kyle Posted February 24, 2018 Share Posted February 24, 2018 (edited) What kind of modification needs to be done to either the cartridge or the 7800 so tigervision games will fit ? Edited February 24, 2018 by kyle Quote Link to comment Share on other sites More sharing options...
roadrunner Posted February 24, 2018 Share Posted February 24, 2018 (edited) Take the cartridge apart and remove the plastic prong piece. Edited February 24, 2018 by roadrunner Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted February 24, 2018 Share Posted February 24, 2018 If you remove the prongs, then that would prevent them from being used on an actual 2600 since the cart slot dust cover won't be able to retract open without them. What I've done, is to use a pair of nail clippers and trim off about 1 cm of the plastic on each prong. That is how I play my miner 2049er on my 7800. However, this could be frowned upon since it is a permanent modification. But even if you trim the posts back as I've stated, it still works on a 2600 as well. Quote Link to comment Share on other sites More sharing options...
Lucky Man Posted February 24, 2018 Share Posted February 24, 2018 You can also cut or drill the screw posts off the bottom of the 7800 cart sleeve. You won't be able to fasten it down with the screws again, but the little clips will hold it in place on the board. I did this to mine so all of my cartridges would fit into the cart slot. Some people also cut the corners of the sleeve so tight fitting carts will work, but mine was fine. Here's a post on how to do the cart sleeve mod: http://atariage.com/forums/topic/123373-tigervision-compatibility-mod-complete/?hl=%2Bcartridge+%2Bguide+%2Bmod Quote Link to comment Share on other sites More sharing options...
+save2600 Posted February 25, 2018 Share Posted February 25, 2018 Buy a Harmony cart - that'll fix it but good. 3 Quote Link to comment Share on other sites More sharing options...
kyle Posted February 25, 2018 Author Share Posted February 25, 2018 (edited) I guess I could just hook up a 2600. lol Edited February 25, 2018 by kyle Quote Link to comment Share on other sites More sharing options...
Shawn Posted February 25, 2018 Share Posted February 25, 2018 What kind of modification needs to be done to either the cartridge or the 7800 so tigervision games will fit ? The cartridge glide openers need to be flipped. The part that is currently on the inside of the cart needs to be on the outside. Just flip them and close your cart back up and it should now fit just fine. I really do think they put them in backwards at the factory. 1 Quote Link to comment Share on other sites More sharing options...
