Harry Potter Posted January 16, 2018 Share Posted January 16, 2018 I have the Windows version of Hatari v. 2.0.0 and want to be able to mount a disk image that's on a drive other than the one on which the emulator resides. How do I do that, or is it impossible? Quote Link to comment Share on other sites More sharing options...
darwinmac Posted January 16, 2018 Share Posted January 16, 2018 You would press F12 to bring up the Hatari menu. Then, click on Floppy Disks to bring up that dialog. You will click Browse in order to find the disk that's on the other drive. Unfortunately, the SDL file selector isn't the native Windows file browser so it's a bit clunky to use. Bob C Quote Link to comment Share on other sites More sharing options...
Harry Potter Posted January 16, 2018 Author Share Posted January 16, 2018 I know all this, but I can't find an option to change the drive. Quote Link to comment Share on other sites More sharing options...
darwinmac Posted January 16, 2018 Share Posted January 16, 2018 Unfortunately, I dont use the Windows version. I use the macOS version so the file systems are different. I would suggest asking your question on Atari-Forum where there are active Hatari users who post there. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted January 16, 2018 Share Posted January 16, 2018 It seems, that this is just another case where Windows users are let down, to say so. There are no (logical) drives in Linux, so file selector does not support change of it. And it will be so, I guess until someone go in business to rewrite complete UI for Hatari Win. version. Quote Link to comment Share on other sites More sharing options...
MrMaddog Posted January 16, 2018 Share Posted January 16, 2018 Ok, there are buttons at the top of the file selector for floppy image directory... Up: Goes up a sub directory... CWD: Directory where Hatari resides Home: Your User directory in Windows Root: Root of drice where hatari was installed Yeah, the previous versions of Hatari assumes you know about Linux style directories. The 2.0.0 version is sorta like the STOS file selector which was also wonky compaired to GEM's. Quote Link to comment Share on other sites More sharing options...
darwinmac Posted January 17, 2018 Share Posted January 17, 2018 (edited) @HarryPotter - The quick answer is there is no way to change drives from the SDL file selector. However, you can work around the problem by changing the value of szDiskImageDirectory in the [Floppy] section of the hatari.cfg file. By default, you'll find this file at: C:\Users\(Your windows login)\.hatari I ran the 2.0.0 version of Hatari on my Windows virtual machine after making this change and Hatari did look on the new drive for the disk images. I realize this isn't convenient if you want to have your ST images on multiple drives, but I'm hoping that isn't the case. When editing the hatari.cfg file, I found it easiest to use WordPad and tell it to save as a text file. Notepad didn't show any line breaks since it probably isn't using a CR/LF line ending. [Floppy] bAutoInsertDiskB = TRUE FastFloppy = FALSE EnableDriveA = TRUE DriveA_NumberOfHeads = 2 EnableDriveB = TRUE DriveB_NumberOfHeads = 2 nWriteProtection = 0 szDiskAZipPath = szDiskAFileName = szDiskBZipPath = szDiskBFileName = szDiskImageDirectory = E:\ I've added a link to the Atari-Forum discussion where this topic was discussed in 2015. http://www.atari-forum.com/viewtopic.php?t=28385 TL;DR: The Hatari developers all use Linux. Windows is the only modern OS that uses drive letters. If they received a patch from a Windows user who's also a developer, they'd be interested in the support. As to why the Hatari Windows UI is so bad, it's because no Windows user has stepped forward to write a Windows front end. I heard from someone years ago who created a Hatari front end but, to my knowledge, it was never released. Bob C Edited January 17, 2018 by darwinmac Quote Link to comment Share on other sites More sharing options...
Harry Potter Posted January 17, 2018 Author Share Posted January 17, 2018 So it's not possible. BTW, I did want multiple drives. Quote Link to comment Share on other sites More sharing options...
darwinmac Posted January 17, 2018 Share Posted January 17, 2018 If you want to have ST images on multiple drives, youre out of luck. I was hoping you simply saved your data (and ST images) on a different drive than where you probably put Hatari. Bob C Quote Link to comment Share on other sites More sharing options...
Harry Potter Posted January 17, 2018 Author Share Posted January 17, 2018 Is there a way to specify a different setup when starting Hatari? Quote Link to comment Share on other sites More sharing options...
Harry Potter Posted January 17, 2018 Author Share Posted January 17, 2018 Never mind. Found it! Quote Link to comment Share on other sites More sharing options...
darwinmac Posted January 17, 2018 Share Posted January 17, 2018 I would suggest bookmarking Hataris website. In my opinion, they have done a nice job documenting the different options. Im glad you found what you needed. Bob C Quote Link to comment Share on other sites More sharing options...
