Airshack Posted March 2, 2018 Share Posted March 2, 2018 Curious. For those who have a RAMDISK in their PEB... what are you using yours for? Quote Link to comment Share on other sites More sharing options...
Opry99er Posted March 2, 2018 Share Posted March 2, 2018 When I had one, I used it for running Funnelweb as my *OS* and partitioned off multiple *disks* for development. Wish I hadnt gotten rid of it. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 2, 2018 Author Share Posted March 2, 2018 I have a work disk for test programs, funnelweb, Preditor, DM2K and DSK2PC on it. Everything I need for development basically, at my fingertips without the hassle of swapping floppies. Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 2, 2018 Share Posted March 2, 2018 On my TI, it has most of the basic programs I need like my menu, FunnelWeb, archiver, terminal emulator, disk utilities, etc. I used to keep one partition available for Infocom games given the random access required. And assembling/linking code has no equal in the TI world than a nice, fast RAMdisk. Just be sure you back up regularly! Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted March 2, 2018 Share Posted March 2, 2018 It is a 3 Meg HRD16. All 10 partitions are used for menus, F'WEB, FbFORTH, TURBOFORTH, about 100 other programs and a 3200 sector partition reserved for "workspace". 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted May 4, 2019 Share Posted May 4, 2019 Does anyone want to help rebuild my HRD+ Im having no luck with following docs that im not even sure they work. Quote Link to comment Share on other sites More sharing options...
apersson850 Posted May 6, 2019 Share Posted May 6, 2019 I've only used my home-made RAM-disk to keep the SYSTEM.EDITOR, SYSTEM.COMPILER and SYSTEM.FILER when using the UCSD p-system. Since that operating system relies quite a lot on swapping these files in and out, it makes a big difference. Only recently have I added two Horizon RAM-disks, but not done so much more than figuring out why the ROS 8.xx didn't support the p-system. Got it going, but I'm not doing much with my TI nowadays. Quote Link to comment Share on other sites More sharing options...
RickyDean Posted May 6, 2019 Share Posted May 6, 2019 Does anyone want to help rebuild my HRD+ Im having no luck with following docs that im not even sure they work. Chris did you find someone to help? Quote Link to comment Share on other sites More sharing options...
GDMike Posted May 6, 2019 Share Posted May 6, 2019 I started using the step by step for the 3000 and after finishing the power section it says 1. After verifying everything place the card with no chips into the PEB. And you should get led 1 lit but not led2. I confirmed that. Then it says 2. Place all support chips into the card but not the 11 ram chips.. Here is where I lost everything.. It doesn't say where to run Jumpers, as I see traces in the photo of lots of traces and it doesn't explain setting up the stacked 138 chips. But it goes on saying run the mem test.. So, yes I'm missing out. But why these docs have this step by step and is Missing so much. Quote Link to comment Share on other sites More sharing options...
RickyDean Posted May 6, 2019 Share Posted May 6, 2019 I started using the step by step for the 3000 and after finishing the power section it says 1. After verifying everything place the card with no chips into the PEB. And you should get led 1 lit but not led2. I confirmed that. Then it says 2. Place all support chips into the card but not the 11 ram chips.. Here is where I lost everything.. It doesn't say where to run Jumpers, as I see traces in the photo of lots of traces and it doesn't explain setting up the stacked 138 chips. But it goes on saying run the mem test.. So, yes I'm missing out. But why these docs have this step by step and is Missing so much. Is yours a 3000 or the 3000b ? I do have one of each and can see what I can find out. Quote Link to comment Share on other sites More sharing options...
GDMike Posted May 6, 2019 Share Posted May 6, 2019 (edited) Thanks. Well that's a good question. Lol seems it was a HRD+. With an update to it..and the board layout looks just like the 3000 board. I believe Chris said to just remove everything and start over. Which was probably the best thing! That's when I couldn't find good docs. I'll attach photos here after I get kids off to school. Thanks Edited May 6, 2019 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted May 6, 2019 Share Posted May 6, 2019 This is now the basic board and it does get led 1 lit when placed in the PEB. Thanks on the help in advance. I'm not a super wiz at reading schematics. But I'm ok and there is some sloppy soldering here, but there was a reason as I only wanted to tack parts and not make them permanent to save wear on the board in case someone said, oh don't use that component, use this one etc..sorry to make it look sloppy but I'll clean it up as we determine it's a permanent thing. Quote Link to comment Share on other sites More sharing options...
GDMike Posted May 6, 2019 Share Posted May 6, 2019 (edited) The ic list that I have left over after removing everything: U2 74LS154. U3 2 stacked 62256LP-12 U4 2 stacked HM62256LP-12 U5 1 ea M5M5256P-15 U6 1 ea CXK58256P-12 U7 1 ea D43256A-85L U8 1 ea D43256AC-85L U9 2 stack 74LS259 U11 1 ea HM6264LP-12 U12 3 stack HM62256LP-12 U13 1 ea D43256A-85L U14 M5M5256BP-15L U15 1 ea M5M5256BP-15L U16 1 ea D43256C-12L U17 1 ea D43256C-12L U18 1 ea SN74LS156N U19 1 ea 74LS138 U20 3 stacked 74LS138 U21 1 ea 74LS144 U22 1 ea 74LS244 U23 1 ea 74LS245 Edited May 6, 2019 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted May 6, 2019 Share Posted May 6, 2019 (edited) One more note: I have 4 spare 138s. And 7 ea. HM6264LP-15 Edited May 6, 2019 by GDMike Quote Link to comment Share on other sites More sharing options...
RickyDean Posted May 6, 2019 Share Posted May 6, 2019 Let me look at my docs for the 3000 and see if I can find the hrd+ docs and see if i can help. But this will be tonight as I am at my day job. I have a 1000(I believe), 2000, 3000 and 3000b, and a 4000. Quote Link to comment Share on other sites More sharing options...
RickyDean Posted May 6, 2019 Share Posted May 6, 2019 (edited) Thanks. Well that's a good question. Lol seems it was a HRD+. With an update to it..and the board layout looks just like the 3000 board. I believe Chris said to just remove everything and start over. Which was probably the best thing! That's when I couldn't find good docs. I'll attach photos here after I get kids off to school. Thanks Have you looked at the 3000 information that Theirry Nouspikel put out, this may give some guidance? http://www.unige.ch/medecine/nouspikel/ti99/horizon.htm also some more info http://atariage.com/forums/topic/224208-horizon-hrd-ramdisk-debugging-repair/ ftp://ftp.whtech.com/datasheets%20and%20manuals/Hardware/Horizon%20-%20Bud%20Mills%20Services/ use anonymous as the user name, no password and there was a change in 1988 that may have some bearing, find attached. HORIZON CHANGE NOTICE.pdf Edited May 6, 2019 by RickyDean 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted May 6, 2019 Share Posted May 6, 2019 (edited) Thanks Ricky, I have I'm pretty sure seen every doc out there..they all pretty much start setting up the card with a list of parts, getting power configured and what chips to use etc.. and pictures..BUT I'm not finding exact trace wire-wrap runs (only ram is shown), and some boards have traces running to the edge connector and some photos without. I'm just confused on trying to read what chip does what and when and what revision..I can't seem to be able to keep all that straight. I am fine if someone gives me a layout of wiring runs, but not to good at following the schematic, unless I had a large white board and then laying everything out, but it's way too much work for a final report that may, no, Probably will not work due to some reason or another. I would think that if I knew what chips we're installed, and the wiring (physical) of pin to pin. And other Jumpers thant run to like the junction ports etc..If any of that makes sense? And I'm not in a hurry as I'm rebuilding a car at the same time, and like you said you're at work. So I understand where you are coming from. I would be fine as one step at a time to make sure I'm not wasting anyone's time here. Oh the fun. I'd love to get it working since I'm trying to write some forth code using a PEB that uses the 1mb sAMS card and the ramdisk just makes it so much nicer to code. Edited May 6, 2019 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
RickyDean Posted May 7, 2019 Share Posted May 7, 2019 Okay here are some pics of what I have, some are operational, some not so much, but getting there slowly. It seems as pic 004 and 005 are the closest to your version, they were created in 1988. 004 is however needing reconstruction as it had leaking batteries from 17 years of storage. 2 Quote Link to comment Share on other sites More sharing options...
GDMike Posted May 7, 2019 Share Posted May 7, 2019 Just looking them over. Thanks Quote Link to comment Share on other sites More sharing options...
GDMike Posted May 7, 2019 Share Posted May 7, 2019 (edited) Yeah nice boards! I believe like someone once said I have a HRD+ with all kinds of mods. And without schematics its very difficult. I think the color of the boards say something too. I believe there are serials on the boards. I appreciate your efforts here. Edited May 7, 2019 by GDMike Quote Link to comment Share on other sites More sharing options...
RickyDean Posted May 7, 2019 Share Posted May 7, 2019 Yeah nice boards! I believe like someone once said I have a HRD+ with all kinds of mods. And without schematics its very difficult. I think the color of the boards say something too. I believe there are serials on the boards. I appreciate your efforts here. Okay, gotcha. If you have the manual for that board, you should be able to strip it to the base components, then start back per the instructions to bring it back to that level at least. I don't know the mods as they weren't a concern of mine at the time(long story). I can look for the HRD+ manual and then can go through it step by step with you, till we get it there. It will take some time, as I work and this is my medium for communication at the time, until I get home in the evenings. But this is very doable. My boards don't have serials any more due to the process I used to clean years of trash off them after pulling them from storage (dishwasher) as they were bad. This explains the discoloration of the boards also(to hot). Quote Link to comment Share on other sites More sharing options...
GDMike Posted May 7, 2019 Share Posted May 7, 2019 Cool beans. Yup. At this point I'm interested in finding a board with the address switch rt next to the 74LS138 3-stack. You will know it when you see it. Lol its going to be the brain for this board because it does all the addressing for the memory space. Take you're time..you are doing me a favor,!! Quote Link to comment Share on other sites More sharing options...
RickyDean Posted May 8, 2019 Share Posted May 8, 2019 Cool beans. Yup. At this point I'm interested in finding a board with the address switch rt next to the 74LS138 3-stack. Here are some pics of a HRD+, that I got from an individual at one time. Keep in mind that the added wires are placed there, to support the chip stacking. The ram disk probably started out as a 384k for example and in this pic was taken to a higher capacity, so the wires were added to route the signals. I have also printed out the manual for my use if needed. Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted May 8, 2019 Share Posted May 8, 2019 Note, as previously stated--and even more obvious when looking at all of the pictures now in this thread (thanks everyone), your board is an HRD+. If it won't build as an HRD+, there is probably a broken trace or a bad solder joint on the board somewhere. It is also remotely possible that there is a bad component, but as the board fires up without any of the chips installed, that tells us the problem will likely be somewhere in the support logic area. If you try to build it as a 3000, you are doomed to failure, as there are a lot of differences between those boards. One note for those with HRD3000 boards--I have lots of the normally unobtainium 74LS154s in the .300 DIP variety. .600s are easy to find, but the .300s are not often to be found. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted May 8, 2019 Share Posted May 8, 2019 Ricky, I have U19 as a 138. Is that what that is, otherwise it looks like the board. Its gonna be hard to see, but maybe you have docs, but I need the wiring pin layout on upper to lower to lower on U20. And wiring from pin to pin on all jumpers..its a lot Thanks Quote Link to comment Share on other sites More sharing options...
