First Spear Posted February 15, 2019 Share Posted February 15, 2019 Attempting to use the below code to erase the GRAM contents of locations 20 to 50. Is that the best way to do that? Thanks. For cc= 20 to 50 Define cc , 1 , GramTile_Bitmaps_0 If cc % 8 Then Wait Next GramTile_bitmaps_0: DATA $0000,$0000,$0000,$0000 Quote Link to comment Share on other sites More sharing options...
skywaffle Posted February 15, 2019 Share Posted February 15, 2019 I did not think you could more or less queue multiple GRAM definitions in between waits. Are you needing to always clear the same number of grams? Quote Link to comment Share on other sites More sharing options...
intvnut Posted February 15, 2019 Share Posted February 15, 2019 (edited) If you don't mind a bit of assembly, I think you can do this in a single frame. . Clear20to50: Procedure ASM MVII #c20to50, R0 ASM MVO R0, $100 ASM SWAP R0 ASM MVO R0, $101 ASM DECR PC ASM c20to50: ASM SUBI #8, R6 ASM MVII #_int_vector, R0 ASM MVO R0, $100 ASM SWAP R0 ASM MVO R0, $101 ASM MVII #(50 - 20) + 1, R0 ASM CLRR R1 ASM MVII #$3800 + 20*8, R4 ASM c20to50l: ASM MVO@ R1, R4 ASM MVO@ R1, R4 ASM MVO@ R1, R4 ASM MVO@ R1, R4 ASM DECR R0 ASM MVO@ R1, R4 ASM MVO@ R1, R4 ASM MVO@ R1, R4 ASM MVO@ R1, R4 ASM BNEQ c20to50l End . Clearing GRAM tiles goes much quicker than copying images into GRAM tiles. I did not think you could more or less queue multiple GRAM definitions in between waits. Are you needing to always clear the same number of grams? There is a WAIT buried in the IF-statement in First Spear's code: If cc % 8 Then Wait EDIT: Never mind, that's not what you meant. You meant multiple calls to Define between calls to Wait. Edited February 15, 2019 by intvnut Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted February 15, 2019 Share Posted February 15, 2019 I'm curious ... why do you need to clear GRAM? I can't imagine a scenario where loading up GRAM with a blank card would be needed. If you need to make a MOB invisible, you can clear its "Visibility" flag. If you need a BACKTAB card to be clear, just set it to GROM card #0 (which is blank). The only time I would worry about clearing GRAM would be during program initialization, but then that's handled by the EXEC during the bootstrap process. Even if you'd like to do it, it wouldn't be a time-critical process, so you could just loop with active display disabled and do the whole thing in one go. What specifically are you trying to accomplish? -dZ. Quote Link to comment Share on other sites More sharing options...
intvnut Posted February 15, 2019 Share Posted February 15, 2019 I can imagine if you're computing tile bitmaps programmatically, say for rendering a proportional font bit-by-bit over multiple frames (think "RPG dialog" where text appears at speaking speed), or maybe an "automap" type of feature, starting from a blank bitmap is a good idea. You can put your canvas tiles in BACKTAB, and then focus on DEFINE-ing cards as you update bits. That said, 31 is (literally) an odd number of GRAM tiles to clear. It's also prime. Quote Link to comment Share on other sites More sharing options...
carlsson Posted February 15, 2019 Share Posted February 15, 2019 If you have the ROM available, I would probably waste 15 * 4 = 60 words of $0000 and DEFINE 15 cards at a time. Intvnut's assembly code probably is even better, but if you desire to stay entirely in IntyBASIC that would be a decent approach I believe. Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted February 16, 2019 Share Posted February 16, 2019 I can imagine if you're computing tile bitmaps programmatically, say for rendering a proportional font bit-by-bit over multiple frames (think "RPG dialog" where text appears at speaking speed), or maybe an "automap" type of feature, starting from a blank bitmap is a good idea. Gotcha. That's why I asked what was the actual use case to see what would be most optimal for it. Those you mentioned would be good candidates to clear the canvas. -dZ. Quote Link to comment Share on other sites More sharing options...
