT ; \ Set the clock words DECIMAL : TIME! ( hr min sec -- ) CLOCK-ON UTI-ON S>BCD secs C! S>BCD mins C! S>BCD hrs C! UTI-OFF 0SBO ; : DATE! ( yr month day-- ) CLOCK-ON UTI-ON S>BCD day C! S>BCD month C! S>BCD year C! UTI-OFF 0SBO ; 2 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 18 Share Posted July 18 I noticed you omitted fetching the day of week at >4030 (Sunday = 1). You might as well add it to make your package complete 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted July 18 Author Share Posted July 18 1 hour ago, Vorticon said: I noticed you omitted fetching the day of week at >4030 (Sunday = 1). You might as well add it to make your package complete Good catch. I have all the "words" to do it now. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted July 18 Author Share Posted July 18 So here is an even bigger version. You probably never use all of this. It compiles to 1418 bytes. But is has examples of how to manage this kind of stuff in Forth. Some concepts explored here: I changed things up and used create/does> to make clock "field readers" that all use the same code. This saves space. Created words that make it pretty simple to make the date format anything you like. Used compact string arrays that pack the strings end to end for months and days of the week Spoiler \ IDECLOCK.FTH July 2024 B FOX \ INCLUDE DSK1.TOOLS ( DEBUG only) HERE \ clock registers in memory HEX 4020 CONSTANT secs \ Register 0: Seconds. Valid values: >00 to >59. 4024 CONSTANT mins \ Register 2: Minutes. Valid values: >00 to >59. 4028 CONSTANT hrs \ Register 4: Hours. Valid values: >00 to >23, 402C CONSTANT day \ Register 6: Day of the month. Valid values: >01 through >31. 4030 CONSTANT dow \ day of the week 4032 CONSTANT month \ Register 9: Month. Valid values >01 to >12. 4034 CONSTANT year \ Register 10: Year. Valid values >00 to >99. 403C CONSTANT ctrl \ Register 14: Control register 1000 CONSTANT IDECARD DECIMAL 12 2* USER CRU \ address of R12 in any Camel Forth workspace \ Machine code CRU words HEX CODE 0SBO ( -- ) 1D00 , NEXT, ENDCODE CODE 0SBZ ( -- ) 1E00 , NEXT, ENDCODE CODE 1SBO ( -- ) 1D01 , NEXT, ENDCODE CODE 3SBO ( -- ) 1D03 , NEXT, ENDCODE \ BCD integer conversions : BCD>S ( bcd -- n ) \ "BCD to single" DUP 0F AND SWAP F0 AND 4 RSHIFT 0A * + ; DECIMAL : S>BCD ( n -- bcd ) 10 /MOD 4 LSHIFT + ; \ Update Transfer Inhibit : UTI-ON ( -- ) ctrl DUP C@ 8 OR SWAP C! ; : UTI-OFF ( -- ) ctrl DUP C@ 7 AND SWAP C! ; : CLOCK-ON IDECARD CRU ! 0SBO 1SBO \ enable mapping of >4000 - >40ff space 3SBO \ fixed page at >4000 - >40ff ; \ creates "field readers" that read a clock field using common code. \ slower reads, but saves a lot of space : CLOCK-FIELD: CREATE , DOES> CLOCK-ON UTI-ON @ \ get the clock address from this word C@ BCD>S \ read the address and convert UTI-OFF 0SBO ; \ card off \ define the field readers secs CLOCK-FIELD: SECS@ mins CLOCK-FIELD: MINS@ hrs CLOCK-FIELD: HRS@ dow CLOCK-FIELD: DOW@ day CLOCK-FIELD: DAY@ month CLOCK-FIELD: MONTH@ year CLOCK-FIELD: YEAR@ : TIME@ ( -- secs min hrs) SECS@ MINS@ HRS@ ; : DATE@ ( -- day month year) DAY@ MONTH@ YEAR@ ; \ formatted output \ returns a string. can be used to create a time/date string : (##) ( -- addr len ) 0 <# # # #> ; : .## (##) TYPE ; \ +PLACE concatenates (addr n) to counted string $addr : +PLACE ( addr n $addr -- ) 2DUP 2>R COUNT + SWAP MOVE 2R> C+! ; \ syntax suger: concatenate stack string to pad : & ( addr len -- ) PAD +PLACE ; \ usage: TIME@ >TIME$ : >TIME$ ( mins secs hrs -- addr len) PAD OFF BASE @ >R DECIMAL (##) & S" :" & (##) & S" :" & (##) & R> BASE ! PAD COUNT ; \ Usage: DATE@ >DATE$ : >DATE$ ( day month year -- addr len) PAD OFF BASE @ >R DECIMAL (##) & S" /" & (##) & S" /" & (##) & R> BASE ! PAD COUNT ; \ Set the clock words DECIMAL : TIME! ( hr min sec -- ) CLOCK-ON UTI-ON S>BCD secs C! S>BCD mins C! S>BCD hrs C! UTI-OFF 0SBO ; : DATE! ( yr month day-- ) CLOCK-ON UTI-ON S>BCD day C! S>BCD month C! S>BCD year C! UTI-OFF 0SBO ; \ OUTPUT WORDS : .TIME ( -- ) BASE @ >R DECIMAL TIME@ .## ." :" .## ." :" .## R> BASE ! ; \ compact string array. Uses count byte as link to next string. : NTH$ ( $array n -- address len ) 0 DO COUNT + ALIGNED LOOP COUNT ; CREATE MONTHS S" " S, S" Jan" S, S" Feb" S, S" Mar" S, S" Apr" S, S" May" S, S" Jun" S, S" Jul" S, S" Aug" S, S" Sep" S, S" Oct" S, S" Nov" S, S" Dec" S, 0 , : ]MONTH ( n -- addr len) DUP 13 1 WITHIN ABORT" Bad month#" MONTHS SWAP NTH$ ; CREATE DAYS S" " S, S" Sunday" S, S" Monday" S, S" Tuesday" S, S" Wednesday" S, S" Thursday" S, S" Saturday" S, S" Friday" S, 0 , : ]DAY ( n --) DUP 7 1 WITHIN ABORT" Bad day#" DAYS SWAP NTH$ ; : .DOW ( --) DOW@ ]DAY TYPE ; : .MONTH ( --) MONTH@ ]MONTH TYPE ; : .YEAR ( --) YEAR@ 20 .## .## ; : .M/D/Y ( -- ) MONTH@ .## ." /" DAY@ .## ." /" YEAR@ .## ; : .Y-M-D ( -- ) YEAR@ .YEAR ." -" MONTH@ .## ." -" DAY@ .## ; : .D.M.Y ( -- ) DAY@ .## ." ." MONTH@ .## ." ." YEAR@ .## ; : .USADATE ( -- ) .MONTH SPACE DAY@ .## ." , " .YEAR ; : .FORTH-DATE ( -- ) DAY@ .## .MONTH YEAR@ .## ; : .LONG-DATE ( -- ) .DOW ." , " .MONTH SPACE DAY@ .## ." , " .YEAR ; : .STAMP ( -- ) .LONG-DATE ." , " .TIME ; HERE SWAP - DECIMAL . .( bytes) \ TEST CR .M/D/Y CR .Y-M-D CR .D.M.Y CR .USADATE CR .FORTH-DATE CR .LONG-DATE CR .STAMP CR 2 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 18 Share Posted July 18 You really went all out, didn't you An equivalent idea in Pascal would be to create a unit named CLOCK which would have a set of procedures that format and display the date and/or time in a variety of ways while accepting x,y screen coordinates as input. You just gave me another thing to do! 1 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted July 18 Author Share Posted July 18 1 hour ago, Vorticon said: You really went all out, didn't you An equivalent idea in Pascal would be to create a unit named CLOCK which would have a set of procedures that format and display the date and/or time in a variety of ways while accepting x,y screen coordinates as input. You just gave me another thing to do! Confession time. I found a file from 1991 that I had written for HsForth to start with. But I made a lot of changes to my thinking from 33 years ago!. Wow time is relentless. You mean like this: : XY.TIME AT-XY .TIME ; : XY.DATA AT-XY .DATE ; 2 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 22 Share Posted July 22 Saw this today. Pretty cool. 2 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted July 22 Author Share Posted July 22 I always wondered how few chips it would take to make a Forth CPU. This is cool. I think the world should credit Chuck's work properly. There are Von Neumann architectures and there are Harvard Architectures but nobody talks about the "Moore Architecture". Memory, 2 stacks and I/O. I think his best CPU design was ShBoom. Chip Hall of Fame: Computer Cowboys Sh-Boom Processor - IEEE Spectrum 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted July 22 Author Share Posted July 22 2 hours ago, Vorticon said: Saw this today. Pretty cool. I need more life span. I started spinning on what it would look like to build one of these 7400 CPUs but incorporate a couple of 74181 ALU chips to speed up math operations 74181 - Wikipedia AND... Steal the 9900 idea of using RAM for the registers except the register window would actually be the data stack and return stack ( 32 cells each ie: 128 bytes) Internally with this design you would only need a workspace register, a data stack register (8 bits) and a return stack register 8 bits) Like Camel99 Forth, workspace register could be used as the base address for the "user area" where task local variables are stored. And on it goes down the rabbit hole... 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted July 31 Author Share Posted July 31 (edited) In process of working on the VI99 editor I of course began to wonder how I could hold bigger files. The original VI used a swap file and I could go that way using BLOCK so that's a consideration. Of course the super power is in the SAMS card. Previously for ED99 I made a 2 "window" memory manager so you could freely copy records from anywhere to anywhere in a SAMS 64K segment. I went down the rabbit hole of how would I do that on a character by character basis. My solution was to wrap the entire thing into a sub-program with its own workspace. I used registers as variables and constants to try and keep things as speedy as possible. But of course now these registers are in expansion RAM so they are slower. The manager as is compiles to 464 bytes. It works but I don't know if the editor could tolerate moving data at Forth speeds. Anyway here it is. I like it but it probably needs much faster FILL and CMOVE code words that somehow use the SAMS manager differently. Spoiler \ SAMS 2 window virtual memmory system as SUB-PROGRAM 2024 Brian Fox \ This version replaces variables with registers in a workspace. NEEDS DUMP FROM DSK1.TOOLS NEEDS MOV, FROM DSK1.ASM9900 NEEDS ELAPSE FROM DSK1.ELAPSE NEEDS SAMSINI FROM DSK1.SAMSINI HERE CREATE SAMSWKSP 16 CELLS ALLOT \ init the registers at compile time for debugging HEX SAMSWKSP 16 CELLS FF FILL \ name R0 for easy Forth access SAMSWKSP CONSTANT SEG \ set the segment in R0 like this 1 SEG ! \ store with memory increment : !++ ( addr n -- addr') OVER ! CELL+ ; : INIT-SAMSWKSP SAMSWKSP 1 !++ \ R0 = segment 2000 !++ \ R1 = last window used 0 !++ \ R2 page# in window0 0 !++ \ R3 page# in window1 2000 !++ \ R4 low ram window0 3000 !++ \ R5 low ram window1 DROP ; INIT-SAMSWKSP \ ========================================== \ REGISTER Usage in VIRTWSP \ separate workspace allows register renaming for code clarity R0 CONSTANT SEG# \ 64K segment in use R1 CONSTANT USED \ last used memory WINDOW ( 2000 or 3000 ) R2 CONSTANT PAGE0 \ SAMS page number in window 0 (variable) R3 CONSTANT PAGE1 \ SAMS page number in window 1 (variable) R4 CONSTANT WINDOW0 \ WINDOW0 address (constant) R5 CONSTANT WINDOW1 \ WINDOW1 address (constant) R6 CONSTANT OFFSET \ OFFSET into window (computed) R7 CONSTANT PAGE# \ SAMS PAGE# (computed) \ R8 scratch \ R9 scratch \ R10 scratch \ R11 scratch \ R12 scratch \ R13 address of Forth workspace \ R14 Forth program counter \ R15 Forth status \ address of Forth TOS register in Forth workspace : [TOS] ( -- ) ?EXEC 8 R13 () ; IMMEDIATE \ 9900 sub-program. NOT a Forth word. Called with BLWP CREATE _real ( virtaddr -- realaddress) SAMSWKSP , HERE CELL+ , \ compile a vector to code below \ perform TOS 4096 /MOD to compute offset,page# [TOS] OFFSET MOV, \ virtaddress in r6 R6 PAGE# MOV, \ dup in R7 PAGE# 0C SRL, \ R7 / 4096 = quot. PAGE# 4 SLA, \ R7 = samspage# = quotient * 16 OFFSET 0FFF ANDI, \ R6 = offset = virtaddr MOD >1000 \ fast tests if page# is already in memory PAGE# PAGE0 CMP, EQ IF, WINDOW0 [TOS] MOV, \ use 1st window OFFSET [TOS] ADD, \ add the offset RTWP, \ return to Forth ENDIF, \ test if page# is in 2nd buffer PAGE# PAGE1 CMP, EQ IF, WINDOW1 [TOS] MOV, \ use 2nd window, OFFSET [TOS] ADD, \ add the offset RTWP, \ return to Forth ENDIF, \ *********************************************** \ * page# not in memory: * \ *********************************************** USED WINDOW0 CMP, \ last window was window0 ? EQ IF, ( yes so used window1) WINDOW1 USED MOV, \ use window1 @ 3000 PAGE# PAGE1 MOV, \ remember this page# ELSE, ( must have used window1 ) WINDOW0 USED MOV, \ use window0 @ 2000 PAGE# PAGE0 MOV, \ remember this page# is in window0 ENDIF, USED R9 MOV, \ copy memory window in use to R9 \ map new page into a RAM window R9 0B SRL, \ R9 = index into SAMS registers R12 1E00 LI, \ cru address of SAMS 0 SBO, \ SAMS card on PAGE# SWPB, \ swap bytes on page# argument PAGE# 4000 R9 () MOV, \ load page# into SAMS card memory ("registers") 0 SBZ, \ SAMS card off \ return "real" address to Forth USED [TOS] MOV, \ move active window to Forth tos OFFSET [TOS] ADD, \ add the offset into the window RTWP, \ end code \ test word CODE >REAL ( a -- a' ) _real @@ BLWP, NEXT, ENDCODE \ FAR memmory operators convert virtual address to real address CODE !L ( n virtual -- ) _real @@ BLWP, *SP+ *TOS MOV, TOS POP, NEXT, ENDCODE CODE C!L ( c virtual -- ) _real @@ BLWP, 1 (SP) *TOS MOVB, SP INCT, \ drop virtual TOS POP, \ drop c NEXT, ENDCODE CODE @L ( virtual -- n) _real @@ BLWP, *TOS TOS MOV, NEXT, ENDCODE CODE C@L ( virtual -- c) _real @@ BLWP, *TOS TOS MOVB, TOS 8 SRL, NEXT, ENDCODE HERE SWAP - DECIMAL . .( bytes) And here are some Forth memory movers and fillers. It takes 22 seconds to fill 64K bytes. 13 seconds to fill 32K "cells". : SAMSFILL ( addr len char --) -ROT BOUNDS DO DUP I C!L LOOP DROP ; : SAMSFILLW ( addr len U -- ) -ROT BOUNDS DO DUP I !L 2 +LOOP DROP ; : SAMSCMOVE ( addr1 addr2 u --) \ 8 bit move. BOUNDS DO DUP C@L I C!L CHAR+ LOOP DROP ; : SAMSMOVE ( addr1 addr2 u --) \ 16 bit move. BOUNDS DO DUP @L I !L CELL+ 2 +LOOP DROP ; Edited July 31 by TheBF fixed a comment 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 1 Author Share Posted August 1 I was staring at the code that performed 4096 /MOD but using bit shifting. PAGE# 0C SRL, \ R7 / 4096 = quot. PAGE# 4 SLA, \ R7 = samspage# = quotient * 16 PAGE# SWPB, Given a virtual address of >1234 We get the result >1000 It seems like a lot of shifts. How about we replace all that with this? PAGE# F000 ANDI, And if we do this then the page# in the correct byte for use by the SAMS card so I removed another SWPB in that section. So now performing "<address> 4096 /MOD" takes 2 instructions. PAGE# F000 ANDI, \ R7 = page# in low byte OFFSET 0FFF ANDI, \ R6 = offset = virtaddr MOD >1000 This speeds up writing 64K bytes by 5%. I'll take it. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 1 Author Share Posted August 1 2 minutes ago, TheBF said: I was staring at the code that performed 4096 /MOD but using bit shifting. PAGE# 0C SRL, \ R7 / 4096 = quot. PAGE# 4 SLA, \ R7 = samspage# = quotient * 16 PAGE# SWPB, Given a virtual address of >1234 We get the result >1000 It seems like a lot of shifts. How about we replace all that with this? PAGE# F000 ANDI, And if we do this then the page# in the correct byte for use by the SAMS card so I removed another SWPB in that section. So now performing "<address> 4096 /MOD" takes 2 instructions. PAGE# F000 ANDI, \ R7 = page# in low byte OFFSET 0FFF ANDI, \ R6 = offset = virtaddr MOD >1000 This speeds up writing 64K bytes by 5%. I'll take it. Of course this is only valid for 1M of SAMS memory but that's what I have so I will keep until somebody complains. 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 1 Author Share Posted August 1 I spoke too soon. (of course I did) I needed to add one shift back into the calculation But at least its a smaller and faster shift. ( only 4 bits) The method is to manage the SAMS page number in the low byte of the register. This saves a SWPB instruction later when we map the page into memory. The API to set R0 in the SAMS workspace is \ store segment value in low byte to save instructions later : SEGMENT ( n -- ) 16* >< SEG ! ; So 1 SEGMENT would set the SEG variable (alias for R0) to >1000 Then the correction in the /mod computation is this. PAGE# F000 ANDI, \ get the significant digit PAGE# 04 SRL, \ shift 4 bits SEG# PAGE# ADD, \ add the segment no. * 16 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 1 Author Share Posted August 1 So now the hard reality of dealing with SAMS memory on a byte by byte basis. Here is a FILL routine written using C!L that writes a byte to SAMS in a 64K segment : SAMSFILL ( addr len char --) -ROT BOUNDS DO DUP I C!L LOOP DROP ; It fills 64K bytes in 22.9 seconds. the code is 16 bytes. Here is the same function written in Forth Assembler CODE SAMS.FILL ( VirtAddr len char -- ) TOS R3 MOV, \ char is held in R3 R3 SWPB, \ do that 9900 thing R0 POP, \ R0 is our down counter R1 POP, \ R1 is the virtual address BEGIN, R1 TOS MOV, \ Virt to TOS ie: R4 _real @@ BLWP, \ convert virtual to real in TOS R3 *TOS MOVB, \ put the byte into the real address R1 INC, \ next virtual address R0 DEC, \ dec the counter EQ UNTIL, TOS POP, NEXT, ENDCODE It fills 64K bytes in 11.23 seconds If I run the normal FILL routine, filling 8K bytes, 8 times, in a DO LOOP it takes ... 1.33 seconds. So using SAMS by computing the window address on each byte, is at best 9X slower than expansion RAM. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 2 Author Share Posted August 2 The TI-99 is a cursed machine to try and optimize. I took an earlier version of this 2 window SAMS idea that doesn't use a separate workspace. I call the "_real" word with BL. I incorporated the slightly improved divide code and I used the free registers R13 14 & 15. It is also now using registers on the 16 bit buss in the Forth workspace. This version does the 64K fill operation in 9.85 seconds vs 11.23 with the BLWP version so that's a 14% improvement. The separate workspace is great but it's a big hit when the registers are in expansion ram. So all that to say, I think for speedy purposes you have to use SAMS as 4K chunks. Spoiler \ SAMS memmory access as BLOCK from Forth. Source code Brian Fox NEEDS DUMP FROM DSK1.TOOLS NEEDS MOV, FROM DSK1.ASM9900 NEEDS ELAPSE FROM DSK1.ELAPSE NEEDS SAMSINI FROM DSK1.SAMSINI HERE \ ========================================== \ BLOCK is the entire SAMS manager HEX VARIABLE USE VARIABLE SEG \ set the segment CODE 16* TOS 4 SLA, NEXT, ENDCODE \ store segment value in low byte to save instructions later : SEGMENT ( n -- ) 16* >< SEG ! ; 1 SEGMENT CREATE WINDOWS 2000 , 3000 , \ windows in Low CPU RAM CREATE PAGES 0 , 0 , \ SAMS page in the each window 4000 CONSTANT SAMS \ base address of registers in SAMS card : (R1) R1 () ; \ syntax sugar \ 9900 sub-routine. NOT a Forth word. CREATE _real ( virtual -- real_addr) \ REGISTERS USED \ R0 R1 R4 R5 W \ perform TOS 4096 /MOD to compute offset,page# TOS R5 MOV, R5 R0 MOV, \ dup in R0 SEG @@ TOS MOV, \ segment# to TOS \ manage the page numbers in the low byte to save instructions R0 F000 ANDI, \ get the significant digit R0 04 SRL, \ shift 4 bits R0 TOS ADD, \ add the segment no. * 16 R5 0FFF ANDI, \ offset= virtual masked to 12 bits \ search if page# is already in 1st buffer TOS PAGES @@ CMP, EQ IF, TOS WINDOWS @ LI, \ set 1st window. ~2x FASTER using LI R5 TOS ADD, \ add the offset RT, \ get out ENDIF, \ search if page# is in 2nd buffer TOS PAGES CELL+ @@ CMP, EQ IF, TOS WINDOWS CELL+ @ LI, \ set 2nd window, R5 TOS ADD, \ add the offset RT, ENDIF, \ page# not in memory: Select another window W 0001 LI, USE @@ W XOR, W USE @@ MOV, W 1 SLA, \ W 2* is new index into PAGES & WINDOWS TOS PAGES (W) MOV, \ remember this new page# WINDOWS (W) R1 MOV, \ get the window to use into R1 \ map new page into a RAM window R1 0B SRL, \ divide window by 2048 = index into SAMS registers R12 1E00 LI, \ cru address of SAMS 0 SBO, \ SAMS card on \ TOS SWPB, \ swap bytes on page# argument TOS SAMS (R1) MOV, \ load page# into SAMS card register 0 SBZ, \ SAMS card off WINDOWS (W) TOS MOV, \ get window into TOS R5 TOS ADD, \ add the offset RT, \ ------------------------------------------------------------ CODE >REAL ( virtual -- offset page#) _real @@ BL, NEXT, ENDCODE \ Fetch and store in virtual memory. (Long addresses) CODE !L ( n virtual -- ) _real @@ BL, *SP+ *TOS MOV, TOS POP, NEXT, ENDCODE CODE C!L ( c virtual -- ) _real @@ BL, 1 (SP) *TOS MOVB, SP INCT, TOS POP, NEXT, ENDCODE CODE @L ( virtural -- n) _real @@ BL, *TOS TOS MOV, NEXT, ENDCODE CODE C@L ( virtual -- c) _real @@ BL, *TOS TOS MOVB, TOS 8 SRL, NEXT, ENDCODE : SAMSMOVE ( addr1 addr2 u --) \ 16 bit move. BOUNDS DO DUP @L I !L CELL+ 2 +LOOP DROP ; : SAMSFILL ( addr len char -- ) -ROT BOUNDS DO DUP I C!L LOOP DROP ; \ 20.65 seconds CODE SAMS.FILL ( VirtAddr len char -- ) TOS R13 MOV, \ char is held in R13 R13 SWPB, \ do that 9900 thing R14 POP, \ R14 is our down counter R15 POP, \ R15 hold virtual address BEGIN, R15 TOS MOV, \ Virt to TOS and auto-inc _real @@ BL, \ convert virtual to real in TOS R13 *TOS MOVB, \ put the byte into the real address R15 INC, \ next virtual address R14 DEC, \ dec the counter EQ UNTIL, TOS POP, NEXT, ENDCODE \ 64k 9.8 SECONDS 3 Quote Link to comment Share on other sites More sharing options...
Tursi Posted August 2 Share Posted August 2 (edited) As you've seen the TI is almost 100% memory constrained. Since everything including registers hits memory, you need to reduce the number of operations for best performance. Many processors have tricks to do things in unusual ways faster than the obvious way - unless it reduces the instruction count they usually don't help on the TI. DIV is the slowest opcode by far, but it's usually faster than two shifts and an add. I can see two optimizations in your main loop - though the biggest one depends on an assumption that I don't know: is there any reason to expect that the virtual memory base will change inside of a block? If you know that the start and end address of your copy loop will be inside the same virtual memory page (or whatever the terminology is in this case), then you will see massive gains by only converting the virtual address to physical once, outside of the loop. The second gain would be to use MOV instead of MOVB and move two bytes at a time. This will immediately double your copy performance, but you need to deal with two things: - odd starting address - move one byte before you start. MOV always moves to an even address, no matter what it's passed. - odd count - after the loop you can drop one last byte with a MOVB. I've taken a stab at it here, but I've never used the forth assembler before, so I posted the raw assembly since that may be more clear than my "Forthglish". Spoiler * I am assuming I can use R0 as a scratch register MOV TOS,R13 * char is held in R13 (00XX) !! Assuming "TOS" defines to *reg or @address MOV R13,R0 * make a copy in R0 (00XX) SWPB R0 * get into MSB (XX00) MOVB R0,R13 * MOVB R0,R13 - R13 now contains the same byte in MSB and LSB (XXXX) POP R14 * R14 is our down counter (!!MAGIC!!) POP R15 * R15 hold virtual address (!!MAGIC!!) MOV R15,TOS * Virtual address to stack for function call (!!MAGIC TOS!!) BL @_real * convert virtual to real in TOS (!!MAGIC TOS!!) MOV TOS,R15 * now it's a physical address (!!MAGIC TOS!!) MOV R15,R0 * need to check if its an odd address AND R0,1 * ANDI R0,1 - isolate the 1s bit JEQ STARTLOOP * if it's zero, jump ahead to start the loop MOVB R13,*R15+ * move a single byte to ensure the address starts even DEC R14 * count down the byte JEQ FINISH * if we're done, skip to the end STARTLOOP * startloop label - correct my syntax as needed DECT R14 * pre-decrement so that we overflow at the end - that way we can detect even if odd JLT ENDLOOP * if we already underflowed, then there was only 1 byte left (or zero to start!), go deal with it LOOP MOV R13,*R15+ * put TWO bytes to the real address - same cycles as MOVB, twice the data, and autoincrement in one DECT R14 * dec the counter !!BY TWO!! JGT LOOP * if still positive, loop JNE ENDLOOP * If we went negative, go check for -1 MOV R13,*R15 * else it was exactly zero, so move once more. We don't need to inc or dec anything JMP FINISH * we already know we're done ENDLOOP * label to deal with the last byte, if necessary INV R14 * FFFF -> 0000, otherwise we don't care JNE FINISH * skip ahead if it's not 0 MOVB R13,*R15 * Move the last byte. No need to increment or decrement anything FINISH * finish label - continue with TOS POP, NEXT... Most of your cycles are going to the BL @_real and whatever that function is doing, so if you don't need to do it for every byte, you'll save a lot by only calling it once. And unless you're talking to hardware registers, using MOV instead of MOVB will double your copy performance instantly. HTH. (Edit: if you do have big copy blocks that might change virtual memory bases, you could do a little more setup up front, and have the code split up the memory copies into safely sized and aligned chunks. It'll still be faster. ) Edited August 2 by Tursi 1 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 3 Author Share Posted August 3 Thanks Tursi. I really appreciate input from someone with your expertise. I will try your code and report back what happens. Again sincere thank you. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 3 Author Share Posted August 3 @Tursi Oh and the magic TOS is an alias for R4. In my Forth the top of stack value is cached in R4. The literature says this speeds up Forth about 10%. I see 8 to 10 % improvement on 9900. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 3 Author Share Posted August 3 @Tursi regarding the DIV versus shifts. @Lee Stewart wrote up a version of code for me to replace DIV/MOD and it measured about 10-12% faster than DIV. This code removed an instruction so it's probable just a bit better. But ya it's really close. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 3 Author Share Posted August 3 Given Tursi's "magic" comments, I guess I should give a short lesson an making "macro" instructions in Forth Assembler since my code uses them all the time. Forth Assembler is a secret super power of Forth IMHO. It is so intimately connected to Forth it's like programming in Forth with Registers instead of the data stack. (In fact I wrote a version of Forth Assembler that uses Forth names rather than TI names for many instructions and it works remarkably well) My personal version of the TI Forth Assembler has the following "pseudo instructions" as the TI manual call them. : RT, ( -- ) R11 ** B, ; : NOP, ( -- ) 0 JMP, ; : NEXT, ( -- ) R10 ** B, ; \ CAMEL99 interpreter cached in R10 Notice the these Assembler words just wrap the instructions in a "colon" definition. When these words are invoked, they "run" the assembler words. The magic part is that Assembler words write numbers into the Forth dictionary using the "comma" word. For example the NOP, above does nothing more than compile the number >1000 into the Forth dictionary memory. The special part is that 0 before the JMP, word. JMP, takes a signed byte on the data stack and combines it with the "JMP" instruction so the the JMP will jump forward or backward. The 0 causes JMP to go ahead 1 cell. 1 JMP, will compile the number >1001 and that instruction will jump forward 2 cells. So that's the theory. Other instructions require different input arguments like the registers to use and the addressing mode but it all boils down to taking inputs from the data stack and mixing those inputs with the "raw" instruction number to make the final 9900 instruction. Since the input arguments are taken from the Forth data stack we can play with those arguments with normal Forth words like SWAP DUP ROT etc. So here is all it took to make a pseudo-instruction to "POP" a number from the data stack into a 9900 register. : POP, ( dst -- ) *SP+ SWAP MOV, ; The destination register is placed on the data stack. Then in the definition we put the source argument on the stack, which is the address of the data stack held in the SP register. (SP is just an alias for R6 in Camel99) Next a SWAP puts the two arguments in the correct order for the MOV, instruction. So the instruction *SP+ <dst> MOV, will be compiled into memory when POP, is invoked. Here is the reciprocal operation PUSH, which takes two instructions on 9900. : PUSH, ( src -- ) SP DECT, *SP MOV, ; And here are the same "macros" for the other Forth stack, the return stack. : RPUSH, ( src -- ) RP DECT, *RP MOV, ; : RPOP, ( dst -- ) *RP+ SWAP MOV, ; I think that's pretty cool. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 3 Author Share Posted August 3 21 hours ago, Tursi said: I can see two optimizations in your main loop - though the biggest one depends on an assumption that I don't know: is there any reason to expect that the virtual memory base will change inside of a block? @Tursi I didn't answer your question. The thing I was trying to accomplish was making the SAMS memory within one 64K "segment" look like a contiguous chunk of memory. With the two window concept it means you could freely move a block of memory in the segment to another address in the segment. I had done this before for 80 bytes file records and it works great but as I have discovered the speed hit is too much for byte by byte copying/filling. So the answer is yes. And now I have to change that expectation. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 3 Author Share Posted August 3 OK so after lunch and a little thinking I realize that what @Tursi has taught me is: 1. Do the virtual->real conversion outside the loop. 2. Work at the cell level rather than the byte level. I have code for #2 in in a library file, but my version can be improved using ideas from Tursi's example. And converting outside the loop is simplest in Forth using a word I made for testing, but now will probably be the core of the whole thing. : SAMS.FILL ( virtual len char --) ROT >REAL -ROT FILL ; Now the tricky part is that we can only fill 4K with this simple method and we run the risk of going over a page boundary so I will devise a method to handle that. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 4 Author Share Posted August 4 Well that took me way longer than expected. I figured the best way to try this was to use Forth and I think it will be an acceptable solution for an expanded editor. I have not got SAMS.CMOVE yet but SAMS.FILL is very promising and I am still using the byte by byte standard FILL word so it could go faster still. I am using the SUB-PROGRAM (BLWP) version of the SAMS manager because it's safer. If I really need 14% more speed at that end I could change to the BL version. Here is the method: 1. Given an (address,length) pair, find a chunk of data from the input pair with length=#bytes to the first 4K boundary 2. Cut the input data pair by the length of that first chunk to get a "remainder" (address, length). (Here we can use the amazing /STRING ... again!) 3. Loop on that until the remaining length is less than 4K 4. FILL the final chunk Here is the code: HEX 1000 CONSTANT 4K F000 CONSTANT PAGE_END \ compute start of next SAMS page boundary ( 1000,2000,3000 ETC) : BOUNDARY ( addr -- addr addr') DUP PAGE_END AND 4K + ; : CHUNK ( addr len -- addr len addr1 n1) OVER BOUNDARY OVER - 1FFF AND ; \ compute the next chunk to use and what is remaining : NEXTCHUNK ( addr len -- addr len addr len') CHUNK DUP>R \ compute chunk and save length 2SWAP R> /STRING 2SWAP ; \ reduce size of data by length HEX : SAMS.FILL ( virtaddress len char -- ) >R \ save char on Ret. stack BEGIN DUP \ test for 0 bytes WHILE DUP FFF U> \ test if SIZE > 1 SAMS page WHILE NEXTCHUNK \ get a chunk to fill SWAP >REAL SWAP R@ FILL REPEAT SWAP >REAL SWAP R> FILL \ do the last chunk (partial page) THEN ; And here is the performance in the video. This took over 11 seconds doing the virtual to real conversions on every byte. SAMS FILL 2024-08-04 10-47-45.mp4 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 4 Author Share Posted August 4 OOPS. The idea is good but I missed one case in the logic. The case where you only want to FILL one small number of bytes. Back to pit... 1 Quote Link to comment Share on other sites More sharing options...
