Dave7800 Posted February 26, 2018 Share Posted February 26, 2018 I just recently purchased a 7800 system. The problem Im having is that you have to really insert the cartridge with a lot of force. This happens with both 7800 and 2600 games. Sometimes if you dont get it in there properly the game wont play. Is this normal? Is there a fix for this or is it the age of the plastic? Quote Link to comment Share on other sites More sharing options...
atari181 Posted February 26, 2018 Share Posted February 26, 2018 From what developer are you talking about? Is it Atari branded games? There are multiple discussions about 7800s being finicky with different carts in the forums. Do a quick forum search you will find lots of info. Quote Link to comment Share on other sites More sharing options...
Dave7800 Posted February 26, 2018 Author Share Posted February 26, 2018 Yes they are strictly Atari only games. One of them was also a Data Age game too. Quote Link to comment Share on other sites More sharing options...
Dave7800 Posted February 26, 2018 Author Share Posted February 26, 2018 atari181, I did a forum search and these two threads explained a lot. Thanks http://atariage.com/forums/topic/261723-7800-and-imagic-carts-not-fitting/?do=findComment&comment=3685923 http://atariage.com/forums/topic/73258-finally/?do=findComment&comment=900532 1 Quote Link to comment Share on other sites More sharing options...
marlowe221 Posted March 2, 2018 Share Posted March 2, 2018 It can be weird. No Imagic 2600 cart will fit in my 7800 for love or money. Quote Link to comment Share on other sites More sharing options...
+hloberg Posted April 30, 2018 Share Posted April 30, 2018 A reiteration. the 'sleeve' mod of trimming the edges works for most 3rd party cartridges to fit. http://atariage.com/forums/topic/73258-finally/?do=findComment&comment=900532 Except; Tigervision still won't fit due to the pins are too long for the 7800. cartridge surgery is required to fix that. Also Parker Bros games with the spring loaded pins won't work without cartridge modification. I had some time so I just tested this by removing the 'sleeve'. Tigervision and above mentioned Parker Bros still wouldn't fit even with NO sleeve in place. I mod the sleeve and now all my 2600 carts fit but the two mentioned. I tested the actually ROMS without the cart and, yes, they work. the pins on the carts are the problem. since I don't want to damage the carts I'm not going to clip the pins. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted April 30, 2018 Share Posted April 30, 2018 Also Parker Bros games with the spring loaded pins won't work without cartridge modification. Parker Bros games with spring loaded pins? Which titles because this is the first I've heard of any parker bros carts not fitting into a 7800? Also, I believe CPUWIZ stated that if you are careful in removing the label on your tigervision carts, you can actually swap the plastic around that has the pegs on it. The pegs on the opposite site normally hidden within the cart are shorter and yet still long enough to open the dust doors on the 2600 and short enough to fit into a 7800 without cutting them a cm back or so as I had done in the past. Quote Link to comment Share on other sites More sharing options...
