Nukey Shay Posted July 13, 2019 Share Posted July 13, 2019 Code areas used for spacing to keep branches in check still need editing if the city/stargate options are changed. This edit is stable for displaying the 20pixel city without a stargate: Defendr2.asm Def2.bin Quote Link to comment Share on other sites More sharing options...
rallyrabbit Posted July 14, 2019 Author Share Posted July 14, 2019 21 hours ago, Nukey Shay said: Removing that code provides enough free space to add Defender's full city gfx...just a couple of branch pagecross glitches to iron out. Unfortunately I didn't remove that code.... I just repurposed it elsewhere for a different function. I currently have 130 bytes free in bank 0 and maybe 80 bytes free in bank 1 - that's with me still trying to out my radar glitch.... On a side note, in both yours and in mine, I am finding a lot of radar glitches. Lots of phantom blips showing up from time to time. I'm trying to deal with that tonight. You may have seen from my bins that I am trying to go with a full solid bar side to side below the radar. so when I actually set PF0 (0xF0), PF1 (0xFF), PF2 (0x83) and back to 0x00 for all three at the end of the radar update before updating the scanlines for the playing area - it tends to get worse. This all of course is being done in the area around LF360 Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 14, 2019 Share Posted July 14, 2019 (edited) Not seeing the phantom blips you mentioned (?) Gotta make sure that the radar display loop is NOT crossing a page (0 free cycles here). 59 minutes ago, rallyrabbit said: You may have seen from my bins What bins? I can't find any you posted (I'd have a better understanding of what your games problems are if you did). BTW moving setup code out of the display bank provides enough space to add the city gfx table (208 bytes for 20 pixel version). Edited July 14, 2019 by Nukey Shay Quote Link to comment Share on other sites More sharing options...
rallyrabbit Posted July 14, 2019 Author Share Posted July 14, 2019 (edited) 11 hours ago, Nukey Shay said: Not seeing the phantom blips you mentioned (?) Gotta make sure that the radar display loop is NOT crossing a page (0 free cycles here). What bins? I can't find any you posted (I'd have a better understanding of what your games problems are if you did). BTW moving setup code out of the display bank provides enough space to add the city gfx table (208 bytes for 20 pixel version). As soon as I get done with housework, I'll go into the symbol file and start looking at the paging. The end of my radar code is (which uses for previous bit but retains some of what I was doing to get the bottom bar). I would say you are probably right about paging since this code caused one of the above branches to fail (too long)..... LF360: STA WSYNC ;3 LDX #$F0 ;2 PF0 makes radar to the entire screen STX PF0 ;3 LDX #$FF ;2 give to an unused register to save for PF2 next line STX PF1 ;3 LDA #$83 ;2 sides+the tab in the lower center of the radar STA PF2 ;3 STA WSYNC ;3 JSR LF92E ;6 looks like it is designed to waste cycles STX PF2 ;3 JSR LF92E ;6 looks like it is designed to waste cycles LDX #$03 ;2 NOP ;2 NOP ;2 @55 STA ENABL ;3 STA VDELP1 ;3 STA NUSIZ0 ;3 STA NUSIZ1 ;3 @67 CLC ;2 @69 STA PF2 ;3 STA PF1 ;3 @75 STA PF0 ;3 BCC LF3A2 ;2 always branch to update game area I will say when I use your code only in my file, it does not seem to have the radar glitch as often (rarely), this is your code for the same bit: LF360: DEY ;2 16/21/26/31/36/41/46/51/56 BNE LF360 ;2 19/24/29/34/39/44/49/54/58 STA ENABL ;3 61 STA VDELP1 ;3 64 STA NUSIZ0 ;3 67 STA NUSIZ1 ;3 70 LDA #$7E ;2 72 STA PF2-2,X ;4 00 INX ;2 BNE LF3A2 ;3 LF395: JMP LF553 ;3 You're looping rather than me trying to force things with the timing (like the original code did) Here's my latest... which is still not 100% what i want because I am still dealing with the radar issue. Something else I noticed as soon as I put in your radar code vs the old radar code I was using is the fact that the ship goes up to the top of the play area but the ship image (and enemy images) get cut off. This should me Roughly speaking, here's the changes I made and some info on it: 1) Title Screen (part of design espire did for Defender Arcade that was not adopted) 2) End of Wave Screen changed 3) Firebomber changed into Atari 2600 Defender Bomber 4) Lander changed into Atari 2600 Lander 5) Mutant changed into Atari 2600 Mutant 6) Big Red changed into Atari 2600 Baiter 7) Phred changed into a Atari 2600 Baiter that shoots Removed Bonus/dogfight Stages 9) Score digits are the digits used in Atari 2600 Defender 10) Removed Inviso 11) Radar changed to look like Atari 2600 Defender in color, border now takes up the full screen 12) Graphics for Extra Ships and Smart Bombs changed to a vector format 13) Scoring for pods is now 1000 points 14) Ship was changed (not like Stargate or Atari 2600 Defender) 15) Bonus for people at end of stage is 100 points 16) City added instead of mountains when planet is not destroyed (to give a look and feel more like Atari 2600 Defender) (Nukey Shay) 17) Removed Hypersace risk of exploding and losing the ship 18) Hypersapce can be used with Player 1 fire button while at the top of the playing area and pushing up while firing. There is no limit on hyperspace. NOTE: When a Hyperspace is used successfully, the ship will not fire a laser. NOTE: When a person is abducted, hyperspace can be used to jump to the abduction (like the old startgate worked previously) 19) Smart Bombs can be used from player 1 fire button when at the bottom of the city or space area if planet destroyed). NOTE: People in the city can still be shot if at the level to use smartbomb. NOTE: When a Smart Bomb is used successfully, the ship will not fire a laser. 20) Removed Munchie, Phred, Yllabian Space Guppy as eneoies 21) Sounds of enemies shooting has been changed to be more similar to Atari 2600 Defender 22) Removed the platforms under the people when planet isn't detroyed 23) The color of the people on the planet matches Defender Arcade 24) Scoring for picking up falling people is not cumulative increasing, it is a standard 500 points 25) Stargate is no longer in the play area or the scanner 26) Retained and use the dynamo that comes out in attack 2 of waves 27) First attack of each wave contains Landers, Dynamo, Bombers with Pods (after wave 5) 28) Second attack of each wave contains Baiters that do not shoot, Bombers and Landers 29) Baiters that can shoot are introduced singly after lengths of failing to end the wave after the second attack occurs 30) Wave multiplier for increasing enemy speed is slowed down by half to get better longer game play out of a typical game (one of the big complaints of defender II/stargate/defender arcade is how short the games are because it is too hard). 31) End of wave "person" bonus text now doesn't look goofy (it actually flows with the rest of the text) 32) Only the Dynamo and POD remain as they were in Defender II/Stargate. All other images are "static" (all 4 graphics represent the same graphic). I still have the options for no hits, invincible, etc on for debugging, I also have not removed the original stargate code as I use it to test with occasionally. defender city v16.bin Edited July 14, 2019 by rallyrabbit more info Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 14, 2019 Share Posted July 14, 2019 (edited) Your scanner begins at cycle 60 instead of cycle 61...so all the writes to the GR registers are off by 1 cycle. Quick fix: Leading up to the scanner, A is loaded with the value 2 at both F322 and F344. Change the 2 bytes at F344 to be D0 00 instead of A9 02. That new branch will burn the missing cycle (A still holds a 2 from F322). Edited July 14, 2019 by Nukey Shay Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 14, 2019 Share Posted July 14, 2019 .. Quote Link to comment Share on other sites More sharing options...
rallyrabbit Posted July 17, 2019 Author Share Posted July 17, 2019 So far no dice, comparing code back to the point that it worked to see what I changed that lead to this Quote Link to comment Share on other sites More sharing options...
rallyrabbit Posted July 17, 2019 Author Share Posted July 17, 2019 Oooo the problem was my coding, optimized some code and calculated cycles and current scanline wrong. So that's good, now back to testing and looking at the last city change. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 20, 2019 Share Posted July 20, 2019 You should not WSYNC before you draw the horizontal line below the scanner, this bumps the total to 263. A time check can be done after the 2nd WSYNC to waste some cycles and store the result to $F0 temporarily. This cuts down the time leading to the city jump later (providing the necessary cycles to use the updated city kernel). Also, enough space for the full city is obtained by moving the code below $F5C3 to the areas currently being used for the city gfx. Demo: defcity.asm temp.bin Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 20, 2019 Share Posted July 20, 2019 BTW the game you posted crashes if all the humanoids are killed. Trying to find the cause. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 20, 2019 Share Posted July 20, 2019 (edited) Found it. The first DEY in the city routine does not check if zero. Odd, since it worked fine in my assembly. You can use those spare cycles to add a branch to fix it: sta.w PF2 ;4 added 1 cycle tya ;2 ; sta $2E ;3 beq LFFED ;2 branch to JMP if already 0 and #$03 ;2 beq LFFE9 ;2/3 .byte $C5 ;3 temp.bin Edited July 20, 2019 by Nukey Shay Quote Link to comment Share on other sites More sharing options...
rallyrabbit Posted July 24, 2019 Author Share Posted July 24, 2019 On 7/20/2019 at 5:50 AM, Nukey Shay said: Found it. The first DEY in the city routine does not check if zero. Odd, since it worked fine in my assembly. You can use those spare cycles to add a branch to fix it: sta.w PF2 ;4 added 1 cycle tya ;2 ; sta $2E ;3 beq LFFED ;2 branch to JMP if already 0 and #$03 ;2 beq LFFE9 ;2/3 .byte $C5 ;3 temp.bin 8 kB · 1 download Weird that was working. Thanks I fixed that. Quote Link to comment Share on other sites More sharing options...
rallyrabbit Posted July 24, 2019 Author Share Posted July 24, 2019 (edited) On 7/19/2019 at 10:15 PM, Nukey Shay said: You should not WSYNC before you draw the horizontal line below the scanner, this bumps the total to 263. A time check can be done after the 2nd WSYNC to waste some cycles and store the result to $F0 temporarily. This cuts down the time leading to the city jump later (providing the necessary cycles to use the updated city kernel). Also, enough space for the full city is obtained by moving the code below $F5C3 to the areas currently being used for the city gfx. Demo: defcity.asm 290.95 kB · 3 downloads temp.bin 8 kB · 4 downloads OK, I think I need some more newbie explanation here. The game seems to run fine with the code I have.... I am not sure i understand the problem I am causing. I merged in the radar bit that you changed, it does work, but, my scanlines still all lined up.... Edited July 25, 2019 by rallyrabbit Quote Link to comment Share on other sites More sharing options...
rallyrabbit Posted July 25, 2019 Author Share Posted July 25, 2019 (edited) So I've been doing some comparisons. Radar: Stargate: Scanline 61 to 77 Defender Arcade: 61 to 77 Your build: 61 to 79 Your build of my defender city: 60 to 78 (though I know the problem here on why it starts too early) My port without your radar code: 61 to 79 My port with you radar code include: 61 to 79 So, I think somewhere, I am 2 scanlines too long, so I'm trying to figure that out now. Also, do you know which part of the code launches the baiters when the wave takes too long? Edited July 25, 2019 by rallyrabbit Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 27, 2019 Share Posted July 27, 2019 LD542. This is branched to when the delay timer rA8 reaches zero. It is then given the value of 2, loop LD548 checks for any free slot (read+$22,X = 0), the low 3 bits of timer r80 is used to choose which enemy to send from table LDDE7. LD56C is branched to if no free slots are available. Quote Link to comment Share on other sites More sharing options...
rallyrabbit Posted August 10, 2019 Author Share Posted August 10, 2019 Well, I am almost done. I decided to keep with the simple city. I had to scale back what I Was doing on the radar to maintain the scanline behavior. But now I have another Y index glitch in the city kernel (my code with your change from 7/23). Seems that making the radar work on the proper scanlines has screwed up the solution you came up with for the Index Y checks. Now I either crash when planet is destroyed or have trails on the people waiting to be abducted. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted August 10, 2019 Share Posted August 10, 2019 Must be hitting HMOVE a cycle late. Check the debugger that branches executing beforehand are not crossing pages (they will be flagged with ! in Stella's code window). Quote Link to comment Share on other sites More sharing options...
rallyrabbit Posted August 12, 2019 Author Share Posted August 12, 2019 On 8/9/2019 at 9:58 PM, Nukey Shay said: Must be hitting HMOVE a cycle late. Check the debugger that branches executing beforehand are not crossing pages (they will be flagged with ! in Stella's code window). I think I was off by a cycle somehow (too short) before the branch and throwing off the rest of the loop while decrementing Y. Quote Link to comment Share on other sites More sharing options...
rallyrabbit Posted August 12, 2019 Author Share Posted August 12, 2019 The last version of the game (I guess is v18). Testing now but thing this may be close to being the last spin. v18.bin Quote Link to comment Share on other sites More sharing options...
rallyrabbit Posted August 13, 2019 Author Share Posted August 13, 2019 Well pretty quick I've found another radar bug when a lander picks up a person it starts messing up. So will have to sort that now the fun never stops! Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted August 13, 2019 Share Posted August 13, 2019 (edited) You are still +1 cycle in the city routine...HMOVE must always execute from cycle 0. Fixed w/improved ship display there: Edited August 13, 2019 by Nukey Shay Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted August 13, 2019 Share Posted August 13, 2019 26 minutes ago, rallyrabbit said: Well pretty quick I've found another radar bug when a lander picks up a person it starts messing up. So will have to sort that now the fun never stops! Part of the problem is that the radar display area is off by 1 cycle as well (so the GR registers are hit 1 cycle too late). Just above the loop, change the 2 NOP instructions (4 cycles) to be STA $2E (3 cycles). Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted August 13, 2019 Share Posted August 13, 2019 Why were these 4 lines removed? This is the source of the issue, I think. LDA read+$4D,X ;4 ORA rF1 ;3 STA write+$4D,X ;5 BNE LD90B ;2 always branch? LD8E7: V18fix.bin Quote Link to comment Share on other sites More sharing options...
rallyrabbit Posted August 13, 2019 Author Share Posted August 13, 2019 17 hours ago, Nukey Shay said: Why were these 4 lines removed? This is the source of the issue, I think. LDA read+$4D,X ;4 ORA rF1 ;3 STA write+$4D,X ;5 BNE LD90B ;2 always branch? LD8E7: V18fix.bin 8 kB · 2 downloads Yeah it looks like it. That ay be a victim of an unlocked computer + kids ? thanks. Back to final testing. Quote Link to comment Share on other sites More sharing options...
rallyrabbit Posted August 15, 2019 Author Share Posted August 15, 2019 v19 release candidate. Adjusted some sounds (enemy shots and person abduction). Made some adjustments we talked about above. Things look better. v19.bin Quote Link to comment Share on other sites More sharing options...
