256 colors Posted February 4, 2019 Author Share Posted February 4, 2019 You guys really are not making this easy for the kid... Unless you actually know that you need another version of TOS, I'd say 1.04 för ST and 1.62 for STE is just fine to start out with. Like I said earlier, more or less all software is patched today (atleast all the software that is worth wasting your time on is), but you need 1mb RAM. For STE, using simms, that is no problem, but upgrading an ST is difficult. 2.06 isn't really worth the hassle unless you are getting a harddrive, since you need a few auto booting programs to really take advantage of it, and you'd probably want 4mb ram aswell then. More likely this what i will do aim for a ST machine with TOS 1.04 then load TOS 1.02 via disk if when i need it or add it via switch Same with a STE machine with 4mb of ram with TOS 1.62 and add TOS 2.06 via switch with two machines setup that way i should be covered for as much compatibility as possible Quote Link to comment Share on other sites More sharing options...
6BQ5 Posted February 5, 2019 Share Posted February 5, 2019 More likely this what i will do aim for a ST machine with TOS 1.04 then load TOS 1.02 via disk if when i need it or add it via switch Same with a STE machine with 4mb of ram with TOS 1.62 and add TOS 2.06 via switch with two machines setup that way i should be covered for as much compatibility as possible Don't worry too much about the TOS version whether it's 1.62 or 2.06 ... or even 1.06. Your bigger challenge will be how to transfer downloaded files from your Windows PC to your ST machine. Simplest scenario will be ZIP files containing individual files that can be copied to a floppy. Wait till you get to MSA / ST files that exceed a single floppy! Maybe in that case you will want to upgrade RAM to 4MB first so you can make a RAM drive or maybe you will want to add a large capacity file storage system. Suddenly TOS version doesn't seem too critical in comparison. Oh, and don't forget your color display requires compatibility with low 15 kHz horizontal scan rates. You mentioned in your opening post you have a display with a SCART input. Hopefully you will be OK. Quote Link to comment Share on other sites More sharing options...
256 colors Posted February 5, 2019 Author Share Posted February 5, 2019 Don't worry too much about the TOS version whether it's 1.62 or 2.06 ... or even 1.06. Your bigger challenge will be how to transfer downloaded files from your Windows PC to your ST machine. Simplest scenario will be ZIP files containing individual files that can be copied to a floppy. Wait till you get to MSA / ST files that exceed a single floppy! Maybe in that case you will want to upgrade RAM to 4MB first so you can make a RAM drive or maybe you will want to add a large capacity file storage system. Suddenly TOS version doesn't seem too critical in comparison. Oh, and don't forget your color display requires compatibility with low 15 kHz horizontal scan rates. You mentioned in your opening post you have a display with a SCART input. Hopefully you will be OK. I have couple of display options Sony 28 inch wide screen CRT TV with RGB SCART input Then i have SAMSUNG T32E310 32" LED TV/MONITOR with RGB SCART and S-VIDEO input with a XRGM-MINI if i need too use it GOTEK DRIVE will be a must i'm not dealing with crusty old floppies to much hassle Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted February 5, 2019 Share Posted February 5, 2019 Don't worry too much about the TOS version whether it's 1.62 or 2.06 ... or even 1.06. Your bigger challenge will be how to transfer downloaded files from your Windows PC to your ST machine. Simplest scenario will be ZIP files containing individual files that can be copied to a floppy. Wait till you get to MSA / ST files that exceed a single floppy! Maybe in that case you will want to upgrade RAM to 4MB first so you can make a RAM drive or maybe you will want to add a large capacity file storage system. Suddenly TOS version doesn't seem too critical in comparison. Oh, and don't forget your color display requires compatibility with low 15 kHz horizontal scan rates. You mentioned in your opening post you have a display with a SCART input. Hopefully you will be OK. Transferring files between Atari and Windows PC (or Linux, or MAC) is very easy with Flash cards (SD cards) when you have TOS/DOS compatible partitions. Think about getting UltraSatan ... 1 Quote Link to comment Share on other sites More sharing options...
6BQ5 Posted February 5, 2019 Share Posted February 5, 2019 Transferring files between Atari and Windows PC (or Linux, or MAC) is very easy with Flash cards (SD cards) when you have TOS/DOS compatible partitions. Think about getting UltraSatan ... It’s been on my wish list for a while now. Maybe next month. Quote Link to comment Share on other sites More sharing options...
256 colors Posted February 6, 2019 Author Share Posted February 6, 2019 Running out of options were to buy a 2nd hand unit anybody know good online stores or other sites? Quote Link to comment Share on other sites More sharing options...
6BQ5 Posted February 6, 2019 Share Posted February 6, 2019 I always scour : eBay Amazon Craigslist Here Atari Forum Vintage Computer Federation Be sure to post a Want To Buy message in the marketplace section of those forums. Throw your net wide. Quote Link to comment Share on other sites More sharing options...
256 colors Posted February 6, 2019 Author Share Posted February 6, 2019 I always scour : eBay Amazon Craigslist Here Atari Forum Vintage Computer Federation Be sure to post a Want To Buy message in the marketplace section of those forums. Throw your net wide. Okay Anyway i'm trying out Windows version of Hatari with TOS 1.62 and add TOS 2.06 on STE settings and 4mb of ram to give me idea how many STX files are compatible Because i'm in a PAL region were i can't find PAL versions of games is it going be a hassle using NTSC versions when i need too? Quote Link to comment Share on other sites More sharing options...
6BQ5 Posted February 6, 2019 Share Posted February 6, 2019 Okay Anyway i'm trying out Windows version of Hatari with TOS 1.62 and add TOS 2.06 on STE settings and 4mb of ram to give me idea how many STX files are compatible Because i'm in a PAL region were i can't find PAL versions of games is it going be a hassle using NTSC versions when i need too? Hmm ... I haven't run into any issues running PAL or NTSC versions of programs on Hatari. I'm in the US so when I boot up with my TOS 2.06 images I normally see 60 Hz in my status bar. When I run a demo or two from Europe that requires special timings then I do see the 60 Hz change to 50 Hz. Obviously, the 50 Hz and 60 Hz are all emulated/simulated. Runs without a hitch or glitch! Quote Link to comment Share on other sites More sharing options...
256 colors Posted February 6, 2019 Author Share Posted February 6, 2019 Hmm ... I haven't run into any issues running PAL or NTSC versions of programs on Hatari. I'm in the US so when I boot up with my TOS 2.06 images I normally see 60 Hz in my status bar. When I run a demo or two from Europe that requires special timings then I do see the 60 Hz change to 50 Hz. Obviously, the 50 Hz and 60 Hz are all emulated/simulated. Runs without a hitch or glitch! On real 800XL hardware NTSC games are just abit slower so i guess it's the same? Whilst i'm here what's a good mouse for the ST? Quote Link to comment Share on other sites More sharing options...
6BQ5 Posted February 6, 2019 Share Posted February 6, 2019 On real 800XL hardware NTSC games are just abit slower so i guess it's the same? Whilst i'm here what's a good mouse for the ST? Speed - yes, you will probably notice speed differences. I've bumped into a few European Sound Tracker programs that play faster than expected on my STe. So, you may find some software may run slower than expected on your PAL system. I use the original STM1 mouse that came with my STe and it's the same model I used 20+ years ago. There are replacement 9-pin mice on eBay and I've seen adapters for interfacing to USB mice as well. Maybe a USB adapter would be a good choice for you if you want to use something light and modern. Quote Link to comment Share on other sites More sharing options...
eeun Posted February 8, 2019 Share Posted February 8, 2019 To further complicate your options, if you don't like being tethered to a PC, there are also FPGA options like MiST and MiSTer. Instant on, low power, no host OS in the way. Quote Link to comment Share on other sites More sharing options...
256 colors Posted February 8, 2019 Author Share Posted February 8, 2019 (edited) To further complicate your options, if you don't like being tethered to a PC, there are also FPGA options like MiST and MiSTer. Instant on, low power, no host OS in the way. Yeah i really don't like being hand cuffed to the PC with noisy fans and software and security bullshit updates Whilst emulation has it's pro's and cons i'd rather deal with real hardware knowing it should behave as expected Edit: :I would say Hatari is a lot better then few years ago Edited February 8, 2019 by 256 colors 1 Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted February 10, 2019 Share Posted February 10, 2019 As far as a mouse goes, if you want an Atari ST specific mouse, with the best "feel" IMHO, then Best Electronics "Best" mouse is the way to go. It is expensive though, at $34.95. http://www.best-electronics-ca.com/accesori.htm#mouse(top of the page). Quote Link to comment Share on other sites More sharing options...
256 colors Posted February 19, 2019 Author Share Posted February 19, 2019 Shoud get it friday Atari 1040STE with GoTeck drive and 4MB of ram TOS 1.62 english Theirs a pink security marking on the case any ideas on best way of getting rid of this? 1 Quote Link to comment Share on other sites More sharing options...
6BQ5 Posted February 19, 2019 Share Posted February 19, 2019 Marking? Pictures, please! I’m curious to see what this looks like. Quote Link to comment Share on other sites More sharing options...
