RasterScan Posted August 5, 2019 Share Posted August 5, 2019 (edited) Hey all. I recently acquired a 1040 STe. The top half of the the enclosure was damaged badly in shipping; the bottom half survived with a few repairable cracks. I did patch up the top case. My question is, would you continue repairing the top case and paint the enclosure or just source out a replacement top half. I’ll include a few photos. I always disliked the idea of painting cases. Also, the ABS is very brittle. This is another reason I’m apprehensive about painting the case. Thanks! Edited August 5, 2019 by RasterScan Quote Link to comment Share on other sites More sharing options...
towmater Posted August 6, 2019 Share Posted August 6, 2019 Paint might help it hold together a little longer, it's probably worth a try since you'd dispose of it in any case (no pun.) Perhaps avoid garish colors. 1 Quote Link to comment Share on other sites More sharing options...
javiero Posted August 6, 2019 Share Posted August 6, 2019 Hope it helps. 1 Quote Link to comment Share on other sites More sharing options...
RasterScan Posted August 6, 2019 Author Share Posted August 6, 2019 Thanks! I did see that video. I think I will paint it Stone Gray and call it a day. Quote Link to comment Share on other sites More sharing options...
Ute Posted August 7, 2019 Share Posted August 7, 2019 I saw an ST on ebay that had been Hydro dipped with Carbon Fiber, it looked ok. Something like this, except on an ST case and without the high gloss: Quote Link to comment Share on other sites More sharing options...
RasterScan Posted August 8, 2019 Author Share Posted August 8, 2019 4 hours ago, Ute said: I saw an ST on ebay that had been Hydro dipped with Carbon Fiber, it looked ok. Something like this, except on an ST case and without the high gloss: Interesting. Not a bad idea. The enclosure I have is too far gone. I painted it today but it was cracking as I was handling it. ? Quote Link to comment Share on other sites More sharing options...
Ute Posted August 8, 2019 Share Posted August 8, 2019 (edited) You can try the extreme fix in the video above if you have the means. You can fix small cracks with Acetone, it melts the plastic back together. But it's also easy to accidentally drip it on parts your not gluing and damage them or make it look funny. Sounds like it may be to brittle? B&C sells ST cases, but you have to email Bruce and talk to him directly. Last time I talked with him they were around $40 USD Edited August 8, 2019 by Ute Additional info. Quote Link to comment Share on other sites More sharing options...
RasterScan Posted August 16, 2019 Author Share Posted August 16, 2019 On 8/8/2019 at 7:18 PM, Ute said: You can try the extreme fix in the video above if you have the means. You can fix small cracks with Acetone, it melts the plastic back together. But it's also easy to accidentally drip it on parts your not gluing and damage them or make it look funny. Sounds like it may be to brittle? B&C sells ST cases, but you have to email Bruce and talk to him directly. Last time I talked with him they were around $40 USD I contacted them but no luck. I patched it up as much as I can. i glued it up and painted it. Now I’m waiting for the paint to dry. I would still like to find an enclosure. I’m afraid to even move this one. Thanks everyone! Quote Link to comment Share on other sites More sharing options...
