Trip2018 Posted February 2, 2018 Share Posted February 2, 2018 (edited) Does anyone know how the color effect of chetiry was achieved and if there is a bB kernel avalible? I am working on the japanese equivilent of it (hopefully that makes sence). Edited February 2, 2018 by Trip2018 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted February 2, 2018 Share Posted February 2, 2018 To figure out how things are done, load the game in Stella: Then use the Developer Key COMMAND-<COMMA> on a Mac or ALT-<COMMA> on Linux/Windows to put Stella in Fixed Debug Colors Mode: If you enter the debugger in Stella by hitting ` (left of 1, above TAB) and select the TIA tab you can see what those colors represent: So Chetiry updates the object colors while the scanline goes across the screen (ie: Racing The Beam): BK = Background PF = Playfield P0 = Player 0 P1 = Player 1 BK = Background PF = Playfield P0 = Player 0 P1 = Player 1 BK = Background PF = Playfield (and a small sliver of BL, the ball) The black on the left & right is where VBLANK is turned on in order to prevent the screen from being drawn beyond the left/right of the gameplay area. The setting of VBLANK on the right is 1 pixel late, which the ball is used to hide. This makes the last column of blocks 5 pixels wide instead of 4. You can use the developer key COMMAND-B or ALT-B to turn the ball off and on in order to see why it's being used: Ball ON: Ball OFF: 2 Quote Link to comment Share on other sites More sharing options...
Trip2018 Posted February 2, 2018 Author Share Posted February 2, 2018 (edited) I have no idea how or what I should do to implemment this as I have no experience with assembly language. Edited February 2, 2018 by Trip2018 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted February 2, 2018 Share Posted February 2, 2018 I have no idea how or what I should do to implemment this as I have no experience with assembly language. It's not that difficult, try working through the interactive Easy 6502 tutorial. If you can follow that, then check out my Collect tutorial. Quote Link to comment Share on other sites More sharing options...
Trip2018 Posted February 3, 2018 Author Share Posted February 3, 2018 (edited) Perfect, thanks. Edited February 3, 2018 by Trip2018 Quote Link to comment Share on other sites More sharing options...
+Lewis2907 Posted February 3, 2018 Share Posted February 3, 2018 SpiceWare, Thanks for the link. I need to learn ASM. This should get me going. 1 Quote Link to comment Share on other sites More sharing options...
