+Karl G Posted February 4, 2019 Share Posted February 4, 2019 I'm trying to figure out the cause of messages along these lines output by DASM: old value: $0001 new value: $000e old value: $0007 new value: $0004 old value: $fa00 new value: $fa05 old value: $fa05 new value: $fa0a ... There are 51 of them, and I believe that they are coming from an assembly module where I'm defining 50 text glyphs like so: text_data left_text __A = * - text_data ; baseline (0) .byte %00100000 .byte %01010000 .byte %01110000 .byte %01010000 .byte %01010000 __B = * - __A .byte %01100000 .byte %01010000 .byte %01100000 .byte %01010000 .byte %01100000 __C = * - __A .byte %00110000 .byte %01000000 .byte %01000000 .byte %01000000 .byte %00110000 __D = * - __A .byte %01100000 .byte %01010000 .byte %01010000 .byte %01010000 .byte %01100000 ... There are also definitions for the same glyphs with the glyphs on the right side, but without the labels. What do these messages likely mean? I would think that this message would be indicating that I'm redefining symbols, but I don't think that's the case here. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted February 4, 2019 Share Posted February 4, 2019 (edited) I saw that error before. Turns out that I didn't declare the address location of a variable soon enough in the assembly (so that on first pass, some instructions were using absolute addressing, and then zero page addressing on the second pass). Have Dasm make a report with the -List switch, then take a look at where the errors start. It'll show you how many bytes each instruction is using as it builds the binary. Dasm C:\folder_name\program.asm -f3 -lreport.txt -oC:\folder_name\binary.bin Edited February 4, 2019 by Nukey Shay 2 Quote Link to comment Share on other sites More sharing options...
+Karl G Posted February 4, 2019 Author Share Posted February 4, 2019 Thanks! Quote Link to comment Share on other sites More sharing options...
