silentshadow56 Posted July 26, 2019 Share Posted July 26, 2019 I have an Atari Falcon modded with a CenTurbo II Rev. B accelerator installed that I'm eventually looking to sell, but need to test everything out first so I'm not super concerned with quality and everything like that. I have both adapters for VGA output and Composite output and composite would seem like the easy choice, but it's a 16-Pin DIN? Like I said all I'm trying to do is check to make sure everything boots up and runs properly and if it doesn't to then be able to diagnose it. What would be the simplest way to get it to output onto a modern television? Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted July 26, 2019 Share Posted July 26, 2019 Not really sure what you mean with 'have both adapters' - it goes in Falcon's 19-pin video connector, and what is on other end ? 16 pin DIN connector ? But you need for composite signal simple cable what leads composite signal and GND to TV. Like Scart connector - that's what new TVs have in Eu . They may be special just composite input on some TVs - RCA ? . And some may not have it at all. VGA way is what should work with every newer TV, monitor. Quote Link to comment Share on other sites More sharing options...
silentshadow56 Posted July 26, 2019 Author Share Posted July 26, 2019 6 hours ago, ParanoidLittleMan said: Not really sure what you mean with 'have both adapters' - it goes in Falcon's 19-pin video connector, and what is on other end ? 16 pin DIN connector ? But you need for composite signal simple cable what leads composite signal and GND to TV. Like Scart connector - that's what new TVs have in Eu . They may be special just composite input on some TVs - RCA ? . And some may not have it at all. VGA way is what should work with every newer TV, monitor. Yes, I have an adapter that plugs into the atari falcon and then one has and 16 pin din on the other end and the second one has a vga on the other end. I'm just looking for something I can use that will allow me to display it on my tv Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted July 26, 2019 Share Posted July 26, 2019 I saw such solution. You missing end for TV mode, with proper connector. And without you giving more info - what connector(s) you have on your TV is is really not possible to give help. Can you perform some simple cable/connector soldering ? If not, you need to order complete cable for TV . Quote Link to comment Share on other sites More sharing options...
silentshadow56 Posted July 26, 2019 Author Share Posted July 26, 2019 I would need to order a complete cable for my tv, but I don't know where I can get such a cable or what kind to get Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted August 27, 2019 Share Posted August 27, 2019 If as you say you have a VGA lead then why not get something like this https://www.amazon.co.uk/eSynic-Converters-Converter-Female-Adapter-VGA-HDMI-3-5mm-Audio/dp/B00S646VV4 I have bought similar devices for old consoles like Wii and Game Cube , they seem to work fine Quote Link to comment Share on other sites More sharing options...
