Swami Posted May 16, 2018 Share Posted May 16, 2018 Ive been thinking about the issues weve been having with using PC or PS2 racing wheels with pole position on the 5200 and Ive realized what would likely solve all the issues would be a proper racing wheel hack of pole position that uses the analog up and down of the joystick for gas and break and fire 1 and 2 buttons for high and low gear. That way we could have analog gas and brake that would work with the old pc wheels that use up and down for gas and brake with bohoki adapter and may solve the analog-digital issues Ive seen with the ps2 wheel in negcon mode. I wonder how difficult it would be for someone to make such a hack of the pole position rom? These are the two ROMS I have. They are just the original controller setup roms, but are a starting point if someone wants to do the hack. B is somehow different from A. I think A is the original 5200 version. Maybe B is some kind of 8-bit conversion as the horizontal alignment at least is different. The first one came with the 32K ROMS folder on the atarimax sd multicart and the second was in a 5200 merge ROM pack from emuparadise.Edit: here is an explanation of version B, which should be the rom to hack, as A does not work correctly on a ROM cart, but I will check both versions again to see if there are any advantages to A:http://atariage.com/forums/topic/225966-pole-position-wont-steer/page-1?do=findComment&comment=3001038 Pole Position A.bin Pole Position B.bin Quote Link to comment Share on other sites More sharing options...
0078265317 Posted May 16, 2018 Share Posted May 16, 2018 nice Quote Link to comment Share on other sites More sharing options...
Swami Posted May 16, 2018 Author Share Posted May 16, 2018 nice I should probably have clarified these do not do what I want, they are just the original controller setup roms, but are a starting point if someone wants to do the hack (I don't know how) or I ever learn to. I think it would be a cool hack for many people. I've been wanting to learn some programming, so this might be an interesting start, but it may be a long long time before I get there, if someone else wants to do the hacking. Also, a ways down in that thread is what I believe is a 8 or 10 track version of 5200 pole position - original cart and ROM glitch fixed versions. So, that may be a good one to do the hack on, as well. Quote Link to comment Share on other sites More sharing options...
Lynxpro Posted June 12, 2018 Share Posted June 12, 2018 Had Warner not forced Atari Inc to discontinue the 5200 in favor of the 7800, Dan Kramer was going to design a consumer version of the Pole Position controls for the 5200. That and a Yoke controller based upon the Star Wars Arcade Yoke. Quote Link to comment Share on other sites More sharing options...
Swami Posted June 12, 2018 Author Share Posted June 12, 2018 Had Warner not forced Atari Inc to discontinue the 5200 in favor of the 7800, Dan Kramer was going to design a consumer version of the Pole Position controls for the 5200. That and a Yoke controller based upon the Star Wars Arcade Yoke. We have determined one of these with the bohoki adapter will serve that purpose, although shifting involves pressing the yoke forward or backward and gas and brake are buttons on the handle tops. It does also work well with SWA:: https://www.ebay.com/itm/Vintage-New-G-Force-Plus-Fligh-Simulator-Joystick-Controller-Suncom/183251630955?hash=item2aaaa5fb6b:g:F18AAOSw17paxsQL Quote Link to comment Share on other sites More sharing options...
